Question about Baby Gear
Driver seat wont recline,how do i fix it without setting airbag
54 Plate 2005 Mk 2 clio
My driver seat wont recliner and renault want £500 to fix it (trying to rip me off i think), they said it needs to whole new back but they have tried to over charge me before so i dont really trust what they are saying.
I want to try and fix it myself but how can i strip down the seat without setting off the driver seat side airbag?
please help!!
SOURCE: renault clio airbag in seat
i hit the kirb in my clio and the airbag passanger side in the seat went off. also had a bit of trouble with it starting a few wks before. it wouldnt start then 2 -3 hrs later would ??? any simmilaritys scared the living daylights out of me
Posted on Sep 09, 2008
  • 566 Answers
SOURCE: drivers side seat not working properly
hi this sounds like the coiled spring that is enclosed behind the cover where the recline lever is it has either broken or the pin it locates on has snapped or spring has for some reason slipped its fastening ? try removing cover and investigate the spring and its locator points
Posted on Dec 29, 2008
warlock61
  • 659 Answers
SOURCE: 97 Ford Explorer - Driver Seat Repair- 2 Dr V6 SOHC
you can replace the recline lever assy without removing the seat
Posted on Jan 17, 2009
SOURCE: 2002 nissan maxima driver power seat will not incline
its not the motor its the switch to the seat...it happ. to me b4.
Posted on Mar 19, 2009
  • 223 Answers
SOURCE: My driver side power seat will not move forward or
hello dschlig, most common for these seats are the motors. I would recommend raising the seat as high as possible. While trying to activate the seat in the forward/back positions, see if you hear or feel a clicking in the motor under the seat. The motor can be recognized closest to the carpet, and has 2 rods going to each seat track. If the motor clicks, inspect the connector and make sure nothing dislodged it. If it is ok, you can use a small hammer and an extension and lightly tap the motor to see if it will maybe release. If you know how to use a volt-meter, you can also check for power to the motor connector when sliding the switch in either direction. The motor can be replaced seperately.
Posted on Apr 20, 2009
Ford 2008 expedition, power drivers seat won't recline, but everything else works.
Power Recliner
The driver seat has an electro-mechanical backrest adjuster. The backrest adjustment switch is located on the side of the seat cushion side shield and is part of the seat control switch. The recliner motor is mounted to the backrest frame. Power recliners and motors are only serviceable by installing a new backrest frame assembly.
Does yours have Driver and Passenger Power Seats Without Memory Or Power Driver Seat With Memory ?
B1666 Seat Driver Recline Motor Stalled On-Demand If the motor does not operate, Go To Pinpoint Test L . If motor operates, Go To Pinpoint Test M . Take it an have it check !
Does your
May 15, 2016 | Ford Cars & Trucks
My 2003 c320 drivers seat blows fuse when headrest,recline or memory buttons pushed. Does not blow when forward/rear slide adjust used. Any ideas??
sounds like you have trapped/chaffed wiring under seat or around seat recline hinge, remove seat and have a close look at the wiring. disconnect battery first because airbags in seat and seat belt pretensioners i think are fitted to this car. good look
Sep 12, 2015 | Mercedes C-Class Exterior Pillar Posts...
Memory seat does not fully recline
Sounds like you lost basic settings for the seat. Recline the seat all the way forward and all the way back a couple of times. That should reset the settings and work properly
Dec 09, 2013 | Volkswagen Cars & Trucks
The six way power seat on my 2005 suburban has an issue. When I turn the motor off and remove the key the motor goes to it's down and back position but continues to run. And it doesn't respond to the...
The first place to start would be to have the dealer or someother qualified repair shop , that has a professional scan tool read DTC'S - diagnostic trouble codes in the driver seat module ! The seat adjuster motors are controlled by the driver seat module through the adjuster motor control circuits. In an inactive state both of the motor control circuits are grounded within the driver seat module. In an active state the driver seat module switches the appropriate motor control circuit to battery positive voltage. The direction of the adjuster motor rotation is determined by which of the motor control circuits is switched to battery positive voltage while the other remains grounded. During adjuster motor operation the driver seat module also monitors the current flow through the motor control circuits.
