Question about Olympus VN-480 PC Digital Voice Recorder
File transfer VN-480PC doesn't work on notebook (Vista)
Installed full version software(download) for Olympus VN-480PC on a new ASUS notebook (running Windows Vista): notebook recognizes recorder when attached, but doesn't transfer any files (indicates 'transferring' at the bottom of the frame, but the usual pop-up frame doesn't appear).
Note: file transfer works perfectly on PC with Windows XP
  • Anonymous Mar 14, 2009
    this did not solve the problem
    President:
  • 919 Answers
Install a VN recorder on VISTA
1. Make sure the device has been uninstalled in device manager
2. Make sure the old version of digital wave player is uninstalled.
{Delete Temp files in Internet Explorer --Tools--Internet Options --Delete Files-- Delete offline content--OK}
3. Install digital wave player (The newest Version).
http://www.olympusamerica.com/files/DigitalWavePlayer.zip
4. Install the 2.1.4 vista update
http://olympusamerica.com/cpg_section/software_results.asp?id=1291&os=w
5. Restart the computer.
6. Plug in the VN recorder to the USB port and turn the recorder on.
"Found new hardware" will appear,
7. install automatically.
This may fail, if you see VNUSB device, skip the final steps and proceed to Digital Wave Player to Download files from the Digital Voice Recorder.
If you will see "Other devices" listed in Device manager with "digital voice recorder" underneath it.
8. Right click on the "digital voice recorder"
9. Select update driver from the pop up menu.
10. Choose the browse computer Option
11. In the next window browse to the location that you downloaded the Digital Wave Player application to
12. Click Next
A security warning window will open,
13. Choose "install anyway" and the device will install.
When successfully installed you will see the "other devices" disappear and a VNUSB device with a "VN series device"
underneath it appear at the bottom of the device manager list. There will be a blue question mark next to the device. At this point you can close the device manager and the properties window and open Digital Wave Player. You will see the recorder listed underneath the recorder folder and be able to download and use the program normally now.
Posted on Feb 19, 2009
I had the same problem on XP. The long instructions with downloading updates for wave player did not help. I managed to solve this problem.
Solution:
Go to Control Panel and press Add Hardware. Search for new hardware and allow windows to go on the net to search for the drivers. It will find and install drivers. After that functionality in the Digital Wave Player will become active and you can transfer your files onto pc.
Posted on Mar 15, 2009
OLYMPUS VN-480PC RECOGNISE PROBLEMS WITH VISTA
Is this a new Vista system??? has the machine worked before on your computer.??? What is new, what has changed.???
The VN-480PC is compatable with Vista 32 Bit systems but NOT 64 Bit systems.
Verify by checking at www.olympusamerica.com instructions and software downloads are available there also.
Sep 24, 2010 | Olympus VN-480 PC Digital Voice Recorder
I need Digital Wave Player soft to work with VN-480PC
If you have previously connected the recorder:
1. Make sure the recorder is connected correctly.
2. Open the 'System' control panel: Start menu -> Control Panel -> System.
3. Click the 'Hardware' tab and then click the 'Device Manager' button.
4. Right-click the item that shows as 'Digital Voice Recorder' and choose 'Uninstall' or 'Remove'.
5. Disconnect the recorder.
If you have the software already installed:
1. Open the 'Add / Remove Programs' (Pre-Vista/Windows 7) OR 'Programs and Features' (Vista/Windows7) control panel: Start menu -> Control Panel -> Add / Remove Programs (Pre-Vista/Windows 7) OR Programs and Features (Vista/Windows7).
2. Click 'Olympus Digital Wave Player' and choose 'Change / Remove' or 'Uninstall'.
Please restart the computer before reinstalling if you had connected the recorder or installed the software previously.
Digital Wave Player (2.0):
SAVE to the desktop
RIGHT CLICK on the DigitalWavePlayer.zip and LEFT CLICK on EXTRACT ALL
CLICK on NEXT, Then NEXT again, Then FINISH
After unzipping the file, click on the SETUP.EXE file to begin installation.
