Question about Bernina Sewing Machines
Serger runs by itself Bernina /serger 2000D
Bernina 2000D. Plug in cord, and the thing starts by itself. Have replaced cord and control once before for this client. NO (Normally open) safety switch on door DOES override/permit motor engaging, but when you shut the front door, the machine starts w/o depressing the foot control.
Could the diode/resistor already burn out permitting constant power through the ''switch''/speed control. Variable speed resistor still continues to control increase in speed, but there is no stopping when foot pressure is removed .
Any ideas?
5 Suggested Answers
RickE1
  • 202 Answers
SOURCE: Threading a bernina serger
Here is a little jingle to remember as far as the order of threads to thread...
Upper looper, lower looper, left needle, right.
Usuall if you give numbers to the threads from left to right as 1,2,3,4 , you would thread it in the order of 3, 4, 2, 1 . Also when threading the loopers be sure the lower looper thread goes over the top of the upper looper thread as it goes out the back.
Hope this helps.
Posted on Oct 18, 2008
  • 980 Answers
SOURCE: Old model Bernina 830, running ok, then kept
There is a thing called a suppressor which is normally located in the foot control which has fused, you need to open the foot control and you should see a a small thing that looks liuke a fuse connected to the two terminals which you need to take out and discard because you don't need it any more, if you don't have on in the control then it will be on the motor which means you will have to take it in for repair.
Posted on Jun 27, 2009
SOURCE: how to i thread my 008d bernina serger
If you need addtional help email me @ icando@sonic.net I'll help you. I have the same serger. I like it. You probably will to once you've figured it out. Although I don't know anyone that has that model beside me and a Bernina Dealer.
Posted on Jul 10, 2009
  • 96 Answers
SOURCE: bernette for bernina funlock 004D/004 locked
you may have a build up of fuzz or lint try to clean and oil it
Posted on Dec 13, 2009
Sewtech1
  • 69 Answers
SOURCE: 2000DE serger manual
Can help you with a bernina 2000 manual at info@absolutesewing.co.nz or try www.janomestuff.com
Posted on Jan 25, 2010
Bernina 1006 foot peddle does nothing
Not sure. It could be something to do with the foot control, power cord, or the motor. Does the light come on? If so, it's probably not the power cord. If you have access to another foot control and power cord, that is an easy way to test. Otherwise, might be best to take it to a Bernina technician.
Bernina 1006 Parts
Bernina Foot Control Power Cord for 1000 800 Series
http://www.drdanessmh.com/berninaftc.html
Apr 03, 2016 | Bernina Sewing Machines
Bernina Serger Manual
contact bernina customer service about a manual or a bernina dealer
Nov 18, 2013 | Sewing Machines
Bernina 930 foot control cord
Not easily - the plug is molded-on so it's best to get a complete new cord - they're still available.
Feb 02, 2012 | Bernina Sewing Machines
Need manual for bernina serger 1300dc
I have a Bernina Overlocker/serger 1300DC having trouble threading the machine
Sep 23, 2009 | Sewing Machines
I have a Bernina 2000D and it will not sew properly as I have no instruction book
If you visit this company:
http://www.sewingmanuals.com/Sewing_Machine_Manuals/Bernina.htm
Sadly you will have to pay for an instruction manual, leads to a PayPal account.
Please rate this thanks,
Jul 25, 2009 | Bernina Bernette 75
Old model Bernina 830, running ok, then kept running, won't stop. disconnected cord, disconnected foot control, plugged cord into motor, motor runs without foot control. Reconnected foot control, motor...
Jun 25, 2009 | Bernina Sewing Machines
How to i thread my 008d bernina serger?
I believe it is color coded right?
start with the Upper looper follow from the upper looper throught the loops below the machine up through the tension disk and to the place where the thread cone sits. now retrace your steps from the thread to the looper place thread under foot.
by starting from the finishing point to the starting point you know where you are going with the thread when you thread the machine so upper looper lower looper right needle left needle. you must get it exactly correct or it wont work
Jun 21, 2009 | Bernina 1008
Sewing Machines Logo
207 people viewed this question
Top Bernina Sewing Machines Experts
Derek Massey
Page Gettman
Level 1 Expert
Iron
Iron
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
