Question about Sanyo 18KS52 Air Conditioner
Sanyo XS2432 A/C just shuts off when ever never a set day or time
I have the unit over 5 years and every now and then it shuts off all diff. days and time.I reset it and it start up find and works ok.Then there are days i reset the unit it runs ok for about a hour or two then shuts off
I have checked the power all is good and the unit if there is a power problom the unit is to restart with out pushing a thing
can you help
  • Kent Guidry
    Kent Guidry May 11, 2010
    Can you tell me what you are doing that resets the unit?
  • 158 Answers
Better replace main PCB board
Posted on May 09, 2009
I had the rear end fixed about two years ago. A noise developed and got worse until it wouldn't move. Having same problem arise due to my 19 year son taking it one day and doing a number on it. Takes
if it is the diff centre , a quick and cheap fix is to get a replacement from the wreckers. Sometimes depending on the diff construction it is better to get the whole diff assembly --housing and all as the fix is just to drop out the whole rear end and fit the replacement unit. Labour time around 4 hours or less.
Jan 09, 2015 | Cars & Trucks
Day time running light moduleheadlight module
canada? each county can have diff. DRL parts (LAWS)
no year, cherokee? that make any answer impossible
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
look it up here.
Feb 09, 2014 | Jeep Grand Cherokee Cars & Trucks
How to set time on the TIMEX t309t
Please follow these instructions:
Setting the Clock
1. Press and hold the 5 Time Set Button until the display begins flashing.
2. Press the 10 Reverse or 14 Forward Button to set the time. Holding a button for a few seconds will advance or reverse the time rapidly. Set the correct AM/PM time, shown by the PM Indicator on the display.
3. After setting the time, press the 15 Enter Button or wait about ten seconds for the unit to beep twice and the display to return to the normal mode.
Setting the Calendar
1. It is important to set the correct date in order to use the 7-5-2 Alarm settings. Press and hold the 6 Date Set/7-5-2 Button until the display flashes and the year replaces the month/day at the bottom of the display.
2. Press the 10 Reverse or 14 Forward Button to set the correct year, and then press the 15 Enter Button. The unit will beep and the display will show the month and day. Again, press the 10 Reverse or 14 Forward Button to set the current date.
3. After setting the date, press the 15 Enter Button or wait ten seconds to return to the normal display mode.
I hope I could help.
Thanks
Nov 26, 2011 | Timex T309TT Clock Radio
3 YEAR OLD SANYO DP 32746. SHUT ITSELF OFF, CAN NOT TURN BACK ON
If you leave the tv unplugged for 2 days (atleast) then plug it back in and try to turn it on and if it comes on its the power supply board. If it comes back on it will probably shut off between 30min to 4hrs and you would have to unplug it for 2 days again. All the power needs to drain out of the tv. If thats the case take the back pannel off and check the part number out on the internet. Not hard to do becarefull touching things the power supply does store a little bit or shock in it. Good Luck.
Dec 13, 2009 | Sanyo DP32746 32 in. LCD Television
I have a Kenmore Refrigerator that a friend just gave me that is about 5 years old in good condition. On the move we didn't lay it on it's back, but of course it was tilted back at times. Transported it...
How long have you let the unit run? Sometimes if you leaned it back too far you need time for the oil in the compressor to recess..to go back into the compressor. It normally takes a refrigerator 24 hrs. to cool but also up to 72 hrs. if after three days of continous run and not cool at all then you have a restriction in the system, in this case oil in the lines or a stopped up liquid line dryer. It's a filter for moisture and impurities in the closed system. Otherwise give it time to cool without putting the settings all the wayup. Put them on the factory settings usually in the middle of both knobs or whatever you have for adjusting the coolness. Overheating the compressor will not cool the unit and you might try shutting the unit down for a day and then resume again the next day at middle or lower settings. Make sure never to lay a refrigerator over on it's side! The life of a refrigerator should be up!
Randy
A.I.R. Appliances
San Antonio, Tx. 78209
210-822-1818/210-493-2700,cell 210-264-1471
Feb 24, 2009 | Kenmore 53642 / 53644 Side by Side...
How do I set the Prerecorded Greeting?
Press delete while reviewing your announcement.The system will use the prerecorded message until you record a new one.
Setting the Clock
NOTE: A flashing
"CL"
in the message window indicates that you must set the correct
day and time at the base unit.
1.
Press the TIME button. The system announces the time and day of the week,
followed by
"To set day and time, press TIME/SET."
2.Press the TIME
button. The system announces the day.
3.Press the CHANGE
button repeatedly until the system announces the correct day.
4.Press the
TIME
button to save the new setting. The system announces the setting.
