Question about Creek 5350SE Amplifier
I have a creek destiny integrated amp left channel does not work and smell like a some transistor explode when i change the fuse happens again would you help me. thank you very much
4 Suggested Answers
petraman7
  • 1175 Answers
SOURCE: Proton 520 Integrated Amplifier with quiet left channel
Hi...
Flush all the switches and controls with De-Oxit D5 or better.
Then get back to me.
Thanks
Posted on Mar 01, 2009
Grubhead
  • 5309 Answers
SOURCE: Bryston 4b amp, left channel blows the back panel
I would check out whatever drives the left channel first. If it is a transistor, you can put a ohm meter on the terminals and see if it shows a short (amp turned off). If there are two transistors for the left channel, and you find a short on one only, replace the other to be on the safe side.
Posted on Mar 25, 2009
SOURCE: Creek 5350SE amplifer left Channel dead
It's the ribbon cable that is likely at fault. There are actually three computer type ribbon cables in the amp. I believe the cable that is responsible for the drop-out of a channel is the widest (longest) of the three, but you really need a tech to look at it and replace the cable. But please note that the new cable may also have defects in manufacture and that it may take some time to order a new cable from Creek. I had a tech solve the problem permanently by removing all three ribbon cables and then hard-wiring the connections together - that is to say, point-to-point wiring. My cost was about $250, but as you can imagine, there is extensive labor involved. Good luck!
Posted on Aug 13, 2009
How do you kill a captain level 121?
Your question makes no sense in this forum.
Oct 27, 2014 | Creek Destiny integrated Amplifier
We have an old amplifier from back in the 80's and 90's. Its 500watts, the right channels (both main and sides) work fine and loud, but the left channels produce very low sound. I checked the fuse and its...
Have you checked the final transistors on that weak channel? They may look fine but may be weak. You can pull them and check them on your multimeter with the diode check and cross it with the data sheet for that transistor.
Mar 07, 2011 | Kenwood KAC-5204 350 Watt Max Power Stereo...
Creek SE 5350 one channel without sound
I think you will find that the fault is either a dry joint somewhere (have you moved it recently?) OR more likely a transistor. It might be caused by one getting very hot! Thus shutting down and coming back on when cool.
The best way to track this troublemaker down is to spary each transistor (in the left channel only don't bother with the other or Power section) with Servisol Freezer spray. Wait for the thing to play up then spray -one at a time- if it pops on you have got the bugger! To make certain apply a soldering to it and it should act up again. Spray again to confirm.
Apr 11, 2010 | Creek Destiny integrated Amplifier
Amp powers up. the right channel works fine left not at all
If you didn't find any burned parts that would mean one of the buffer amplifiers before the power amp could have died. They could either be transistor based or opamp based. They are fairly low power so they will not explode like the output transistors like to do. Contact rockford, they should be able to send you a schematic. Let me know I will try to help you through it.
Dec 14, 2009 | Rockford Fosgate Punch 401S Car Audio...
Jul 12, 2009 | Creek 5350SE Amplifier
Mar 16, 2009 | Bryston 4B SST 2-Channel Amplifier
Denon AVC-A1SE in protection mode
The numbers of the transistors thay you need to replaced are on the transistor themselfs. Just take out the bad transistors and get the numbers that you need. I ALWAYS replace the output, driver and bias control transistor myself. One thing to keep in mind, if the number on the transistor starts with "A or B or C or D or K" you need to add "2S" in front of that number when you order it. Now that this problem has repeated itself, double check your wire and speaker. They can cause this problem.
Nov 09, 2008 | Audio Players & Recorders
Unit peavey xr 886 it appears my left channel output has gone down,could there be a switch iv'e turned off by mistake. (9 I have no manual) or a fuse possibly. or do I need an expensive repair.
your problem is in the power amp. section the right channel transistor there is defected already,thats why only the left is functioning,you better change it, so it works again ,only two transistor maybe 8 dollars each..
if my solution helps you ..rate me as FIXYA..
Jul 02, 2008 | Audio Players & Recorders
134 people viewed this question
Top Creek Audio Players & Recorders Experts
 Grubhead
Grubhead
Pieter Vleeshouwers
Pieter Vleeshouwers
ray gallant
Are you a Creek Audio Player and Recorder Expert? Answer questions, earn points and help others
