Question about Samsung DV448AEE Electric Dryer
DV448AEP sensor drying doesn't seem to work
Hi, I got this $1300 dryer and it's got great features, well, I really love the washer:), but the sensor drying feature never seems to get the clothes quite dry enough. My old $300 GE dryer did a much better job of toasty hot clothes on the medium setting, now if I use the medium setting clothes come out quite damp, and on "more dry" they come out dry for the most part, but a little cold and possibly damp in a few spots. I've tried putting a blanket or something something in by itself (3 times) and the sensor shuts off the dryer within minutes leaving it damp. The vent piping is solid vent pipe, no flex, and air flow is strong out of the exhaust. Basically should I just run the thing at the highest setting or try to get a service call? I would really like to know if this is normal for this type of dryer. Thanks.
  • burnt dinner May 11, 2010
    Hi iwhitacre, did you ever fix your problem with your Samsung dryer sensor? I have the same exact problem (which I also posted since you only had one response and it had to do with the wrinkle release cycle). I have had 3 of these dryers in my home now in less than 2 weeks and they have ALL had this problem. Just curious! Thanks.
I had the same problem with mine. My wrinkle free setting some how got turned off. As soon as I turned that back on machine kept running and dried the clothes fine.
Posted on Mar 28, 2009
WHY DOES MY SAMSUNG MODEL DV448AEP/XAA SENSOR DRY MODE RUN FOR TWO MINUTES AND THEN WILL GO TO COOL DOWN MODE, ALL OTHER DRY CYCLES MANUEL AND STEAM CYCLE OPERATE FINE!
Sensor is screwed or the timer relay for that part of it is not working . Go to an appliance store to get wiring diagrams ordered and might even know about the problem w that model
Feb 19, 2015 | Samsung Dryers
My kenmore elite #110.73012181 electric dryer with autonsense feature no longer sensing, keeps on drying for hours after clothes dry when on less dry mode or normal dry mode
The drying circuit has to have a sensor to control heat and the timer controls time (on timed drying). Often sensors fail "open" and dryers stop drying. This sensor or the circuit seems to have failed closed (runs all the time). I suspect the sensor has failed in the drying control.
Jan 02, 2014 | Kenmore Dryers
Hi, I have a Maytag dryer, model # mdg308daww Legacy series. It heats up just fine, dries clothes great but the problem I am having is that the Auto dry features are not shutting off as they were before....
you may need to replace the moisture sensor bars inside the dryer.also you may need to check the air flow if timed dry is nnot drying them properly
Dec 19, 2010 | Dryers
Frigidaire AEQ8000 dryer doesn't completely dry clothes
1. Gas valve coilsIgniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Sep 15, 2008 | Frigidaire AEQ7000ES Dryer
Hoover washer dryer saver 1300
I have inherited a hoover saver 1300 in new flat, the dials have worn away and it goes onto drying mode after wash, how can i have it on wash and spin only - NO DRYING? Thanks
Apr 12, 2008 | Hoover H120M Front Load Washer / Dryer
Washer water level low, clothes come out dry !!
This is the water saver feature and the only solution may be to put it on the maximum wash cycle to get clothes really clean.
These washers normally get the clothes almost dry.
Mar 04, 2008 | Frigidaire GLTF1670A Front Load Washer
Maytag Neptune Dryer--Drying Problems
clean out your vents going out your home have someone also clean out the lint that has been pushed in side your dryer
Mar 03, 2008 | Maytag Neptune MDE5500AY Electric Dryer
How to use the dryer of my Candy Aquaviva 1300 please?
wahing machine works great but a cant work out how to use dryer
Feb 21, 2008 | Candy AQ130 Front Load Washer
Whirlpool Dryer GEQ9858J autodry problem
Are you running the dryer in a relatively humid environment?
Sep 07, 2007 | Whirlpool GEQ9858J Dryer
Samsung DV448AEE Electric Dryer Logo
777 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
