Question about Magic Chef MCD1611 Microwave Oven
Replace light bulb in Magic Chef MCD1611
How do I replace light bulb in Magic Chef MCD1611 ?
  • 3 more comments
  • jlfrank Feb 21, 2009
    Magaic Chef Microwave Model MCD1611D, Light not working. Found Light. Where do I go for part replacement or a phone number to order light,
  • Sammie Smith Apr 16, 2014
    how you get to the light?
    ho you get to blub?
    hoiw
    how
Remove cover and look for light. Special torx is required to loosen screws.
Posted on Feb 21, 2009
How do you access the light bulb in a Magic Chief Microwave MCD1611W
https://www.justanswer.com/appliance/9q0am-change-light-bulb-model-mcd1611-w-microwave.html
Quoting from link:
"Unfortunately the microwave will need to be taken apart to replace the bulb. You'll need a size T-20 safety torx bit screwdriver to remove the screws coming in from the back of the microwave around the right left and top edges. Start by unplugging the microwave. Then remove all the screws going into the outer shell and then the outer shell will pull straight back, up, and off. Now you have access to the bulb on the right side of the microwave cavity so you can replace it. The reason Magic Chef did this was because it forces you to unplug the microwave. Before they allowed you to change it by just opening the door and people wouldn't unplug the microwave which would cause the display board to short out when you replaced the bulb."
How do you change the light bulb in model MCD1611
May 04, 2018 | Microwave Ovens
How do I change the light bulb in a magic chef microwave?
  1. Unplug the Magic Chef microwave from the wall outlet.
  2. Remove the screw from the light cover located on the left side of the underside of the microwave. ...
  3. Unscrew the light bulb, then screw in the new light bulb.
  4. Raise the light cover, then secure the cover with the screw that was originally removed.
More items...
How to Replace a Magic Chef Microwave Light Bulb ' Hunker
https://www.hunker.com/13407988/how-to-replace-a-magic-chef-microwave-light-bulb How do change the light bulb in magic chef microwave Google Search
Oct 24, 2017 | Magic Chef Microwave Ovens
Replace light bulb.
http://www.ehow.com/how_7614605_replace-chef-microwave-light-bulb.html
Here is one link that i've found. It didn't mentioned the exact model but i hope this one helps...
Mar 07, 2015 | Magic Chef CMV1000B Microwave Oven
Looking for an exact size replacement for Jenn Air JMC7000
it looks like the Magic Chef MCD1611 is the same size
Jun 16, 2011 | Jenn-Air JMC7000 Microwave Oven
How to replace the light bulb
Replacement of the lamp should be carried out by a qualified appliance repair service.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
But here is a basic method if you are mechanically minded and have electrical safety knowledge.
The lamp is sat in a housing and its position is adjacent to the vent holes that it shines through.
If you feel confident, disconnect it from the mains power, remove anything in the cavity.
Remove the microwave cover. Purchasing a new replacement lamp will be useful as it will give you an idea of what it looks like. Locate the dead lamp remove the lamp and fit the new one. Replace the covers. Plug it back in and try the lamp by opening the door.
Hope this helps.
Feb 16, 2011 | Magic Chef MCD1611 Microwave Oven
Blowing fuse when opening microwave door
the microwave has a short in the power supply it can be the diode or the high voltage capacitor.have a tech check your microwave for repairs.good luck.
Mar 01, 2010 | Magic Chef MCD1611 Microwave Oven
Need part number and where to go for the bulb
go to sears.com go to parts research and enter you model number look at their diagram locate part number either order through them or call around locally,,, or sometimes if u can get the bulb out some local lighting stores willl stock them for cheaper , try to locate the watts and voltages on hte bulb sometimes writeen on the base of the bulb or on the part descritions hope this helps
Jan 30, 2010 | Magic Chef MCD1611 Microwave Oven
Microwave
im not sure what a magic chef bulb is but you can check by opening the casing, the bulb is normally mounted on a fiber board and screwed on the metal part of the microwave,remove the two wires attached to it first, after unscrewing the screw, you can pull out the bulb holder and you can see if it is a replaceable bulb if it has a socket. you can use the old bulb holder , just replace the bulb. in some design, the bulb is mounted directly to the bulb holder, you have to buy the bulb mounted directly to a new bulb holder and use them all as an assembly. be sure to screw them back tight. tnx. i hope i was able to help.
Feb 08, 2008 | Microwave Ovens
Magic Chef Over-Range Microwave Oven Model:MCO153UBF
The turn table and fan are connected in series with the bulb,as you have mentioned that you have replaced bulb,so please check again for any loose contact on bulb holder or bulb continuity again.
Aug 03, 2007 | Magic Chef CMV1000B Microwave Oven
Magic Chef MCD1611 Microwave Oven Logo
1,350 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
