Question about Brother IntelliFAX 2800 Laser Fax
Gringing noise and says to replace drum. Replaced drum and still grinds and says drum needs replaced
  • 215 Answers
Look at front of machine where your received faxes come out. you will see a couple of rollers there. unplug fax, and while watching the rollers, plug in and see if they turn when machine starts rotating. if they don't, you have a broken heat roller gear. another thing can cause this is a bound up toner cartridge. try another if rollers are turning. last but not least, your old drum possibly damaged your drum drive gears.
good luck,
razors
Posted on Feb 19, 2009
Grinding noise LD016
Lubricated the bushings on the black foam roller on the inside of the right hand door. Toner leakage is unrelated unless the drum unit gears are causing the noise, in which case, it must be replaced.
Apr 16, 2014 | Lanier Office Equipment & Supplies
What is the grinding noise on my 2003 Grand am front wheels, help please?
There are many things the grinding noise can be. I would start with the breaks though as that sounds like the most likely culprit. If they are grinding, odds are you have ruined your rotors and/or drums. This means that you are looking at about $50-$70 in new parts per wheel (Total of $200 to $280) to replace, assumming only the pads and rotors/drums needs to be replaced.
Please note that breaks can be a good DIY project, but this takes an intermediate skill level with some expereince. Some vehicles are easier than others. Drum style breaks can be especially tricky as they relie on a system of springs that can be challenging to work with. There is also a hydrulic system that can have issues. If you see break fluid when you take off the wheels and drums, you have much larger issues and I would recommend getting in touch with someone more qualified.
Jun 24, 2012 | 2003 Pontiac Grand Am
I have a grinding noise in the left rear wheel , sound likes a scrap and then a gring . do u have a fix for me
hi this sounds like the handbrake/safety brake pads have either worn and need replacing, or have broken inside the drum, this also could be a sign that your brake pads have worn as well....hope this helps happy 4th to you
Jul 03, 2010 | 2005 Chevrolet Colorado
I have an oki c3530 and it is making a terrible grinding noise, any ideas?
One of the drums needs to be replaced. Systematically remove one at a time until the grinding noise no longer happens, then replace that drum.
Jan 26, 2010 | OKI C3530N Color MFP Printer
Grinding noise in drum at rear
if your slides went bad, theres a good chance your drum was out of alignment it probably gotr worn on the back side and is now gringing when in the right position......
the good part here is the tumbler carries a ten year warrenty
Sep 26, 2009 | Maytag MDE308DAYW Electric Dryer
Rear brake grinding noise when pressing on brakes
The grinding noise in the rear brake drum means that brake shoes are warn out and the metal part of the shoe is touching the drum. You need to replace it asap as it will damage the inner part of the drum and than replacing shoes will not help without skimming or replacing the drum.
Jun 28, 2009 | 1999 Mazda Protege
Grinding noise on OKI C3300
I have had a similar problem. . Black drum needed changing. There was also a grinding noise developing. I have taken each drum and toner module out of the printer and booted it up with one of the 4 missing. It was the Cyan drum that was making the noise. . Question is what can I do? I am not a printer expert. .
I will contact the local printing shop that I use for more info and will come back to you. I suspect that I will need a new drum . . .
Nick Smith
nick@selectaccountingservices.co.uk
Nov 28, 2008 | OKI C3400n Laser Printer
Brother IntelliFAX 2800 Laser Fax Logo
122 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