DTC B1770, B1775, B1780, B1785, B1790, B1805, or B2415
B1825 , B1850, B1860, B1960, B2355, B2365, or B2375
B3962
Memory Seat System Components
The memory seat system consists of the following components:
• Power seat switch assembly
• Memory recall switch assembly
• Horizontal adjuster motor
• Front vertical adjuster motor
• Rear vertical adjuster motor
• Recline adjuster motor
• Driver seat module
• Driver door module
• SEAT 30A circuit breaker
Memory Seat System Description
Battery voltage is supplied to the driver seat module through the power seat circuit breaker. The driver seat module supplies the seat adjuster switch assembly with a battery positive reference voltage. While the seat adjuster switches are in an inactive state the switch contacts are closed to the adjuster switch ground circuit. When a seat adjuster switch is pressed to an active state the switch contact is closed to the reference voltage circuit. Battery voltage on a switch signal circuit indicates to the driver seat module the switch status is active. Each seat adjuster motor is controlled by the driver seat module through 2 motor control circuits. While the seat adjuster motors are in an inactive state the motor control circuits are closed to ground circuit contacts within the driver seat module. The driver seat module operates the seat adjuster motors by switching one of a motor's control circuits to battery voltage. The seat adjuster motors are bidirectional and the direction of adjuster motor rotation is determined by which of the adjuster motor control circuits is switched to battery voltage while the other remains grounded.
Memory Set/Recall Operation
The seat adjuster motors are equipped with internal position sensors. The adjuster motor position sensors are monitored by the driver seat module and are used to determine the seat position when storing or recalling memory settings. The horizontal, front vertical, and rear vertical adjuster motors use hall effect type position sensors. The hall effect position sensors are supplied with battery positive reference and ground circuits from the driver seat module. The position sensor signal circuits are supplied battery positive voltage through a resistor them monitored within the driver seat module. During adjuster motor operation the hall effect position sensor provides a single pulse for every revolution of the adjuster motor shaft. The driver seat module counts the pulses from the position sensor signal circuits to determine the adjuster motor positions when storing or recalling memory seat position settings. The recline adjuster motor is equipped with a potentiometer type position sensor. The recline motor position sensor is supplied with it's own 5-volt reference ground circuits from the driver seat module. The recline position sensor signal circuit is referenced from ground within the driver seat module. The signal voltage monitored by the driver seat module ranges from 0.39 - 4.58 volts and is determined by the wiper location on the resistor within the recline motor position sensor. The recline motor position sensor signal circuit voltage level is used by the driver seat module to determine the seat recline position when storing or recalling memory seat position settings.
The memory recall switch assembly on the driver's door provides inputs to the driver door module. Battery voltage is supplied to the memory
Feb 06, 2018 | Chevrolet Suburban Cars & Trucks
The passenger front seat will not recline - how can I fix
2010 Equinox drivers side won't recline.
Found the cable popped off recline mechanism.
Pulled back the lower seat panel near the recline lever after removing one torque screw located on said panel which is on the back of seat. Works great now. By the way, Freedom Chevrolet in San Antonio, Tx, without diagnosis, wanted to charge my girl friend $860 to replace the whole assembly.
Feb 10, 2010 | 2005 Chevrolet Equinox
Removing seat fitted with airbag from a 2001 Renault Clio
It is best that you disconnect the negative battery terminal while disconnecting & removing or reinstalling the seat.
Be sure to ground yourself by touching metal when going to unplug any harness in a computer controlled vehicle to prevent static discharge. (the airbag is connected throught the harness you are removing and any spark that would hit that wire, could trigger the airbag to deploy)
good luck
Jan 30, 2010 | 2005 Renault R5
Jan 16, 2009 | 1999 Ford Explorer
2005 Chrysler Pacifica Seat motor replacement
it the recline motor , motor 75.00 it not hard to do
Oct 06, 2008 | 2005 Chrysler Pacifica
Service- Airbag
That means that a problem occurred with the airbag.
Jun 18, 2008 | 2000 Renault 181
Baby Gear Logo
328 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
