Question about Reddy Heater-30-55,000 BTU Variable
Reddi heater turns on then shuts off
When i push the reset button on my reddi heater it starts up but id doesn't throw out any heat then shuts off after 5 seconds
Try.. obstruction of fuel
Posted on Feb 21, 2009
I have a 100,000 btu reddy heater, and every time I turn it on, it runs for about 5 minutes, then stops, then I have to push the reset button and start it again. Can you tell me where to start? thanx
If it actually ignites and burns but shuts off either the flame sensor is bad (or dirty) or the control is bad. I would verify the flame sensor is clean and had good electrical connections to the controller for starters.
Feb 10, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
I had my heater on and when I went to turn it off it showed "HH" in the digital display
On many types of heat controler HH stands for high,high set limit, if your unit shut down because of this-look@ the rear of the unit below the handle close to the fan for a reset, push it in and see if it starts back up for ya, hope this helps.
Oct 09, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
How do i light a Reddy Heater rcp 2000 lp gas heater?
hold down the pilot valve knob and turn the arrow to pilot position push down on red button to allow gas thru pilot tube hold down and light keep button held down for 1-2 mins while pilot is on to heat up the thermocoulple then release and turn knob to on position.
Sep 12, 2009 | Reddy Heater RLP100 Portable Forced Air...
Heater turns on for a few seconds then goes out
Absolutely K1 or diesel can get old in a hurry, the ultra-low Sulphur diesel has been tinkered with so much that it turns to book varnish much faster than before 2010. Most of those heaters spray fuel past the igniters using a siphon much like a spray paint gun, the suction tube may have dry rot or a small air leak and it it takes but a tiny air leak to kill the siphon effect. Check the tube from the nozzle all the way down to the fuel tank or replace it if you're not certain it is not compromised or dry rotted.
Oct 12, 2017 | Reddy Heater-30-55,000 BTU Variable
I have an R50 Reddy heater. It will start and run and heat for about 4 mins, then it shuts down. Then I push the reset button and it will run approx. 5 soconds then shut down. What do I do and will it be...
If the heater runs good & smells good while its running, but shuts down for no apparent reason, then most likely, you have either a bad Safety Control HA3003 (reset) or a bad photocell HA3019.
But, don't rule out simple problems like:
(any of the following can cause a flameout condition, in which case the photocell will shut the unit down. This is where trouble shooting comes into effect).
  1. loss of ground at the Ignition Control (transformer)- not screwed down good
  2. restricted fuel fulter
  3. restricted or worn nozzle
  4. air pump pressure not set to specs
troubleshooting tips
Dec 04, 2008 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater keeps shutting down
check your cad cell. replace this. it is not detecting a flame. replacing the cad cell will fix your problem. when it shuts down it goes into lockout.
Oct 30, 2007 | Reddy Heater-30-55,000 BTU Variable
Reddy Heater-30-55,000 BTU Variable Logo
258 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
