Question about Philips Magnavox 27MS343S 27" TV
Tv wont turn on
I have a magnavox tv a 50 inich model #50mf231d/37 i was watching tv and all of a suddenly it turn off almost like a power surge but i have it pluged into a surge protecter and now only the tv wont turn back on. Everything else is working and turning on again except the tv.
Switch off the surge protector for 2-3 minutes then switch back on and TV should work.
Posted on Jul 08, 2009
Magnavox 37MF321D/37. suddenly just shut off and would not turn back on, no blinking green light nothing!
Price the board first and then decide, I fix these in our shop but do not like or enjoy working on them at all.
Dec 20, 2012 | Toymax Magnavox 37MF231D 37 in. LCD TV
My magnavox model 50MF23ID/37 is 4yr old. tv wont
If you hear a clicking noise that sounds like the ballast trying to power on the lamp, but nothing happens, the lamp may be faulty.
http://www.discount-merchant.com/
Here you can get your lamp that most likely needs replacing.
Mar 26, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Magnavox plazma 50 inch flat screen wont turn on
Power supply board is dead.Replaced the power supply board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 08, 2010 | Televison & Video
We have a Magnavox, 50 inch plasma TV, model 50MF231D/37. Recently when the TV is powered off and an attempt to power it back on again has been made, we get a red blinking light. The light blinks six...
Your problem is caused by a power supply issue it sounds like a capacitor is leaking or has vented and will need to be replaced if your comfortable you could check the power board for a can shaped electroletic cap that has vented it will be puffed up on the top the value is printed on the side you can or have someone replace it that should take care of your problem the power board is the one where the AC cord plugs to or leads to
Dec 10, 2009 | Televison & Video
I have 50 in plasma phillips magnavox 50mf231d-37, will not come on red light flahses 4 times
this is some info that some one else had found
get a memory stick( flash drive) and up load their soft ware from their site. I plug the stick into the computor and uploaded the software. I then plugged the stick into my TV on the side. A screen came up and the software loaded on the TV successfully. The red light then turned to green. However, I now have to unplug and plug the TV several times for it to turn on. It works fine but once the TV is turns on, but when I turn it off and it cools for a while I have to repeat the same proceedure off plugging and unplugging
Jul 12, 2009 | Philips Magnavox 27MS343S 27" TV
Magnavox 50mf231d/37 plasma has vertical line on right side, apx 1/3 from end. line is from top to bottom. fivedtv@fairpoint.net
See if the vertical line appears when you press the "Menu" button on the Magnavox. Also, see if the line appears when you watch a dvd on the maganavox. If it does not appear, then the problem is the cable wire or cable/satellite box. You can reset the cable box and the TV by powering them both off, and leaving them unplugged for 20-30 seconds, and then replugging. See if that works.
Apr 16, 2008 | Televison & Video
Remote suddenly desn't work
you may have accidentally pressed one of the wrong button at the bottom of the remote control. the codes are in the back of the user manual
Oct 19, 2007 | Philips 50MF231D 50 in. Plasma Television
Philips Magnavox 27MS343S 27" TV Logo
750 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
