Question about Microsoft Xbox 360 Console
HOOKING UP XBOX 360 TO HDTV
IM HOOKING UP MY HDTV TO MY XBOX I WANT TO GET THE BEST PICTURE AND WHEN I GO TO THE SETTINGS IN THE XBOX I CAN NOT CHOSE THE HD SETTING, I WANT MY GAMES IN HD HOW DO I DO THAT AND WHAT IS THE BEST CONNECTION CORD SHOULD I USE
You have to use the regular red and white cords(not the yellow) and u have to use all 3 hd cords. If ur tv doesnt have a place to put the cords in, then it isnt HD. Also on the plug connecting to the 360, there is a switch that has HD and regular, switch it to HD. hope this helped.
Posted on Feb 19, 2009
How do I hook up Xbox 360 to the HDTV
Step 1:
Connect the audio/video input of the component cable into the "A/V" port located on the back of the xbox 360
Step 2:
Match the red, blue and green cables on the other end of the component cable to the corresponding component ports on your HDTV. If your HDTV has more than one set of component inputs, make note of which one you use.
Step 3:
Slide the switch on the component cable to "HDTV."
Step 4:
Turn on your HDTV. Set the video mode to the component port that will be used. HDTVs with multiple component ports will usually be labeled "Component 1," "Component 2" and so on
Step 5:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Choose the display setting (720p, 1080i and 1080p) that is best compatible with your HDTV. If you're not sure, try them all until you find the one that looks best.
Step 6:
Disconnect any previously connected A/V or component cables.
Step 7:
Connect the HDMI AV cable connector to the "HDMI AV" port on the Xbox 360.
Step 8:
Connect the other end to an available HDMI port on your HDTV. If your HDTV has more than one HDMI input, make note of which one you use.
Step 9:
Turn on your HDTV. Set the video mode to the HDMI port that will be used. HDTVs with multiple component ports will usually label them "HDMI 1," "HDMI 2" and so on.
Step 10:
Turn on the Xbox 360. Go to "My Xbox." Select "System Settings" then "Console Settings" then "Display" and then "HDTV Settings." Pick the display setting (720p, 1080i and 1080p) that looks best on your HDTV.
Dec 26, 2012 | Video Game Consoles & Games
My Xbox elite is just over a year old. I have no red rings. Problem is that all games played on the box are now in black & white. There is no colour on my tv screen. There is nothing wrong with the...
Check and recheck and triple check the av/hd cables. If you want to help isolate, try hooking up your xbox 360 to another tv and doesn't matter if it is hdtv or standard to test out. That method will give your answer quick to help isolate the problem. If you have hdtv make sure your adapter has the switch set for hdtv and not standard and then go in the xbox 360 dashboard system settings and see if it shows up for display. Good luck!!!
Please rate and comment!!!
Dec 23, 2010 | Microsoft Xbox 360 Elite Console
Turn xbox 360 on and no picture on tv, xbox lights up green but doesnt send video output. tv is hd and i have tryed hooking the xbox up to another tv, tryed using hd and regular video outputs, tryed new...
You may need to change your HD settings on the back of the console ( HD setting is actually on cord ) I had that issue when I first went online w/360 . If that does not help u know X box costumer support will repair any damaged system prob. no cost and does'nt take as long as they say.
May 10, 2010 | Microsoft Xbox 360 Console
New HDTV.. xbox 360 has no audio but has video
alright. make sure that your red, green and blue are all plugged in properly and that your audio plugs are also in there correct plugs. i think audio is red and yellow. correct me if im mistaken
Jun 10, 2009 | Microsoft Xbox 360 Console
Picture will not show
You might want to try the following:
1. make sure that the AV cable is not loose or incorrectly seated in both the Xbox 360 console and the TV
2. make sure that you have the correct AV cable for your TV, to verify that the AV cable is connected correctly to the Xbox 360 console and to the TV, disconnect the AV cable and then reconnect the AV cable to both devices
3. if you are using composite cables, do not try to set any HDTV settings because you may lose the picture
4. make sure that your TV is set to the same video broadcast system as your Xbox 360 console (PAL or NTSC)
Example:
- if your Xbox 360 console is an NTSC console, make sure that your TV supports NTSC
- if your Xbox 360 console is a PAL console, set your PAL settings to PAL 60
- if your TV has a type of picture compensation enabled, disable it
5. reset your Xbox 360 console
- Remove any discs from the disc tray
- Turn off the console
- Turn on the console
- As the console starts, press and hold the Y button, and then pull the right trigger at the same time
- The Xbox Dashboard resets the display settings to the default settings and then automatically restarts the console.
6. Do not take your Xbox 360 console or its accessories to your retailer for repair or for service unless an Xbox Customer Support representative asks you to do this
Mar 09, 2009 | Microsoft Xbox 360 Console
Xbox 360 Console, Faulty, NO DISPLAY!!??
What do you mean, no display? Is is game-related display issues? Have you checked the AV cable connection? Or is it about the settings? Is this the first time that you are going to connect your xbox console?
To determine whether the display issues are specific to a particular game, try playing a different game to see whether the same symptom occurs. Reminder, some Xbox original games that were released for the original Xbox console may show some display issues when you play them on the Xbox 360 console.
Next, make sure that AV cable is connected correctly to the Xbox 360 console and to the TV. To verify that the AV cable is connected correctly to the Xbox 360 console and to the TV, you can disconnect the AV cable and then reconnect the AV cable to both devices. Note: If you are using composite cables, do not try to set any HDTV settings. If you try to set HDTV settings, you may lose the picture.
You might also want to check your TV's settings because some display issues can be caused by how the TV is set up. To make sure that this is not the case, please check your TV's settings.
In your TV's settings, you should check the following:
- Make sure that your TV is set to the same video broadcast system as your Xbox 360 console (PAL or NTSC)
- If your Xbox 360 console is a PAL console, set your PAL settings to PAL 60
- If your TV has a type of picture compensation enabled, disable it
- If your TV's settings are correct, you may want to try using a different TV, if you have one available. Try connecting your Xbox 360 console to another TV to see whether the same display issues occur
Next, reset your Xbox 360 console. To reset the display settings to the default settings, follow these steps:
1. Remove any discs from the disc tray.
2. Turn off the console.
3. Turn on the console.
4. As the console starts, press and hold the Y button, and then pull the right trigger at the same time.
Mar 09, 2009 | Microsoft Xbox 360 Elite Console
How to hook an xbox 360 to direct tv
What do you have coming out of the xbox 360, HDMI or RCA? The same question for the direct tv?
Apr 04, 2017 | Microsoft Xbox 360 Console
Xbox 360 Elite compatible with 62' Mitsubishi HDTV?
I have it and it works great! For all TVs, the TV have to be on fixed settings on standard, dot-by-dot mapping, noise reduction off. The camera's exposure the same for both side-by-side shots. Just set it on standard and it should work...
Jun 05, 2007 | Microsoft Xbox 360 Console
Xbox 360 Elite connected to Mitsubishi HDTV Model No. WD62528
Hudeez: 1. Did you check your TV Menu Settings ?? 2. Also on the XBOX 360 Menu. Go to the SYSTEM MENU (PURPLE). CONSOLE SETTINGS and select DISPLAY. Then you'll find the HDTV Settings and pick your resolution for TV Set. Done....
Microsoft Xbox 360 Console Logo
727 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
