Question about Maytag Neptune MAH5500B Front Load Washer
WON'T SPIN OUT. 4 SERVICE CALLS SO FAR
I AM HAVING SIMILAR TROUBLE. 4 SERVICE CALLS SO FAR. #1 DETERMINED A BAD DOOR LOCK. #2 PUT IT NEW DOOR LOCK, NOPE MUST BE CIRCUIT BOARD BEHIND CONTROL PANESL. #3 PUT IT BAD CIRCUIT BOARD. WORKED FOR 6 DAYS THEN BACK TO SAME THING. #4 DETERMINED TO BE BAD CIRCUIT BOARD AND MOTOR AT BOTTOM. I SAID I'D THINK ABOUT IT. PROBLEM, WON'T SPIN OUT. WAS OCCAISIONAL AT FIRST, NOW CONSTANT.
  • 2 more comments
  • gregb672 Feb 19, 2009
    This is my first time on this board. Assuming I can get a # from the old part, can I safely find a new part on this site?
  • gregb672 Feb 21, 2009
    Only board in bottom of machine has a large heat sink on it and no burned spots. Further analysis - seems to wash fine till final spin out then cycles back and forth between 8 and 9 minutes on control panel till I shut it off.
  • MtnMike Feb 23, 2009
    I have the same problem...Wash cycle works fine. When the washer gets to the spin cycle it starts to spin up but then stops. When the door unlocks, there is water left in the drum. This happens occasionally but is getting more frequent. The first service technician to look at it couldn't find a problem since it was a random problem but stilled charge $100 fee to look at it....
    I'm wondering if it could be a loose belt causing the problem since the belt came off once when I was having this problem.
  • Anonymous Feb 23, 2009
    Same issue, won't spin out, stays stuck on 1 Minute remaining until we shut it off. Water drains out fine, but it will not run the final spin.
My washer is a maytag neptune and it went through all the cylcle but when it got to the spin cycle it would start to spin then go to 0 and not spin read a soution on here and it fixed the problem thank u soooo much
Posted on Jun 21, 2011
    Scholar:
  • 79 Answers
Does the machine start to ramp up, stop, then tumble, and repeat this cycle during the spin cycle? If so, there is an open in the balance circuit. See the wiring diagram located in the console. The earlier Neptunes have blue wires going to the balance & inertia switches. You could have a loose wire or a flakey inertia switch. You can bypass each switch with a jumper and see if the problem goes away with that switch bypassed or you could try to use an ohmmeter with a continuity beep function and listen for breaks in the beeps when you tap on each inertia switch.
See www.neptunehelpsong.com for a cute song that explains the Q6 R11 door latch wax motor failure on all of the MAH3000, MAH4000, MAH5500A and the 2000 stackers.
Posted on Feb 25, 2009
  • 198 Answers
If you remove the motor control board, you will probably see burnt spot on the board.Board and motor need to be replaced, pretty expensive repair.
Posted on Feb 19, 2009
  • tom weber Feb 20, 2009
    Use the model number to get the part, sometimes you can get this part on Ebay. Use model number first and then put part number on ebay,
Why does my washer do every thing but spin dry could a pressure swicth be bad on door?
Good Afternoon Dale,
I see that you are having trouble with your Frigidaire Affinity washer, model# ATF7000ES, not spinning your clothes dry. First, if the drum is not spinning at all, I suggest resetting your appliance by either unplugging it or shutting the power off at your home's circuit breaker for 2-3 minutes. Once power is restored run a spin only cycle. If it starts spinning and the clothes are still coming out damp, try one of the following:
    1)Try changing the spin speed to a higher speed.
    2)Make sure that you have not overloaded your washer.
    3)Make sure that the wash load is not too small. If you are only washing a couple of items, try adding 1 or 2 similar items to balance the load.
    4)Try rearranging the load to allow proper spinning.
    5)Check the drain hose for any kinks. If it is kinked, straighten it.
    If you are still having trouble with your washer spin drying, I suggest contacting your local authorized technician. Hope this helps.
    -Best Regards-
    WP
May 01, 2014 | Frigidaire Affinity ATF7000ES Front Load...
