Question about Philips Standard 104SLE 14 in. CRT Monitor
Monitor distortion I see a line moving slowly up my monitor after regular intervals.
  • 126 Answers
Your monitor has came in contact with some magnetic material remove all the things containing magnetsfrom around it and leave monitor unplugged for 1 day and then start it will work fine
pls rate my suggestion
thankyou for using fixya
have a nice day
Posted on Feb 19, 2009
Aoc led showing a line of faded pixels after regular intervals
i encounter this and found out that the signal from pc is the source of the problem and not the monitor itself mine is failing video graphics card
Jan 26, 2014 | Computers & Internet
The display of my Flatron LCD goes on and off at regular intervals? In the beginning it work great. Screen is less than a year old.
wynand811, You should have the manufacturer replace it under warranty. If unit is still covered by warranty, give a call to LG or whoever made it and complain, complain, complain!!! Don't let them off the hook!!
One thing to try is moving the monitor to a known good pc and connecting your monitor to see if it still has the "on/off/on/off/on/off problem. 12fixlouie
Oct 27, 2009 | Computers & Internet
I'm using this as an additional monitor for a HP 10" netbook and the picture is stretched & distorted & doesn't fill screen. The vertical adjustment just moves the whole thing up and remains...
Solution goes this way, to maintain the aspect ratio of the monitor, take note of this. Your HP 10inch notebook have different resolution compare to your additional monitor, But I'm sure you selected the dual view mode or the duplicate mode that is why you have distorted display on your additional monitor, to let the additional monitor decide and maximize its resolution, try using the extended view option, you can change the resolution of your additional monitor without affecting the resolution of your 10 inch laptop.
Oct 21, 2009 | Acer X183HB Monitor
My screen suddenly gets distorted.
Test your laptop by connecting its video ouput (base of the computer at the back) to a known working monitor. Then power on the laptop and see if the known working monitor behaves the same way your laptop's monitor does. That will narrow down the possible causes.
Apr 06, 2009 | IBM ThinkPad R40 2722 Notebook
Samsum samtron crt 56 v monitor ,got a green shade on picture,but looks good at times
That has been damaged by some magnetic device.
Solution: You need to degauze it. (Refer to manual for specific degauze instructions)
Jan 03, 2009 | SAMTRON 55V 15" CRT Monitor
Diagonal RGB lines
It might just need degaussing. If the monitor is equipped with a degauss button, try pressing it. If not, it might eventually go away with time - sometimes when CRT monitors are moved and change orientations odd color distortions due to magnetic fields result. After a while the magnetic field fades and the colors will be back to normal.
Otherwise, upgrade to an LCD - easier on the eyes, and a lot easier on the back. :)
Jun 11, 2008 | Dell P1130 21" CRT Monitor
Regarding non working of the crt
refresh rate problem or a bad conexion on the video out from utr video card
May 09, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Monitor flickering and adjustment buttons locked
If the refresh rate is not properly set the monitor may have a wavy or an appearance that lines are going down ... This may also cause a flickering affect.
Distorted or skewed image on monitor. Issue: Distorted or skewed image on monitor.
Cause: This issue can occur from any of the below possibilities.
  1. Windows issue.
  2. Loose or defective cable.
  3. Refresh rate issue
  4. Interference.
  5. Bad monitor.
Solution: Windows Issue If your monitor has a proper display until it gets into Windows 3.x, Windows 95, Windows 98, Windows NT, Windows 2000, Windows ME, or Windows XP please see document CH000121 for software or setting related issues.
Loose or defective cable You may receive a distorted image when the cable is loose or defective. Disconnect the video cable going from the back of the computer and verify that no pins are bent, burnt or broken. Once verified re-connect the monitor cable.
Refresh rate issue If the refresh rate is not properly set the monitor may have a wavy or an appearance that lines are going down or across the monitor slowly or fast. This may also cause a flickering affect. Additional information about how to change the refresh rate can be found on document CH000558.
Interference A distorted image can be caused by magnetic or other types of interference. Verify no speakers, fans or other magnetic devices are close to the monitor.
Bad Monitor If the above possibilities have been checked it is likely that the monitor is bad. To verify this it is recommended that the monitor be temporarily disconnected and then connected to another computer. This can be a friends computer, a work computer, and/or a computer at a service center. You can also help verify a defective monitor by connecting another monitor to your computer. Note: Connecting your possibly defective monitor to another computer will in no way harm the other computer.
Good Luck/Please dont for get to Rate.Thank You.
Jan 17, 2008 | Samsung SyncMaster 940N Flat panel Monitor
Distorted graphics and low frame rate with new 3d games
Based on that game list it sounds like the problem is related to hardware T&L(transform and lighting) as the games that cause the problem require T&L and the other games don't require it and their fine. It's a start, also have tried both direct3d and opengl modes? Good Luck
Sep 21, 2007 | Dell Inspiron XPS M1710 Notebook
Computers & Internet Logo
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
