Question about Scunci 52067 Handheld Steam Vacuum
Scuncii Steamer wont work wont blow steam anymore
  • Anonymous Feb 23, 2009
    wont blow steam
  • 328 Answers
It is probably clogged with rust or limescale - can happen with steam cleaners. Sadly there's no way around this but to try a limescale remover in distilled water such as Calgon limescale remover. Fill the kettle as normal and give it time to boil up. Then release the steam as you would normally. You may find that the kettle will spurt out deposits of gunk. Sounds like its definately clogged though.
Posted on Feb 20, 2009
  • 175 Answers
Sounds like your have hard water build up that is clogging the sprayer. You will need to take some vinegar and put it into the water compartment and let it set for a day and then try running your machine. From now on, only use distilled water in it.
Posted on Nov 20, 2009
  • alexy91 Jan 06, 2011
    Thanks to this site!....I bought a scunci steamer on ebay and my 3.00 purchase was looking like it was too good to be true; till I turned it on and nothing ...so I looked on this site and put the vinegar in the water compartment solution overnite and wala!
    New Friend:
Or you can take the Scunci Steamer Model S3888 apart and clean all of it's works...Here's how:
1. Remove the two screws from the front of the steamer then remove the end cap.
2. Remove screw from the lower area of handle.
3. On the top of steamer, remove the two screws under round rubber flap around fill hole.
4. Remove the back of handle, top of steamer, front of steamer where nozzles attach.
5. Remove the plastic tube where the steam comes out.
6. Now look in the hole where the steam comes out and remove the 1/4 inch nut, metal washer, and rubber washer.
7. Take a small punch and lightly tap the brass rod until it pops out the back.
8. Remove the brass rod and spring. The spring will have white crud on it and in the hole where it came out of. Clean the hole and spring really good. This will fix the problem of steam always coming out with out pushing the button.
9. Clean the brass rod, spring and hole that they go in. I use a very small round wire brush. Like the kind you might use to clean a gun.
10. Spray some WD40 into the hole and on the brass rod, then put a few drops of oil on the rod.
11. Put every thing back together and it will (should) work like new. At least according to the guy who originally wrote these instructions.
I have just disassembled mine using these directions. The only difference is that I did not find a spring where it says one should be on line #9
I'veI
Posted on Sep 23, 2014
My compact steamer does not let the steam out when I press the black release button help?
I examined mine. There is literally NO hole in the steam wand for the steam to exit. It's a wonder the thing didn't blow up. Take it back and be glad you still have your face.
Jan 01, 2015 | Top Vacuums
My polti steam cleaner wont work when i click trigger
Check the wand and line for calcium build up especially in the nozzle. Hard water will deposit a lot of calcium in the system, which needs to be cleaned regularly to keep it running freely.
Aug 25, 2014 | Polti Vaporetto 2400 Canister Steam Vacuum
My Shark steamer works fine for a few minutes and then the steam doesn't come out anymore.
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the
Shark Manuals that you need.
heatman101
Dec 07, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Steamer does not give out steam. The light comes one and you can pump it and steam comes out and then it will not give out anymore steam.
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Here also is a link to get any of the Shark Manuals that you need.
heatman101
zzc
Jul 14, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Sharksteamer not steaming anymore
Change the type of water you are using...try bottled water...
heatman101
Feb 27, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Bissell handheld steamer froze in the car and wont blow out stea
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
afdda
Jan 08, 2010 | Bissell 1699 ProHeat Clear View Upright...
Shark Euro pro mop the ligt wont turn on anymore.
my husband fixed my shark steamer by taking it apart and testing it wire by wire .the problem ?a fuse hidden inside the unit..unscrew the screws and get inside the steamer .at the bottom of the steamer there is a gold orange foil looking piece .under that is a small fuse .unless you can find another fuse just cut that one off and rewire the wires together .shark now comes on
Sep 27, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
My scunci handheld steamer does not dispence steam anymore
probably full of scale in the nozzle and element common from using tap water. Purchase a product called scale clean insert and flush. Scale clean is available at department stores for home coffee makers.
Sep 13, 2009 | Scunci 900 Handheld Steam Vacuum
Shark floor steamer: Does not produce any steam and no lights are on.
Hi All
Shark steamer that the light is not on and will not heat up. I have found that there is a in line slow blow fuse in side. replace this fuse IF you can find one and the steamer will work. If you let the unit run dry and leave the unit on it will get hot and blow the fuse!
I am looking for the fuse myself. good luck! Dan FL.
Dec 17, 2008 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Scunci 52067 Handheld Steam Vacuum Logo
1,104 people viewed this question
Top Scunci Vacuums Experts
Craig Butler
Craig Butler
Are you a Scunci Vacuum Expert? Answer questions, earn points and help others