I have a hotpoint whirlpool washer I cleaned out the filter as it would not empty now it won't spin
Error codes? may say bad board/replace board, but don\'t. Try to refrain. The likely cause is the wax switch on the door lock mechanism. I am not a proponent of replacing a pcb because the error code says to. After all, resistors and like components are only 0.5 cents. My washer just had a similar problem, it was a $19.95 wax switch. It has a plungher wwhich pushes a set of contacts together, sends a signal to the board telling it that the door is locked and it is safe to spin. Its true. Redundant but true. I am sure it was designed with the service industry in mind. $125.00 for the service call ( just to show up), then order the board and secretly install the $19.95 part, likely get it for $4.00 and laughs all the way to the bank. Mostly I find service guys are friendly enough, but if they sense a mechanical deficciency in the customer, they take advantage
Mar 24, 2013 | Washing Machines
Displays LE won't spin
For many LG's 'LE' normally stands for '(door) Lock Error' indicating that there is a problem either with the door lock or the door locked sensor requiring a service call, sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Oct 31, 2011 | LG WM-2277HW Front Load Washer
Washer won't spin. LE Error
'LE' stands for 'Lock Error' indicating that there is a problem either with the door lock or the door locked sensor requiring a service call, sorry ;-0(
John C
Sep 19, 2011 | LG WM1814CW Front Load Washer
Powerlock 1000 started beeping! New batteries no help. Won't lock or unlock!
This is the relevant excerpt from the troubleshooting instructions:
Why is my Powerbolt 1000 unit beeping?
To determine why your lock is beeping abnormally, please follow these steps:
  1. Take out batteries and unplug powerstrip.
  2. Let it sit for 1 minute, then put the batteries back in and wait another minute.
  3. If it does not beep, the keypad needs to be replaced (17733-1).
  4. If the unit continues to beep, the powerboard needs to be replaced (A17734-3,3 Powerboard 1470 brass finish; A17734-3,26D Powerboard 1470 satin chrome finish; A17734-3,5 Powerboard 1470 antique brass finish).
Here is the link to the complete instructions:
http://www.weiserlock.com/Support/Faq/50160000000HhhZAAS.aspx
Weiserlock contact information is:
(United States of America) Customer Service Contact Information
Call Us
Toll Free: 800-422-4278 (Mon-Fri, 6:00am - 4:30pm PST)
Jul 25, 2011 | Weiser Lock Powerbolt 1000 Lock
Just installed this lock - second one we tried (first didn't close all the way) Backlite is not working. did we oversee something?
I have reviewed the on-line installation instructions for this lock, and it requires attention to detail to properly install.
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
For instance, the first one may have not closed all the way if your door has a 2 3/4" setback instead of 2 3/8", and you did not extend the bolt and adjust the latch as shown in figure 2 of Step 1.
Also, if you don't run the door handling routine properly as in Section 8, the lock won't work properly.
But I believe that you are past that learning curve after the second installation, and I don't know why the backlight won't work on your new lock.
I didn't see any option to enable/disable it in the instructions. So my suggestion: If the lock is otherwise working properly such that the backlighting is the only problem, I'd give a call to the Customer Service number 1-800-677-5625 and discuss it with them. They will let you know if and what the problem is, and a new lock is certainly under warranty!
Jul 23, 2011 | Kwikset 907 90715 Satin Nickel SmartCode...
Needle keeps jamming, won't thread
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 07, 2011 | Janome D'cor Excel Pro 5124 Mechanical...
Kenmore elite he4t won't start getting door lock code DL F
you either have a bad door lock
or in most cases it's your control board
do you hear a clicking right before it gives you the code?
remove the lid.
direct in the center attached in the back is your ccu
locate the pink wires wiggle them up and down and try it again and see what happens. let me know
May 17, 2010 | Kenmore Elite HE4 Electric Dryer
My samsung 7kg front loader keeps flashing UE on the error code (spin cycle) and I can't open the door
UE = Unbalance Error
Laundry load is unbalanced, manually loosen any tangled laundry.
If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 26, 2009 | Samsung WF337AA Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
300 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