Download update 2.1.4:
http://olympusamerica.com/files/DigitalWavePlayerUpdate214.zip
SAVE to the desktop
RIGHT CLICK on the DigitalWavePlayerUpdate214.zip and LEFT CLICK on EXTRACT ALL
After extracting the file, click on the SETUP.EXE file to begin installation.
For 64-bit systems, save the driver to the desktop and run the installation within it:
http://www.olympusamerica.com/files/oima_cckb/VNSeries64Driver.zip
Mar 06, 2010 | Olympus VN-4100PC Digital Voice Recorder
I have a Olympus VN-960PC voice recorder. I have lost the software disc. I downloaded the software to my PC from the internet. When I try to install the program, I get this error message that says the...
Download the Digital Wave Player full version from the Olympus UK site
http://www.olympus.co.uk/consumer/2590_software.cfm The American site only has the software updates and not the full versions of this necessary driver. You may have just downloaded the update previously and this is why you can't execute, because you don't have the actual program installed. Good Luck.
Feb 15, 2010 | Olympus VN-960 Digital Voice Recorder
I have an Olympus Digital Voice Recorder WS-311 M and a new Macbook Pro. I cannot seem to download to my Mac
http://www.olympusamerica.com/cpg_section/cpg_archived_accessories.asp?id=1308&ct=all
"DSS Player Version 7 (Vista Compatible) Item: #147467-410
DSS Player version 7.x provides computer support for Olympus DS-Series, WS-Series and VN-3200 and VN-5200 PC digital voice recorders using Windows 2000 Professional, XP Professional, XP Home, Vista, and Windows 7.
Functions include USB file download, file playback, editing files, conversion of DSS files to WAVE format, and archiving files. The installed application provides for the purchase of an optional Plus upgrade that enables splitting and joining files, and compatibility with voice-to-text transcription software.
The CD also contains DSS Player for Mac that provides computer support for Olympus DS-Series, WS-Series, and VN-3200 PC and VN-5200PC digital voice recorders on Macintosh platforms using Mac OS 10.3 and later, excludes: DS-3000, DS-2000, DS-660, DS-330, DS-320, DS-150, DS-10 and DM-1. Functions include USB file download, file playback, editing files, conversion of WMA and DSS format files to AIFF format, archiving files, and splitting and joining files. This MAC software version is not compatible with older foot switch RS-25, only the RS-27.
Item #147467
Opened software cannot be returned.
Price: $29.99
Sep 24, 2009 | Olympus WS-311M Digital Voice Recorder
I lost my drive for vn-480pc,
Download update: http://olympusamerica.com/files/DWPUP2EN.zip
Download update 2.1.3: http://olympusamerica.com/files/DWPUP4EN.zip
Do not have recorder connected until all software installed and then reboot computer. Once computer rebooted then connect the recorder.
Apr 13, 2009 | Olympus VN-480 PC Digital Voice Recorder
I have olympus digital voice recoder vn . 480 oc and windows vista, not working, not transfer and not identifiquet the olympus digital... in the list of CD windows vista is out I need of sofware for...
There are many steps in installing Digital Wave Player on VISTA, it is important to follow every step since installing Digital Wave Player on VISTA is dependent on this process.
12. Click Next
Mar 23, 2009 | Olympus VN-480 PC Digital Voice Recorder
Olympus VN-3100 software
Call tech support at Olympus. They maybe able to help you with a special link.
Feb 06, 2009 | Olympus VN-3100PC Digital Voice Recorder
Here is the download instructions for the VN recorder software it work with the VN 240Pc up to the VN 4100PC and Widows 2000 - VISTA.
Digital Wave Player (2.1): is available via download as a courtesy, please follow the instructions below:
Jun 23, 2008 | Olympus VN-3100PC Digital Voice Recorder
Olympus VN-480 PC Digital Voice Recorder Logo
4,126 people viewed this question
Top Olympus Audio Players & Recorders Experts
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