5.Press the
CHANGE
button repeatedly until the system announces the correct hour.
NOTE: Be sure to select the correct time of day (e.g., 3 AM or 3 PM).
6.Press the
TIME
nnounces the minute.
7.Press
CHANGE
to advance the minutes one at a time. ­OR­ Press and hold the
CHANGE
button to advance the minutes in increments of 10.
8.Press the
TIME
button to save the new setting. The system announces the year.
9.Press CHANGE
to advance the year one at a time. ­OR­ Press and hold
CHANGE to advance the years in increments of 10. When the system announces the correct
year, press TIME
. The system announces the clock setting
Aug 12, 2008 | Motorola Mobility E51 MD7161-2 Twin...
Pro Star DCS 24 B
SYSTEM ADMINISTRATOR
PROGRAMMING
SET DATE AND TIME DISPLAY Should it become necessary to correct the date and time displayed on all of the keysets, due of time change (twice a year), you must first access the customer programs.
To access customer programs, open system programming using the passcode you have been assigned. (Default passcode is 1234). You must use a (display phone) LCD 12B or LCD 24B keyset. ENABLE CUSTOMER PROGRAMMING topbul1a.gif While on-hook, press TRSF and dial 200. he display shows. ENABLE CUS. PROG.
PASSCODE
: topbul1a.gif Dial the four digit passcode. The display shows: ENABLE CUS. PROG.
DISABLE
topbul1a.gif Dial 1 or press the ▲ on the Volume to enable. The display shows: ENABLE CUS. PROG.
ENABLE
topbul1a.gif Press TRSF. The keyset returns to its idle condition.
The display format is the following:
W (Day of the week): Enter 0 for Sunday and 6 for Saturday.
MM (Month): Enter 01 for January and 12 for December.
DD (Day of the month): Enter a number in the range of 01-31
YY (Year): Enter the last two digits of the year.
HH (Hours): Use the 24 hour clock and enter a number in the range of 00-24.
MM (Minutes): Enter a number in the range of 00-59.
SETTING THE DATE AND TIME 1. Press TRSF and then dial the 505. The display shows: OLD: 1102802:0852
NEW: WMMDDYY:HHMM
2. Enter the new time and date using the above format: OLD: 1102802:0852
NEW: 1102802:0752
3. Verify the time and date and reenter them if necessary OLD: 1102802:0752
NEW: WMMDDYY:HHMM
4. Press TRSF to store and exit programming.
If you have entered invalid data, you will receive an [INVALID ENTRY] message for three seconds. Reenter the correct date and time. If the information you entered is incorrect, repeat steps 1 through 4.
Aug 04, 2008 | Samsung Prostar DCS Phone
I get CL blinking on the base
A flashing “CL” in the message window indicates that you must set the correct
1. Press the TIME button. The system announces the time and day of the week,
followed by "To set day and time, press TIME/SET."
2. Press the TIME button. The system announces the day.
3. Press the CHANGE button repeatedly until the system announces the correct day.
4. Press the TIME button to save the new setting. The system announces the setting.
5. Press the CHANGE button repeatedly until the system announces the correct hour.
6. Press the TIME button to save the new setting. The system announces the minute.
7. Press CHANGE to advance the minutes one at a time. –OR– Press and hold the
CHANGE button to advance the minutes in increments of 10.
8. Press the TIME button to save the new setting. The system announces the year.
9. Press CHANGE to advance the year one at a time. –OR– Press and hold CHANGE to advance the years in increments of 10. When the system announces the correct
year, press TIME. The system announces the clock setting.
Mar 24, 2008 | Motorola Mobility E51 MD7161-3 Quad...
Setting the Clock
1.In the stop mode, press and hold down the MENU/STOP button for at least 2 seconds
The menu setting display appears.
2. Press the SKIP/SEARCH button repeatedly to select dAtE
3. Press the POWER/PLAY button.
The year display blinks
4. Press the SKIP/SEARCH button repeatedly to select the year. Then press the POWER/PLAY button. The month display blinks.
5. Repeat the same step 4 to set the month, day, hour display ("24 H or "12H") hour and minute. Note: "second" cannot be selected.
When the minute setting is completed, "dAtE" returns.
6. Press the MENU/STOP button.
Nov 01, 2007 | Sanyo ICR-B60 Digital Voice Recorder
Sanyo 18KS52 Air Conditioner Logo
229 people viewed this question
Top Sanyo Heating & Cooling Experts
Donni Steen
Dennis Boxerman
Tim Whalen
Are you a Sanyo Heating and Cooling Expert? Answer questions, earn points and help others
