Question about Alpine CDA-7843
Alpine CDA-7843: All functions on the deck work except when unit is bumped- acts like a power problem. when the faceplate is moved up or down slightly, unit will come on until car hits a bump- very intermittent. Tried cleaning contacts with no help. Faceplate is tight to it's mount but seems loose because of linkage inside for tilt or opening the CD compartment.
  • 105 Answers
SOURCE: Alpine CDE 9881
You must have a faceplate from that exact model, no others will work. You can try to contact Alpine for a replacement. If it is any consolation, someone has a useless faceplate, because it won't work with anything else, either. Try running an ad in your local lost & found column, you just might get lucky, especially if you offer a reward.
Posted on Jul 28, 2007
TekTrax
SOURCE: Alpine cd redeiver CDA 7837
Just a guess, I’d say who ever installed it didn’t hook up the connector behind it. But lets say they did. In most cases, the radio’s connector bundle will have a fuse. It’s a good idea to check your car’s fusebox first to see if any fuses are blown there. In either case, if you replace a blown fuse with "the right value", and it blows again, have a tech check it out. Note that if you try to get to the rear of the unit, do a little research into how the radio is accessed through the dashboard. Most car radios aren’t quickies to get at and some folks can do damage trying to get at it, but if you methodically take logical steps, you should be able to pull the radio, check the connectors, locate the fuse if it has one. Of course, there may be a wiring incompatibility, meaning, the OEM radio had it’s own specific wiring harness, the Alpine was installed, but someone didn’t get the adapter harness to fit the car. Who knows. Good luck. TekTrax
Posted on Nov 03, 2007
  • 48 Answers
SOURCE: car cd player
You shouldnt have any problem at all. These don't use any special anti-theft features that would keep you from using any faceplate.
Posted on Oct 21, 2008
rangegul3
  • 59 Answers
SOURCE: faceplate for alpine model cde7853
go on google then click on shop it is te best way to buy items hope this helps.
Posted on Dec 31, 2008
  • 323 Answers
SOURCE: alpine 7835 display lights not working, everything else is fine
if it's not under warranty, I would advise taking the face plate apart and checking for burned spots on the board and using compressed air to remove anything that is conductive that may cause a short in the face plate. The face plate should be really easy to take apart.
Posted on Feb 11, 2009
My cda-9813 wont power on,how to take of faceplate?
Here is a link to the owner's manual for your stereo, it shows how to remove the faceplate:
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/500/500CDA9815.PDF
May 14, 2010 | Alpine CDA-9813 CD Player
sure it will the face eject button should be either on the upper or lower left corner of the face.
Mar 26, 2010 | Alpine CDA-9813 CD Player
Cda 9883 - no sound
Check for blown fuses behind the deck and under the hood, sometimes by the battery, you may get lucky but you could have smoked the unit, and would not know anything unless you send it in to get fixed. Replacing the unit could be the answer Alpine CDA-9883 CD Player
Feb 20, 2010 | Alpine CDA-9883 CD Player
I've had my Alpine CDA 9883 for 17 months, and the power to the display goes in and out. I've checked the wiring connections. Any ideas?
Check the face plate pins and the deck side for build up, you can scrape them w/fingernails to clean any excess dirt etc. off them, then replace the face. That's about all you can do. If the faceplate LCD is bad you can by a new one, generally 150-200 for a new face. Check with an Alpine dealer, most good custom shops are actually very helpful.Best of luck
Jun 24, 2009 | Alpine CDA-9883 CD Player
My display stays on for about 3 seconds then it turns off until
If this model has a detachable faceplate,
Remove the faceplate and clean down the contacts with metho and a cotton bud.
Over time usually corrosion and dirt etc builds up on these terminals making them loose cotact when you touch the faceplate.
This is the most commonly known problem alpine units.
Other common problems is the power supply failing /amplifier.
Hope this helps you out
Cheers
Steve
Apr 02, 2009 | Alpine CDA-9805 CD Player
I recently purchased an alpine CDA-9884 two months ago. The past couple of days now none of the functions work on the face, it plays cds but you cannot do anything but turn the volume up or down, you...
Not to sound very obvious, but it honestly just sounds like there is a connection problem between the faceplate and the unit. I would first try using some electrical contact cleaner and cleaning the contacts, installing and removing the faceplate a few times and see what that does. I hope this does something for you. Let me know if I can be of more assistance.
Nov 28, 2008 | Alpine Car Audio & Video
Faceplate problems
I have the same deck and a very similar problem. Mine was stuck in the out position and would beep and move a little but there was no lights or music. I called Alpine and they told me that sometimes the inner sleeve around the deck will pinch the unit a little. I took my unit out of the dash and sure enough the plastic face plate came loose and moved about 1/32 of an inch when I slide it back in place and turned the power back on it worked perfectly. Hope this helps.
May 15, 2008 | Alpine CDA-7897 CD Player
Interface Problems
If you're pressing on the "rotary encoder", then it's you. But if you're not and instead you're just turning it without pressing, you may have a defective unit. Try literally pulling on the thing while turning it. If that avoids triggering the other functions then either you'll have to get used to being gentle, or you need to take it back or send it to Alpine (again, probably just the front faceplate unit needs work...not the whole radio).
Sep 16, 2007 | Alpine CDA-9885 CD Player
CDA-9885 Alpine No audio from Ipod - CD Playback not working
Disconnect whatever is attached to the BLUE wire at the back of the Alpine deck. Re-connect it to the BLUE/WHITE wire instead. This should solve your problem.
Aug 12, 2007 | Alpine CDA-9885 CD Player
Car Audio & Video Logo
95 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
