Question about HP LaserJet 3055 All-In-One Printer
HP Laserjet 3055 continues to show "no paper pickup"........have removed cartridge, no jam or pieces of paper.....turned off to reset, then on.....same no paper pickup message appears..
Thish is paper sencer problem & change the paper sencer.
Posted on Feb 22, 2009
Paper jam in hp 3055
Remove the cartridge check paper jam, remove re install cartridge..
Sep 07, 2011 | HP LaserJet 3055 All-In-One Printer
No paper pickup, press enter
Suspect worn and or dirty paper pickup roller. To check the roller simply open top cover and remove toner cartridge. Roller is D shaped and can easily be removed by gently pressing the two tabs outwards. This should pop out the roller from the holder. Clean roller and check for wear. If worn replace.
Feb 23, 2010 | HP LaserJet 3055 All-In-One Printer
Adf jam hp laserjet 3055
Here is a link to view or download the Service/Repair Manual. It details how to tear the whole thing apart if you need to.
Laserjet 3055
Sep 17, 2009 | HP LaserJet 3055 All-In-One Printer
Documnet feeder jam
Check input paper feeder at top too - easy to miss. Top flips open with a firm (but not excessive) pull, so you can look there.
If you are sure you've opened and looked under every available panel on the printer (there are many!), turn it off and unplug for half a minute. Make sure all panels are back properly in place, but leave out the paper tray (and no paper either in the rear input paper feeder).
Plug in and turn on. Wait for it to finish its start-up sequence - it should complain about no paper.
Check the paper is flat and straight in the paper tray, and no excess room between paper and guides, and put it in again.
Print test page.
How is it now?
Sep 15, 2009 | HP LaserJet 3055 All-In-One Printer
When trying to copy papers do not feed but if you scan they will
HP LaserJet 3050z, 3050 All-in-one, 3052, 3055, 3390 and 3392 versatile printer - Error reported: Document Feeder Jam ISSUE: How to correct the HP LaserJet 3050z, 3050 All-In-One, 3052, 3055, 3390 and 3392 versatile printer if this error is reported: Document Feeder Jam SOLUTION:
  • Clear the jammed media from ADF (HP LaserJet 3050, 3050z).
  2. Remove any jammed media with care.Take out the page gently. NOTE: Take care not to tear the paper. c01075162.gif
  3. Close the ADF cover plate.
  • Clear the jammed media from ADF (HP LaserJet 3390, 3392, 3052 and 3055).
  1. Open the ADF cover plate. NOTE: Check whether all packaging straps inside the ADF are removed. c01075163.gif
  2. Unload the jam clearance component.Lift the two handles with both hands until the component clutch is released.Rotate and lift the jam clearance component, and then put it aside. c01075164.gif
  3. Lift the green handle, and rotate the paper picker until it is opened. c01075165.gif
  4. Gently remove the page without tearing it.If you feel resistance, go to the next step. c01075166.gif
  5. Open the ADF cover plate, and loosen the media gently with both hands. c01075167.gif
  6. When the media are stopped, pull the media out gently along the shown direction. c01075168.gif
  7. Close the cover plate of the flat scanner (HP LaserJet 3390, 3392, 3052, 3055). c01075169.gif
  9. Insert the jam clearance component to reinstall it.Press the two reeds until the component is properly engaged.Install the clearance component correctly. Otherwise, paper jams will continue to occur. c01075171.gif
Have a good day
Jun 22, 2009 | HP LaserJet 3055 All-In-One Printer
Doc. feeder jam, after paper removed completely
HP LaserJet 3030 All-In-One Printer
Mar 11, 2009 | HP LaserJet 3030 All-In-One Printer
Paper Jam - ADF
Open ADF cover
Lift up Pickup roller Assy
remove spring from pickup roller assy
Remove pickup roller assy gently pull it towards you
Carefully remove green plastic diverter
note this is held in place by 4 plastic pins 2 on each side
look in the opening for foreign objects.
( I have found labels, money, paperclips, plastic pieces,jammed paper in this area)
Aug 20, 2008 | HP LaserJet 3055 All-In-One Printer
No Paper Pickup
turnoff the printer n reseat the tomer catridge properly ,take care it should not be tilted on side,check it that it seated properly,power on the printer n check ,can u hear any motors moving sound,if yes check the printer now,if not check for any peice of paper inside the printer especially from where the paper comes out
do revert
thnx
Jan 25, 2008 | HP LaserJet 3055 All-In-One Printer
No paper pickup
Hi , I just had a same problem with the HP Laser Jet 3055 printer at our office but I fixed it! try this:
Turn off the printer.
Open the printer door.
Remove the Cartridge.
Look down behind the cartridge, there's a small white roll. Try playing with it. move it back and forth. try emptying the paper tray and place it back in the printer.
Turn on the printer.
I did this and for some reason it worked! GOOD LUCK!
Jan 22, 2008 | HP LaserJet 3055 All-In-One Printer
HP LaserJet 3055 All-In-One Printer Logo
595 people viewed this question
Ben Johnson
