Question about Kenmore Elite HE4 Electric Dryer
My sears elite XE dryer stopped working suddenly. It has power i.e. light in drum and control panel. when pressing the start button I get the beep that always happens but then nothing. I did the diagnostics and some trouble shooting according to the tech manual that is inside the top. I think the problem is in the electronic controller but not sure yet and don't want to order the part until I am. Has anybody had the same problem and what did you find?
  • losososlobo Feb 19, 2009
    found the problem with open circuit ( bad solder connection) on motor switch which is located on the control circut card. saved a lot of money.
    thanks for your help
2 Suggested Answers
jgwhomeequip
  • 1902 Answers
SOURCE: sears elite he dryer stopped working
Bad control panel. Replace the control panel at repairclinic.com. When your control panel clicks like that it means that a resistor or solder joint has gone bad and it is cheaper and easier to just replace the board
Posted on Feb 19, 2009
I have a Kenmore Elite HE4 smartheat quiet pak 9 that has power but will not start.
Sounds like the belt that turns the drum could be broken. I'd check that first.
Oct 12, 2017 | Kenmore Elite HE4 Electric Dryer
My Sears Kenmore Elite dryer stopped working in the middle of a drying cycle. The drum light is still works - so it has power. But when I press the Start button, I just hear a faint clicking sound. Any...
Most common cause is a partially or fully clogged dryer exhaust vent makes the dryer overheat and trips the high temp limit fuse. Brush out the vent all the way to the outside.
Feb 20, 2011 | Kenmore Dryers
Dryer control panel works then suddenly doesnt. Same issue as everyone else this unit should be RECALLED. unplug it for 24 hrs and it'll work again for a short while. COntrol panel works then doesnt or...
I had the same problem only 1.5 yrs after i bought it. I called sears and complained till i got them to send someone for free to fix it. It had a bad circuit board and another part that cost close to $500 for them both. Was able to get a warrenty for $150 i think and it covered the parts.
Nov 21, 2009 | Kenmore Elite HE4 Electric Dryer
Sears elite he dryer stopped working
Feb 19, 2009 | Kenmore Elite HE4 Electric Dryer
4E problem on kenmore dryer
Same problem, no panel lights, nothing, but drum light works. Several postings on othe sites say the cuicuitry board is faulty. Sears, in the Phillippines, or India, do notheing. Paid lots for this dryer, live alone and really don't abuse it or even use it that much. Is the there a class action suit maybe? all I want is for it to work!
Aug 20, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore HE4 no power to control, no sound, but the drum light bulb on when door opened
Another post reported replacing the power cord. I am trying to determine if this is a factory defect. Check the power at the power cord connections inside the dryer. You could have lost power on one leg and the other 120 volt leg is letting the light work. Let me know what the model and serial number is.
InMrFixIt
Aug 15, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 beeps three times when start panel is pressed and wont turn on
FWIW ... the Sears guy came by yesterday. The problem was apparently that the door latch was not operating to the extent that the sensors thought the door was open. He is replacing the latch next week. He adjusted the old one in the mean tiome and it appears to be working fine.
This kind of stunned me, since my wife reported an electric zap and the interior light burned out as the dryer went dead -- so I was sure it would be a fried circuit board -- but, no, a little jiggling of the latch seemed to clear it up....
Jun 24, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE3
replace the power control board
Jan 21, 2008 | Kenmore 82822 Electric Dryer
Dryer not working
Front Panel lights not working? Dryer inside light does work? I fixed this twice already on my dryer. Please read this whole explanation I live in New Orleans where the humidity is very high. I have a laundry room where my Washer and Dryer reside. Kenmore HE4T. I noticed that when I shut the laundry room door, my central A/C pulls hot air from outside the house via the dryer exhaust duct. This causes moisture to build on the inside of the dryer and especially the front control panel. Did you ever see moisture on your dryer?s door even when there were no clothes in it? The moisture collects on the Silicon board that controls the dyers function and basically causes a short. This is what I do to fix it. You will need a ΒΌ nut driver or socket. 1. Confirm that you have power to the dryer <- is the inside dryer light on when you open the door. YES- keep reading.. NO ? find the circuit breaker and reset it. 2. UNPUG THE DRYER! ! ! ! ! ! ! ! 3. Find the 3 screws in the back of the dryer that hold the dryer lid on. Unscrew them and slid the lid back and lift off. Is there moisture on the inside of the lid? 4. Find the 2 screws that hold down the front control panel. They should be silver and will be on top. Do not remove the inside gold screws. 5. Find the 3 screws that hold down the power control panel on the top left side of the dryer. Probably has a high voltage warning sticker on it. 6. Lift the power control panel (sheet metal) part and move it to the right so it lays on the dyers drum. There are some wires attached to it and unless you are a very handy person, I wouldn?t remove them. 7. Lift the front control panel straight up until it comes out of the dryer. There should be some wires that attach this piece to the power control panel. If you are handy, you can remove these 2 clip-on wires from the power control panel by squeezing the black connector locking clip and releasing it from the panel. 8. If you flip the control panel around you may notice moisture on the green silicon chips. Get a hairdryer and take your time to dry them. 9. Dry all components of the dryer with a hairdryer. 10. Put everything back together except for the lid and all the screws. Remember that the front control panel slides down first and then the power control panel sits on top second. Plug the dryer in and see if you get lights, but don?t start the dryer. Unplug the dryer and replace all the screws and the lid. The problem is that once the dryer gets wet from the moisture, it never dries enough for it to start working again. This is a bad design from Sears/Whirlpool. I learn my lesson that just because its more expensive doesn?t make it more better. I now keep my dryer and washer door open all the time even when there are no clothes in it. This lets the moisture escape into the house rather than collect in the dryer. I hope this helps at least one person. Thanks Jason Kennedy from New Orleans
Nov 19, 2006 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
