Question about RCA 27F650T 27" TV
Service Menue I have a RCA model HD27F754T,I need to know how to get into the service menue. The picture is a little green. Thank You . .
    President:
  • 2,976 Answers
If you don't have a menu button on the front, you'll need the original remote.
Posted on Feb 19, 2009
  • 4,234 Answers
Getting into the service menu is normally discouraged unless you have the service manual. Even relatively simple changes such as those you wish to attempt need to be made in the correct order and fashion. A factory remote is required for this as there is a specific sequence of commands required. If the only problem is a slight tinting of the picture, this should be "fixable" using user level menu options. Please further describe the problem you are having and I'll try to guide you through the changes that are needed.
Thanks,
Dan
Posted on Feb 21, 2009
Hello how do i set the convergence manualy on a pioneer elite pro-710hd projection tv i dont have the remote and dont know how to bring the menue up on the tv
You MUST have the remote to perform service operations on the Elites. Look on ebay or do a google search for Pioneer 710 remote.
There is no way to manually do convergence without a remote, and no way to call up the convergence menu.
Feb 05, 2014 | Pioneer PRO-710HD 64" Rear Projection...
Good older rca tv favors blue green, red is weak. tint function doesent help this problem is there an adjustment inside?, where, turn down green blue or turn up red? jm
Hello; The red probably got low over a long period of time due to only one thing. The CRT/ Picture tube is getting weak and cost much more than the set sold for. The adjustments may only help a little and the set will get worse. These adjustments are done on your remote control with service menu accessed. You will need a Service Manual for instructions to do this, but I think it's time for another set. John
Apr 25, 2011 | RCA MM36100 36" TV
I need codes for a SONY TV for the RCA converter box. I cannot find the list that comes with the manuel. I need to reprogram the converter since the TV button and volume does not respond on the remote. I...
To Get The Code Please Go To Below Website:
http://www.rcaaccessories.com/remotefinder/
You need to select the following information from the drop down list
1.Model of the remote
2.Type of device to which you want to program(TV/DVD/VCR)
Thank you
Aug 02, 2010 | RCA Universal Remote Control
SERVICE MENUE acoustic solutions LCDWDVD19FB
Please i need your help, i have 50pieces of ACOUSTIC SOLUTION LCD TELEVISION, MODEL NUMBER ,LCD-1531B i need how to enter the service mode and the option to change the sound system from pal i to pal bg.THANK YOU.
May 27, 2010 | Televison & Video
Picture is wider than the screean
There is a service menu that techs can use to adjust vertical and horizontal widths. If it is not an aspect ratio problem then it is likely that it needs to be adjusted.
Apr 23, 2009 | RCA P46921 46" Rear Projection Television
Zenith sentry 2 tv
will probably have to take into servise center. will need to enter service menue and need service diagram.
Mar 13, 2008 | Televison & Video
My projection tv is srewed
The green has to be adjusted through the service menu. You may try moving the yoke ever so slightly, but if you do mark the position its in now so you can put it back if it doesnt help the green. You can adjust the horizontal and verticle skew through the service menue. but you probaly have a weak capacitor or open resistor that has caused your green to skew as that is controlled electronically.
Jan 20, 2008 | Televison & Video
Rcatv
I have found that this color wheel comes with a set of instructions that includes getting into the service menu and setting the index for the new color wheel. If the instructions were not with the color wheel, you will need the DVD for this model to find the information on entering the service menu and setting up the color wheel.
Jan 04, 2008 | RCA HD50LPW175 50" HDTV
RCA 27F650T 27" TV Logo
199 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
