Question about Kenmore 24 in. 15689 Built-in Dishwasher
Htere is no power to the inlet valve - Kenmore 24 in. 15689 Built-in Dishwasher
  • Anonymous Feb 20, 2009
    no power at inlet valve
  • 117 Answers
Check the power coming to the dishwasher, circuit breaker. Look at the wiring schematic to see where power comes from first, the control the door switch.
  • Make sure door is closed and properly latched.
  • If delay start option is available, has it been set and is unit still in time delay before starting.
  • Check to see if cycle is set correctly (refer to Operating Instructions in the "Use & Care Manual")
http://tclaundryrepair.com/
Posted on Feb 26, 2009
Miele dishwasher doesn't start Shows inlet
I am working on a similar problem. You need to refer to different info depending on the model. Do an internet search on
2011-11-25_043923_g600__800_miele_service_manual.pdf
You will probably find a lot of "experts" blowing smoke but this should help keep them honest.
Jan 24, 2013 | Dishwashers
Tip
I get error IE on my LG dishwasher.
IE is inlet error, displayed when "Not reached to the normal water level in spite of 10 min. water supply"
Possible cause:
  • The Water Supply Tap is closed.
  • The Water Supply is shut off.
  • The Inlet Hose is kinked.
  • The Water Pressure is very low.(below 10 psi)
  • Inlet Valve is OK?
  • The filter of Inlet Valve is clogged by impure water.
  • The Hall sensor is OK?
  • The Impeller of Air Guide is bound.
Remedy:
  • Cut power by tripping circuit breaker or unplugging power cable for ten minutes.
  • Take action on Water Supply device.
  • Measure the electric resistance of Inlet Valve. (950-1300 )
  • Clean the filter of Inlet Valve.
  • Check the frequency of Inlet Water by the Test Mode.
  • Replace the Air Braker.
on Jan 31, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
No water entering the dishwashet
Check electic water inlet valve screen on lower left bottom of dishwaser, follow the inlet water line to locate the valve, turn off power, and water, reremove inlet water hose, and valve hose, check inlet screen for sand, wash as needed. re-assemble in reverse order,
Oct 13, 2012 | Dishwashers
When the dishwasher goes into wash mode there doesn,t seem to be enough water in the unit to spray out the arms. when i pour water into unit it works ok until its next cycle?
Hello, If your unit is not getting enough water inside of it one of the first things that you would check would be the water inlet valve. If you follow the water line going to the dishwasher the water line itself connects to the inlet valve. Using a multimeter you can remove the connection going to the solenoid to assure that the valve is getting power if the valve were not to be getting power then you would look at the float switch which is usually found to the right of the inlet water valve. If you do have power going to the valve yet you still do not have water flowing past the valve you will most likely need to replace the inlet water valve in the unit. If you have any further questions or you have a problem locating the inlet water valve message me back your make and model number of your unit and I will try to locate your schematic to show the location of the valve. Also if you do have any questions message me back those as well. Thanks again I await your reply Rick
Aug 31, 2011 | Siemens Dishwashers
VERY LOW WATER PRESSURE TO THE LOWER AND UPPER SPRAY ARMS. FILLS AND EMPTIES NORMALLY
Hello there:
i will post this solution in 2 separate post due to the length of it ok
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it. When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it. Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
ools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Step 1. Disconnect the dishwasher from its power source.
Note: Dishwashers are usually wired directly to the home's electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
Oct 16, 2010 | Bosch 24 in. SHY56A05 Stainless Steel...
Won't run. Sounds like the pump is running, but no water, no advance of cycle.
Check the water inlet valve first.
The water-inlet valve lets water enter the machine. First Check to see if the valve is getting water. Make sure it’s not clogged. There is a screen on the inside of the valve, this sometimes gets clogged up with debris. Check to see if you get power to valve when unit is put into operation may take a couple minutes to start a fill. If you have power and it’s not clogged up replace the valve .If you have no power to the water inlet valve check float switch. This can be done by checking the continuity. There is a video of this at www.appliancehelponline.com/servicemanual.html this will walk you checking the water inlet valve and the float switch. It may be a different model but the testing procedure will be the same. You can also enter your model # for diagrams and illustrations for most models.
Apr 09, 2010 | Bosch SHU9915UC Dishwasher
There is no water going into the dishwasher.
Apr 08, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
No water when turned on
IF WATER IS ON TO THE INLET VALVE AND THERE IS POWER TO THE SOLENOID ON THE INLET VALVE IT IS DEFECTIVE. IT SHOULD OPEN WHEN POWER IS APPLIED, THAT IS WHAT THEY ARE FOR.
Mar 09, 2010 | Bosch Dishwashers
IE problem
Possible cause:
Remedy:
Dec 23, 2008 | LG LDF8812 Stainless Steel Built-in...
LG Dishwasher ie error code problem
Possible cause:
Remedy:
Oct 31, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Kenmore 24 in. 15689 Built-in Dishwasher Logo
99 people viewed this question
Top Kenmore Dishwashers Experts
Fred Sops
D. E. Hev
Raisin Brann
Level 1 Expert
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
