Question about Roper RAS6233KQ Top Load Washer
My roper washing machine fails to remove enough water from clothes on last spin every thing else seems ok model RAS 7133 KQ 1
  • maggieh007 Feb 19, 2009
    ROPER MODEL RAS7133KQ1
  • 198 Answers
Possibly the centrifugal clutch is slipping, would need to be replaced, Go to appliance guru to see how this is done, they have step by step on this procedure.
Posted on Feb 19, 2009
Roper RAS8333RQ0. If I put more than 4 or 5 pieces of clothing in it won't agitate or spin. I checked the lid switch and it seems to be OK, as it agitates just fine if the load is small enough.
A couple of ideas.
First, type in your model number to the web-site named: "SearsPartsDirect".
The schematics will show whether you have a drive belt on that model.
If there is, that belt may be slipping, or worn out.
Before you order a belt, consider this.
If the machine is not properly spinning out the water on the spin cycle, ( for example, if the belt were loose), then too much water may overload the machine causing your problem.
God bless your efforts.
Nov 27, 2017 | Roper Washing Machines
My Roper RAX 7245 KQ will not spin unless I physically start the spin process then it will "kick in" and begin to spin slowly enough to drain most of the wet clothes.....what replacement part do I need to...
Please forgive me but, my system went down for a moment. The tech data i pulled up is not giving me the part number that you need.
What you can do is call a sears service center and give them the model number of your washer and they will get you the right belt for your washer. please accept my apology again for the lost of connection. please be kind and rate and comment about your experience today with Fixya.
Jan 14, 2010 | Roper Washing Machines
Water not draining although spin still ok. Then went bang!
Called out a plumber who diagnosed that the machine was not worth mending. He charged me £25. Now have new Indesit WM.
May 23, 2009 | Bosch Washing Machines
Washer washes fine and the water drains but will only spin if you mess with the clothes making them perfectly balanced or you hand start the spin. Roper
sounds like the spin basket drive.. does it agitate ok? if yes get a new washer or change or get a repair man to change the spin basket drive.
May 02, 2009 | Roper RAB5232E
Very weak, slow spin. Fill, wash, drain seem OK.
MY EDUCATED GUESS IS THAT YOUR "DRIVE MOTOR TO TRANSMISSION COUPLING IS FAILING OR ABOUT TO FAIL COMPLETELY. GO TO www.repairclinic.com AND ENTER YOUR MODEL NUMBER AND PART NUMBER 1195967 THE FIRST PART IS THE CULPRIPT. THIS IS AN EASY PART TO REPLACE. TAKE YOUR PUMP OF BY REMOVING 2 RETAINER CLIPS THEN REMOVING THE OTHER 2 RETAINER CLIPS THAT HOLD MOTOR TO MOTOR TRANSMISSION PLATE IF ANY OF THE FINGERS ON THIS PART ARE BROKEN OR DAMAGED(CRACKED) REPLACE IT AND YOU'LL BE GOOD AS NEW. GOOD LUCK. OH BY THE WAY TO DO THIS EITHER LAY IT COMPLETELY ON IT'S BACK OUTSIDE OR FAR ENOUGH BACK SO THAT YOU CAN DO THE WORK FROM UNDERNEATH. EASIER LAYING DOWN AND OUTSIDE BECAUSE THERE WILL STILL BE A BIT OF WATER IN IT.
Apr 09, 2009 | Washing Machines
Roper rtw434osq0 not spinning/draining water
Set the timer to spin manually and turn it on.
Does it spin?
If not,
Your lid switch is bad and must be replaced.
If yes it does spin.
The timer is bad.
Mar 12, 2009 | Roper RAX4233PQ Top Load Washer
Roper washing machine fail to remove enough water from clothes on spin
I had the same problem, I found that my discharge hose was partially plugged and when the water level get down to a certian point it would not drain,
Took me 3 days to figure it out........
Feb 19, 2009 | Roper RAS6233KQ Top Load Washer
A small drip on front side where water comes out of machine
thats your pump. if it leaks all you can do is replace to solve problem.thats the white resvoir looking thing,its a pump
Jan 10, 2009 | Roper RAS8445KQ Top Load Washer
Roper Wash Machine Model # RAS8333RQ4
check the switch under the door , it could be damaged , check with a multimeter at OHMS setting , if there any reading then switch is OK , if not try to clean it up with tuner cleaner , you can purchased at RADIO SHACK.
Dec 17, 2008 | Roper RAS6233KQ Top Load Washer
Roper RAS6233KQ Top Load Washer Logo
100 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
