Question about Kenmore Elite HE4 Electric Dryer
Sears elite he dryer stopped working
There is power i.e. drum light and control panel lights on. won't start.
did diagnostics according to tech manual. motor swith is good. not sure about resistance tests on switch.. colored wires in manual did not match with unit. Click in electronic control panal when start button is pushed button nothing after.
    President:
  • 1,902 Answers
Bad control panel. Replace the control panel at repairclinic.com. When your control panel clicks like that it means that a resistor or solder joint has gone bad and it is cheaper and easier to just replace the board
Posted on Feb 19, 2009
Why won't it start?
Free Kenmore Clothes Dryer User Manuals ' ManualsOnline ...
laundry.manualsonline.com > ... > Laundry Appliance Kenmore
Products 1 - 50 of 65 - Kenmore ELITE HE3 Gas Dryer User's Guide 110.9787 9789. Pages: 0 ... Kenmore 27-Inch Wide Electric Dryer Owners Manual. Pages: 0 ...
Whirlpool & Kenmore Dryer Repair #02 - Won't Start or Run ...? 7:29https://www.youtube.com/watch?v=SPRqKVE8JfYOct 21, 2011 - Uploaded by canyonman1963... and repair a Whirlpool or Kenmore electric dryer that will not start or run. ..... I have a Kenmore Elite Oasis ST Dryer, model number 110.78082701. During ... Dryer Troubleshooting - NotDrying or Taking a Long Time to Dry ...How to take apart Kenmore Elite Dryer - YouTube? 6:28https://www.youtube.com/watch?v=QNa6zfzrm5kOct 16, 2012 - Uploaded by RenewApplianceI have a kenmore elite 79661423410 electric dryer stoppedworking manual says has no thermal fuse and I can't take it apart help thank you.
Dec 12, 2015 | Kenmore HE5 Electric Dryer
My Kenmore Elite dryer keeps beeping..just going through the end of cycle alarm-high,low,off...anyone have any suggestions. Now no panel lights, drum light on with door open, off when closed.
it sounds like you have a bad computer board.every time i saw a dryer that beeps on it's own it was a bad board and now you say you have no lights.most likely it's the board.there should be a tech sheet that will tell you how to get the machine into diagnostics,also you can try to unplug it for like 15 minutes and plug it back in,sometimes it will reset the board just like a house computer but if you have no lights it might not reset.remove the bottom panel the tech sheet should be taped to the back of it or in that area.
Oct 16, 2013 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Electric Dryer -- Diagnostic for electronic control "Start" touchpad is 09. What does it mean?
i donot know what 9is but i think its the moter switch or moter try switch first
Jul 19, 2013 | Kenmore Dryers
My Sears Kenmore Elite dryer stopped working in the middle of a drying cycle. The drum light is still works - so it has power. But when I press the Start button, I just hear a faint clicking sound. Any...
Most common cause is a partially or fully clogged dryer exhaust vent makes the dryer overheat and trips the high temp limit fuse. Brush out the vent all the way to the outside.
Feb 20, 2011 | Kenmore Dryers
Kenmore Elite Electric Dryer, Model # 110.8586400, Control Panel Lights inoperative, But Drum Light works fine. I am going to try this procedure, Will let you know if it works. Jay/ Jacksonville Florida...
I followed that procedure, Taking the Electronic Control Unit out of the dryer, Blow Drying the printed circuit Board (PCB) Board out and reseating P3 and P4, Worked fine.. No moisture was found in the Drum area. I forgot to tag the TECH SHEET FOR this particular dryer . But punch in Tech sheet , Part # 8546206 into google, this gives Schematic and valuable Troubleshooting steps, The only thing i could not find was the pin to pin test on chekcing the individual switches on the main functions, Suppose to be 14 pins I only found 13. But in all drying the PCB board and reseating the plugs worked for me. Again the symptons were no Light indication on ANY button depressed but the drum light was on. Great Site, Not a first time user
Dec 04, 2009 | Kenmore Elite HE4 Electric Dryer
4E problem on kenmore dryer
Same problem, no panel lights, nothing, but drum light works. Several postings on othe sites say the cuicuitry board is faulty. Sears, in the Phillippines, or India, do notheing. Paid lots for this dryer, live alone and really don't abuse it or even use it that much. Is the there a class action suit maybe? all I want is for it to work!
Aug 20, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Oasis Electric Dryer
i have the same problem only the drum light will come on i opened up the top console and found the tech sheet and after going thru the tech sheet with a multi-meter according to the results i will need to replace the user interface assembly, p/n 3407184. you too may have the same problem.
Jan 07, 2008 | Kenmore 67082 Electric Dryer
Not starting 1 yr old kenmore elite smartheat quietpak9 HE4
SEE VIDEO
http://www.youtube.com/watch?v=tq3k22cqjR8
Control panel moisture 9/10 times.... or check the fuse under the lower front panel ($12 sears)
Nov 28, 2006 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
210 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
