Question about Combi Centre DX - Mango
Baxi combi 80 e it takes 12 seconds after turning hot water tap on before gas ignites then 1 minute before water gets hot the central heating system works fine
  • johnayre1 Mar 19, 2009
    Mine was suffering from constant pressure drop.Plumber replaced pressure vessel/hot water storage.Cant understand now hot water in day and night .Not working in morning until heating has been on a while.
    Does the new pressure vesseel need pressurising via valve at top?
    Problem Solver:
  • 16 Answers
It could be a blocked hot water plate heat exchanger
Posted on Aug 17, 2009
My central heating turns off when i turn the hot water tap on. when i turn it off the central heating doesn't come back back on until i turn the power off and on.
Combi-boiler-turn hot water tap on/off and the heating stops for ...
singletrackworld.com/.../combi-boiler-turn-hot-water-tap-onoff-and-the-...
Combi-boiler-turn hot water tap on/off and the heating stops for 20secs ... hot watertakes priority over central heating so when you run the hot tap, heating is ... Yeah onmy worcester combi there is a diverter valve - it feeds either the heating or ...
My central heating works but I have no hot water - 24'7 ...
https://www.247homerescue.co.uk/my-central-heating-works-but-i-have-...
Diverter valves switch heat between the hot water and the central heating. When youturn your hot tap on, the diverter valve temporarily shuts off the water supply ...
Does your boiler keep switching itself off? Here's why ...
www.dhs-uk.com/does-your-boiler-keep-switching-itself-off-heres-why/
Jul 7, 2015 - ... Bathroom Suites, - Showers, - Wet Rooms, - Taps and Accessories, Information and ... Low water pressure can cause your boiler to turn itself off. ... boiler is not turning off, you aren't getting the amount of hot water you require. ... If there is air in your central heating system, then your boiler may shut down.
Feb 09, 2016 | Water Water Heaters
Boiler won't ignite for hot water unless heating is on.
If this is in a RV the propane monitoring valve may require more gas flow to turn on than the water heater requires. A central heating system requires substantial gas flow so when the monitoring valve opens to fire the central heating, there is enough gas flow to also fire the water heater.
Jan 26, 2016 | Water Water Heaters
Central Heating\which combi boiler?
HI right first i would look at a worcester greenstar combl
best you can get and you have full back up from worcester leave all rads with stats as they are i think you will have to remove one , the that would be the bath room also the greenstar comes with a clock bulit in these are on the worcester bosch web site i have been a gas fitter fot 30 years and this what i would go with a really good combi, you can also get awire less room thermostat for this hope this helps
Feb 01, 2010 | Desa International CBN30T Central Heating...
No hot water coming from combi boiler ( vailliant)
I have a BAXI combi Instant 105 HE bolier. It has been very cold for the past week and the hot water is not working (though the heating is). I have cleared the overflow flu pipe of ice but this has not solved the problem. Any suggestions?
Sep 16, 2009 | Combi Centre DX - Mango
Baxi 80 overheating on hot water circuit
thermostat on the gas valve needs to be replaced,, which you will probly have to change the hole gas vale ,, check on the parts and labor and if it is over 6 years old wheigh the diffrence between it and a new unit good luck
Jun 10, 2009 | Water Heaters
Re: combi boiler.
if you have hot water at the taps but the heating isn't working make sure the thermostat is set high enough for the boiler to run check the time clock settings are on.
if these are working it could be a faulty diverter valve switch not sending a signal to the boiler to run.
Mar 23, 2009 | Water Heaters
No hot water from combi boiler
i have a combie bolier when i turn the hot water taps on only cold water comes out central heating working fine can any one give some advise ?and can i fix it myself.
Jan 03, 2009 | Combi Centre DX - Mango
Re pressurise the BAXI DUO TEC COMBI 28 HE A
I represurised mine by the following:
1. unscrew the left hand circular tap all the way
2. slowly unscrew the right hand circular tap untill you hear the water coming through.
3. turn off both taps when pressure is good
Dec 28, 2008 | Kitchen Appliances - Others
Combi cutting out and overheating
is this a baxi 105? chances are you diaphragm has gone on your diverter valve. Or your diverter valve.
Do you will initially get a liitle hot water if your heating is on?
Dec 22, 2008 | Water Heaters
Baxi/Potterton wall hung fan assisted combi boiler
does the boiler come on when the hot water tap is run if not change the hot water flow switch or the diaphram in the hot water flow valve it may be split
Nov 02, 2008 | Combi Centre DX - Mango
Combi Centre DX - Mango Logo
423 people viewed this question
Top Combi Baby Gear Experts
Paul Carew
ray gallant
Are you a Combi Baby Gear Expert? Answer questions, earn points and help others
