Question about RCA DVR-40 DirecTV DTV Receiver / 35-Hours Video Recorder
Fan runs, no panel lights, no response to remote
Tried new remote
Replaced the older receiver box and had Directv reactivate the card. Will probably find another one later.
Posted on Feb 20, 2009
Model 28870-420 ceiling fan. Why don't lights respond to remote or pull switch and motor just hums?
Your fan may have to be "reset" to restore light response. Turn off power at the source, not at the fan. Wait for a few minutes while you remove remote batteries and press all buttons to eliminate a "stuck key" problem. Reinstall batteries, then turn on power again. Try using the remote to turn on lights. If no luck, the remote may need new batteries or the receiver could be defective.
The motor hum could be caused by a broken capacitor connection or defective capacitor at the motor.
Dec 22, 2015 | Hunter Dryers
Non responsive light or fan
Oh, that fan problem. Just for luck, remove the batteries from the remote and press all of the buttons to eliminate a stuck button as a possibility. Next, go to the source of fan power (breaker or fuse) and turn it off. Do not mess with any switches or pull chains. Turn on the fan power and try the remote. Make note of this procedure because you will have to repeat it whenever you have a power outage or you mess with the switches or pull chains trying to solve the problem
Apr 25, 2013 | Casa Vieja Probe Brushed Nickel Ceiling...
Ceiling fan and light
First replace batteries in remote, go to breaker switch and see if power is going to fan,turn off and turn back on,then try,if it still doesn't work,turn power off at breaker,then remove fan to get to wires and check to see if power isgoing to fan,if it is then fan switch is bad.
Dec 23, 2012 | Dryers
My Hunter remote controlled fan worked great for the first few years, but now the the light comes on and the fan turns off at the same time without me touching the remote or the switch on the wall. Wakes...
Sorry to read about your problem, I hope this helps you out.
you may have a defective remote reciver or even a bad remote.
Take the battery's out of the remote for a couple of days, if the fan turns on, the remote is good.
you can have the remote receiver replaced, they run around $60.00
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 29, 2010 | Hunter 52" Ceiling Fan With Light And...
I have a hampton bay ceiling fan/light and the remote came with it. The remote model is: UC7083T. The battery died and when I installed a new battery, the remote willnot connect with the fan/light. Any...
try turning off the switch/circuit breaker at the main lighting panel. Then just turn it back on. Worked for me.
I'm guessing a capacitor in the remote is holding a charge and causing the problem. You'll probably need a new remote soon thiough.
Nov 27, 2010 | Universal Remote Control Hampton Bay...
Infocus 250 will not turn on at all.
The power button is solid green? try to turn on whit the remote control. Try to clean the surface on the Main board, uder the contro panel.
May 31, 2010 | InFocus LP 240 Multimedia Projector
Fan remote doesnt work
you eighter A clean the red eye or B get the code or C get a new remote!
May 11, 2009 | Hampton Bay 52 In.Carriage House II in...
Fan and dimmer remote does not work
The remote is a Hampton Bay remote that should dim the light and fan on and off. I replaced the battery and do not have a red light when I press the button. Light and fan does not turn off with remote.
Mar 01, 2009 | Universal Remote Control Hampton Bay...
Ceiling fan remotes
If you know where the remote receiver is located on the fan (probably in the canopy or the compartment where a light kit would attach), you may want to see if you can find the wire antenna that is hanging off of it. If possible, run that wire outside the canopy so it is exposed, this might give you a better response.
Dec 23, 2008 | Hunter 52" Ceiling Fan With Light And...
RCA DVR-40 DirecTV DTV Receiver / 35-Hours Video Recorder Logo
359 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
