Question about Refrigerators
Freezing fine,food area warm
I just recently moved and fridgidaire model#FRT8G6FMB3 refer.
freezes o.k. but the food section doesn't get cold. Runs quiet &
no leaks.I suspect somethings loose,if not , Where to start?
Thanks! I have the same problem. A few months ago the problem started. We emptied the whole fridge, and started using it lightly. It worked for a while. Again the food area is not working. Freezer area has no problem.
  • jonathan814 Feb 19, 2009
    Same problem but with model# FRT04LG3DW0
  • 27 Answers
Themostat for food area is electrically loose
Posted on Mar 06, 2009
My Kenmore Coldspot will not stop running and is getting too cold. The food in the fridge is freezing. Any suggestions to help me pinpoint the issue?
Either you have a cold control issue or a broken damper allow too much air into that section. I would look into the air control section, top left of the refer section. If the door doesn't close it will cause a freezing effect with this section to occur. I hope this helps.
Aug 31, 2014 | Refrigerators
Hi I have a Maytag model MFI2568aes my vegetables and fruit chillers are freezing everything. Chiller control is moved to the top which is cold, levers on chillers are far right. HELP. Gilbert cell...
Air is controlled by the damper located in the top portion of the refer section behind the ice maker assembly. Make sure the damper can open and close. If stuck open, this would allow air to enter all the time and cause freezing. Most likely the issue is found the the damper has failed to close when needed causing freezing. Double check the temperatures to the freezer, it can"t be any lower the -2 degrees, but you can raise it to 2 degrees to see if this corrects your temperature issue. The software was designed to bring in air from the freezer to produce ice first, then migrate to the refer section, if too cold for the freezer it would migrate into the refer causing freezing of veggies and produce.
I hope this information helps.
Nov 16, 2013 | Refrigerators
PSC23NSTESS FREEZING VEGTABLES
Side by Side ModelsIf foods, such as fruits and vegetables, in the refrigerator are freezing, it can be caused by several things. First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenheit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • If food in the bottom of the refrigerator is freezing, this could be caused by a refrigerator not having enough food to absorb the cold air.
  • If food in the door is freezing, move the door bins up or down so they are one notch away from freezer vents (Side by Side models only).
  • The fresh food control should be at the normal setting of 5.
Freezer on Top Models
First, check the controls. They should be set at "C" and "5" or "5" and "5". The proper fresh food temperature is between 38 and 42 degrees Fahrenehit. The freezer should be between 0 and 8 degrees Fahrenheit.
  • Since the cold air coming into the fresh food section originates in the freezer above, the rear of the top shelf will be the coldest spot in the fresh food area. Avoid placing delicate items that freeze easily on the back half of this shelf.
  • If food is freezing in the produce (fruits and vegetables) or meat pan, it may be that the temperature controls are not set high enough. Since cold air naturally falls, the pans can get too cold if the refrigerator is not running long enough to maintain good air circulation. Adjust both controls up one notch.
Nov 01, 2012 | GE CustomStyle PSC23NSTSS Stainless Steel...
FREEZER NOT FREEZING PROPERLY
There could be a large list of things that cause the freezer to warm up from the temperature it was before. The most likely reason is you probably have a defrost problem. Defrost heater, defrost thermostat and the defrost control are all things that may have failed. If your model is not a frost free let me know. Look inside freezer for a layer of frost building on the rear wall. If your refrigerator is not defrosting it will be a short time before the fresh food compartment begins to warm. To extend the time your refrigerator and freezer can keep food safe defrost by placing a bucket of hot water inside the freezer and close the door. Please place food from freezer and fresh food compartment into another refrigerator or cold storage area. By keeping doors shut as much as possible the refrigerator and freezer will last up to a week this way before defrosting again, Sea Breeze
Sep 12, 2012 | Hotpoint Refrigerators
Just recently, even at the lowest settings (to keep temps warm as possible) the refrigerator is so cold the milk and OJ is freezing. Any advice on what might be the problem?
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Jan 16, 2011 | Kenmore Side by Side Refrigerator
Fridge Too Cold
heatman101
Jul 31, 2010 | Frigidaire 16.5 Cu. Ft. Top-Mount...
FOOD ON MIDDEL SHELVES IS STARTING TO FREEZ
you need to send model number next time,cold air from the freezer is blown into the fridge section in this area,on some models there's a damper that controls this,the damper door doesn't close all the way when the temp.is cold enough still letting the cold air in and then food starts freezing.you'll see a tag with a model number on the left or right side up near the ceiling in the fridge section that will have the model number,you need this to order parts and to look up your machine
Apr 21, 2010 | Refrigerators
Refrigerator is too cold and freezes food.
Good day,
If the machine is under one year old, all working components are under factory warranty. Call for warranty service from selling dealer, or if you moved out of the area, an authorized Whirlpool warranty dealer.
Nov 25, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have the same refrigerator and the SAME problem. The freezer unit didn't work at first (for about a week) and then it started freezing solid with not way to control the temp. When that happened, the refrigerated section stopped working and has not worked since (two months). Help!!
May 27, 2008 | Frigidaire FRT21H8 Top Freezer...
Too cold in bottom section
Had the same problem and referred to another post regarding ice build up around the evaporator coils in the freezer unit. I had no ice build up but flat foil guard had dropped down across the freezer outlet which caused more cold air to be forced up into the lower section of the fridge. This caused the freezing of the vegetables.
Follow barkbugs steps first www.fixya.com/support/t970724-fisher_paykel_fridge_freezer and see if that is the problem.
Also while starting to remove items from the freezer check to see if something has moved back and is blocking the air vent. Even a packet of food may cause enough blockage. A slicker pad was also part of our problem.
Oct 31, 2007 | Refrigerators
Refrigerators Logo
116 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
