Question about Keurig B50 Coffee Maker
Piece broken The piece where the hot water concentrate before to fall in a cup is broken. We take a picture. If we don't use this piece, the hot water go every where. It' like a funnel and it's black. We take a picture.
    Problem Solver:
  • 25 Answers
This is the cup assembly.
Posted on May 14, 2009
Saeco grinder
Maybe the piece that direct cofee to brew group it is missing, so all cofee fall down.
Oct 04, 2013 | Coffee Makers & Espresso Machines
Broken water pump bypass hose for a 2002 buick park ave
You will have to remove the belt, altenator and the tensioner bracket. The piece of plastic will be in its bore I've never had one fall in the engine.
Oct 12, 2012 | 2002 Buick Park Avenue
The rubber nose piecce is broken, can it be replaced and where can I get it at area code 33436
Usually with stuff like that they are too small too fix. Your best bet is to find someone around you that has the tools to put it back on or to replace the actual piece. Or can try asking at glasses stores to see if that could fix it, but if you don't have the piece it could be difficult. If you don't have the piece then you should just replace the glasses because it is hard to find the same exact piece. Also if these glasses are prone to having that particular piece fall of you should invest in different glasses.
Jun 21, 2011 | Adidas A152 Sunglasses
The "funnel" piece underthe cup
Here is a tip that I wrote about how and where to get replacement parts foryour Keurig Coffee Brewer
Keurig CoffeeBrewer Replacement Parts
heatman101
May 18, 2011 | Keurig B66 3-Cup Coffee Maker
The clean light is blinking and beeping. There is less than 2 cups of Vingegar still in the water reserve.
Sounds likea serious PIECE. Try running it on the regular mode with vinegar, or you could even use hot water.
Jan 22, 2011 | Mr. Coffee 072179228578 12 Cup Coffee...
Garmin Nuvi - rubber piece that sticks to windshield stayed
you can use sellys contact cement or a rubber cement used to reole shoes to reattactch to the plastic piece. Just dont over stick the cup keep it concentrated towards the centre.
Please rate my help++++Thanks for using FIXYA
Dec 06, 2009 | GPS
The place where u place the soap won't let all the soap out why
hello. i can help you.
When the detergent cup doesn't open, check these:
Timer
Bi-metal switch or wax motor
Detergent cup, itself
Timer On many dishwashers, a plastic actuator arm mechanically links the timer to the detergent cup. When the timer reaches the proper time in the cycle, the timer activates a lever that opens the detergent cup. If the linkage is broken or defective, the cup stays closed after you've closed it. Check the link and repair or replace it, as necessary.
Bi-metal switch or wax motor A bi-metal switch is a simple electrical device that deforms when electricity is applied to it. The degree of this deformation can be engineered to concise standards.
The timer energizes the bi-metal switch inside your dishwasher door--directly behind the detergent cup--when the detergent cup should open. When energized, the bi-metal switch deforms away from the detergent cup latch, which opens the detergent cup. If the bi-metal switch is defective, it may not deform enough to open the cup. If that happens, you need to replace it.
On some dishwashers, the bimetal switch is wired through the heating element or motor circuit. If the element is broken (or open), or if the motor is drawing low current because of a low-fill situation, the bi-metal switch doesn't open properly.
Newer dishwasher models use a wax motor instead of a bi-metal switch. It's a sealed unit with wax that heats up and pushes a piston through to open the door. The wax motor, controlled by the timer, mechanically opens the door.
Detergent cup, itself The detergent cup itself can become clogged with old dried detergent that prevents it from opening. Sometimes just cleaning the cup takes care of the problem. If not, you probably need to replace the entire cup assembly
The cycles times are too long If your dishwasher's cycle times are too long, check these:
Water pre-heating
Cycle not completing
Water pre-heating Your dishwasher may pre-heat the water. If so, and if the water entering the dishwasher is cool, the heater may take up to half an hour to heat the water.
To avoid the wait, increase the incoming water temperature before turning on the dishwasher. Do that by running the kitchen sink faucet until the water runs hot. Or increase the temperature of the hot water to the entire house at the hot water heater.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Cycle not completing See "The cycle doesn't complete" section.
Jul 05, 2009 | Electrolux Kenmore 24 in. Built-In...
Making hot chocolate in regal 36 cup coffee maker
I've never done that myself but I have seen it done at a school function when my children were younger. If you make sure to rinse the valve thoroughly after you empty the urn, what problems could it cause?
Feb 12, 2009 | Regal Ware K6725 Kitchen Pro Bread Maker
Keurig B50 Coffee Maker Logo
263 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
