Question about Hotpoint Washing Machines
Hotpoint wlw3300bblwh leaking yellow oil - Hotpoint Washing Machines
  • 198 Answers
Transmission leaking, expensive repair, replace the machine.
Posted on Feb 19, 2009
I have 2014 Montana 3735mk looks like a leak by my rear 2 hydraulic Jacks but it is a yellow oil. What is back there that contains a yellow oil that could leak?
a lot of hydraulic oils are yellow or honey coloured so it may be a seal that is leaking
check to see if it is still under warranty and have a service dealer check it out.
Aug 14, 2015 | Cars & Trucks
Oil leaks at front of engine1994
Well,so does my Toyota.
Major PITA to find source.
Get leak detection dye and UV flashlight.Yellow glasses may help.
Wash off front of engine at the quarter car wash.(Engine running)
When you get home,add dye.Run engine for one minute or less and look.Use an inspection mirror to see the lower cam cover and front of oil pan with engine off.
The dye with glow bright yellow.
Feb 21, 2013 | 1994 Toyota Land Cruiser
Oil leaking on front right side of my fridge freezer
Hello, Thank You for using FixYa. I will be helping you today.If its oil you unit will stop cooling because there would be a sealed system leak.
Thank You and please rate my answer if it was helpful..
Jun 16, 2011 | Hotpoint Refrigerators
Yellow white goo under my valve covers but not in the oil
you have antifreeze getting in somewhere as it's the only thing that will make oil foam up and get a gooy greyish white color....you might check to see where it shows up strongest and check that part of the engine closely for a leak...
Feb 02, 2010 | 1999 Chevrolet Malibu
Red /yellow cloured oil leak around behind front wheel line
if it is yellow it could be the aircon compressor, if it is really red to pink, power steering or automatic transmission leak
Jan 08, 2010 | 1997 Mercedes-Benz E-Class
When we wash..you can see oil in the wash tub and smell of strong oil odor.
sounds like the spyder has leaked oil from the bearings into the drum, does it make a grinding noise on spin?
Nov 09, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint vbxr1060 spins but won't agitate
OK, this oil is defiantly coming from a busted transmission(gear box). you will need to replace the gear box asap. the housing has failed. its cracked and leaking oil. This will damage the clutch and prevent the agitation effect. the gears will eventually lock up and damaged the drive assembly if not replaced soon.
Jun 10, 2009 | Hotpoint Aquarius WD63 Front Load...
Oil Leak around oil cap and Air Filter
blown head gasket. the coolant gotten into the oil.
Jun 01, 2009 | 1998 Volkswagen Jetta
OIL PRESSURE GAUGE AND YELLOW FLUID LEAK
isw this leak inside car or outside ,yellow fluid sounds like antifreeze
Apr 07, 2009 | 1989 Jaguar XJ6
Hotpoint washer top loading has oil dripping on the floor
The only place oil can be coming from is the transmission. If left as is, leaking oil will eventually result in full transmission failure. Yes, you can replace the transmission, but the repair is costly and moderately difficult. I'd save the expense and put the money toward a new machine. Please don't bother rating this solution as anything but a FixYa will drop my rating.
Oct 28, 2008 | Hotpoint Washing Machines
Washing Machines Logo
122 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
