Question about Ovens
Oven won't heat
The electric panel (timer, temp set) works so I know there is power to the oven but the elements - both top and bottom - won't heat. It stopped working when I had the oven on and the door open for an extended period. So I am thinking maybe it over heated and tripped a breaker. Is there a reset button?
Dacor Epicure 30" convection oven DAC-ECPS130S
  • kim_maas Feb 19, 2009
    Thank you. I'm not sure what "check your main panel" means? If it means the electical panel where you set timer/oven temp etc that is working fine. It's just when you set the oven temp it waits a minute, makes a clicking noise and never heats up.
    Any other thoughts would be appreciated
    Oh, sorry. No, there is power to the oven, it just won't heat
    President:
  • 2,976 Answers
Check your main panel. If you ran it for a long time with the door open, the elements never reached their shutoff temperature. Quite possibly, you burned them out.
Posted on Feb 19, 2009
  • David Shaub Feb 19, 2009
    Check your MAIN ELECTRICAL PANEL. Your breaker box.
Creda Solarplus (48906) top oven and grill not working
Electric stoves do not have pilot lights or igniters it could be the power control board has failed .
Mar 12, 2016 | Creda Ovens
Bottom oven isn't heating to desired temp. Considering swapping the heating elements to see if one is faulty - thoughts?
try thermostat first. verify heating elements operational, if so check if tstats are same. swap if so, If not jump out tstat and see if higher temp achieved.
Sep 20, 2015 | Thermador PODC302 30" Double Electric Wall...
Oven Won't Heat To Desired Temp / Burner Quits Working Sometimes
The temperature sensor in the oven needs to be replaced. Here is the part to order. As far as the top element, lift the top up and look for lose or broken wires on the element. Keep me posted.
Nov 20, 2012 | Magic Chef Ovens
SMEG OVEN BRAND NEW WON'T HEAT
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Sep 08, 2012 | Smeg Ovens
Dacro Wall oven (electric) does not heat past 345 degrees on bake or convection bake but broiler works and bottom oven works fine (for bake, convection bake and broil).
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
Jul 28, 2012 | Dacor Ovens
I have a double oven top one stopped heating up sooo i just switched the elements from the bottom to the top as to order the parts but that isnt the problem the top still won heat up
This could be a faulty circuit or sensor that will need to be replaced before the oven safety feature will disengage. If the Temp sensor is not registering as working or the load sensor it will not allow the element to heat up. This is a safety feature. You will need a repair tech to diagnose this and do the repair.
Oct 17, 2009 | Frigidaire FEB27S5A Electric Single Oven
Bottom oven doesn't heat after running self-clean cycle
Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 17, 2009 | GE Profile JTP56 Electric Double Oven
Old Gaffers& Sattler oven won't heat up. I suspect timer setting?
The most common failure in any electric oven is the heating element.
Jun 20, 2017 | Ariston Technologies Ariston FO98P...
Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Jul 08, 2008 | Ovens
    Top oven will not heat up
    Had a similar problem. The overheat sensor had failed to the open position and the oven control would light up and you could set the temp, but it would drop to 100 degrees and then go blank.
    Nov 14, 2007 | GE JKP45 Electric Double Oven
    Ovens Logo
    242 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
