Question about Roper RAS6233KQ Top Load Washer
Roper washing machine fail to remove enough water from clothes on spin
  • buzz345 Mar 15, 2009
    My Roper doesn't spin very fast at all. I've gotten into it and the pump and discharge hose is clear. My drain is clear. The discharge hose is in the drain tube about 4 inches. Wondering ......
I had the same problem, I found that my discharge hose was partially plugged and when the water level get down to a certian point it would not drain,
Took me 3 days to figure it out........
Posted on Feb 21, 2009
2 Suggested Answers
  • 198 Answers
SOURCE: my roper washing machine fails to remove enough
Possibly the centrifugal clutch is slipping, would need to be replaced, Go to appliance guru to see how this is done, they have step by step on this procedure.
Posted on Feb 19, 2009
Roper washer new will not fill with warm water on rinse cycle it fills and spins
if its only a new machine make sure transport bolts have been removed
Apr 09, 2014 | Roper Washing Machines
My 5 year old Roper washing machine fills up, washes/agitates the cloths, drains them when the washer get to the rinse line to start the rinse cycle it stops, and all I hear is a humming. The machine will...
I'm not familiar with roper washing machines so I'll ask the question does it have two fill hoses. Most European machines now only have one fill. If it has two then it sound like the machine takes the initial water from the one fill and the rinse cycle water from another. The humming sounds like the valve for the other fill needs replacing. These are quite inexpensive and easy to fit. Power off.. remove lid ....switch of water...take out valve when you establish which one is affected and replace
Oct 17, 2013 | Whirlpool WTW5700S
My washer spins but not enough to get the water out of clothes.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Feb 18, 2011 | Roper RAX4232KQ Top Load Washer
Roper rtw434osq0 not spinning/draining water
Set the timer to spin manually and turn it on.
Does it spin?
If not,
Your lid switch is bad and must be replaced.
If yes it does spin.
The timer is bad.
Mar 12, 2009 | Roper RAX4233PQ Top Load Washer
My roper washing machine fails to remove enough water from clothes on last spin every thing else seems ok model RAS 7133 KQ 1
Feb 19, 2009 | Roper RAS6233KQ Top Load Washer
Roper Wash Machine Model # RAS8333RQ4
check the switch under the door , it could be damaged , check with a multimeter at OHMS setting , if there any reading then switch is OK , if not try to clean it up with tuner cleaner , you can purchased at RADIO SHACK.
Dec 17, 2008 | Roper RAS6233KQ Top Load Washer
Agitator not spining properly to pull clothes down into water
remove agitator cap remove boplastic cover underneath remove bolt remove upper portion of agitator replace agitator dogs part # 80040
Jun 06, 2008 | Roper RAB2121KW Top Load Washer
Roper RAS6233KQ Top Load Washer Logo
94 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike Cairns
Mike Cairns
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
