Question about Craftsman Air Tools & Compressors
I need a part for 25 gallon craftsman air compressor model # 919.165230
  • David Shaub May 11, 2010
    What part?
    Did you check with sears online?
    Did you check with your nearest Sears service center?
  • 398 Answers
Why won't it pump up past 40#?
If you don't have any air leaks, the cylinder head gasket is probably bad on the pump. Easy fix for less than $10. you can get the parts you need here:
http://www.mastertoolrepair.com/sears-craftsman-919195411-p-48270.html or ebay.com. For around $50 you can get the whole rebuild kit.
May 09, 2014 | Craftsman 20 Gallon Portable Horizontal...
I have a Craftsman 3.5 hp, 25 gallon compressor. The compressor runs fine, but will not build pressure. Tank has pressure from the last cycle so I know it is not leaking. The compressor runs but no...
Hi Jim,
Disconnect your main air supply from the comp head to the receiver/tank and see if their is a reasonable air supply to atmosphere.
If not check that air is being taken in by the head intake filter
John
Aug 05, 2011 | Craftsman Air Tools & Compressors
What is the torque specs for a cylinder head for a craftsman air compressor 150 psi 7hp 60 gallon
The spec is 25-30 ft lbs.
Here are the specs.
http://shoppingcart.msservicecompany.com/msservice_net/product_files/D22629/d22629.pdf
Oct 10, 2010 | Craftsman Air Tools & Compressors
Air pressure does not go over 25 psi I have taken the whole unit apart and check, relief valve,regulator,check valve. Pressure switch, Piston & Gasket. everything seem good I have taken the pressure...
Does it shut off at 25 psi or just keep running and never build more pressure than that? Also, did this come on gradually or suddenly? Also, was it being used regularly when it happened or had it been sitting for a while?
Mar 07, 2010 | Craftsman 1 Hp, 4 Gal. Air Compressor
Motor runs pressure stays around 25psi
if they are oilless compressors then the rings are worn
Jan 15, 2010 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I am looking for a manual for my 33 gallon craftsman air compressor
Hello, Follow this link, and put the model , and number of your compressor in the window. It will provide the manual and exploded diagrams you need.
http://www.managemyhome.com/mmh/owner_manuals/search?sid=MMHMxSearsx00019&query=113226640+CRAFTSMAN
Best regards, --W/D-- Please feel free to rate this solution......thanx!
Aug 01, 2009 | Craftsman Air Tools & Compressors
Craftsman 25 gallon compressor wont cut off
The pressure switch has snap action contacts that are opened by a diaphragm pushing against a spring mechanism. Unplug the compressor and remove the cover to the switch and look for the contacts. Make sure that they are not welded together from use. Move the on/off lever to see if they open and close. You may have welded contacts or broken mechanism within switch. A factory replacement is expensive, however if you are a tinker-er you can use a lower price generic pressure switch available on ebay. Switches are sold by pressure range, you need a 120#. Fittings may need tweaking. Enjoy
Dec 11, 2008 | Craftsman Air Tools & Compressors
Air Tools & Compressors Logo
225 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
