Question about Frigidaire Heating & Cooling
Charging the system
I need to know how much refrigerant to charge a FS 5BO-018K Frigidaire system with. I have no manual.
  • 96 Answers
Look at the data sticker on the unit it will tell factory charge by oz
Posted on Feb 19, 2009
Is there a charge to ask a question?
Hello friend, I appreciate your post!
There should not be a charge to ask your question as this is a public site for assistance. I would be happy to assist you with the issue on your Frigidaire refrigerator, FRS26ZRFW1. -Matt
Oct 06, 2014 | Frigidaire Refrigerators
Wine cooler too cold
The 2 @ 47 degrees may be low in refrigerant gas. Refrigerators are design to operate with an exact amount of gas. When the gas charge gets slightly low the system will operate colder for a time and when the gas charge loses a couple of ounces the system stops cooling. Another cause may be the thermostat isn't operating properly and or the temperature sensing bulb may be too close to a source of heat.
Feb 09, 2014 | Frigidaire 35 Bottle Wine Cooler
Once I replace the compressor in my Frigidaire Top mount, how do I charge the system. The diagram on Parts-Direct of the new compressor and the bad compressor in my unit, does not have charging ports
so do you have all the necessary equiptment to replace the compressor,
torch?
silver solder?
refrigerant gauges?
vacuum pump?
refrigerant recovery system to remove chareg from old compressor?---THIS ONE IS MAJOR
A CFC CERTIFACTION ISSUED BY UNITED STATES DEPARTMENT OF ENVIROMENTAL PROTECTION AGENCY?
a charging scale ?
refrigerant oil compatable w/refrigerant you'll be using?
i am all for the can do people but i highly recommend on this one you call in a PRO
Aug 03, 2011 | Frigidaire Refrigerators
How to put freon in my p12A
This should only be performed by a trained service technician. Not only is this potentially dangerous to the untrained person, but there is also a high potential to damage the equipment further if not charged properly.
The charge is to be metered into the suction line up stream of the compressor (charge liquid only if a blended refrigerant is used).
Most self contained unites will not have pressure taps to charge yourself, the would have to be added and soldered in aftermarket.
If in fact you had pressure taps, you will need a set of refrigeration gauges. Refrigerant needs to be weighed in, usually in ounces for a small unit. Charge is critical on these types of systems, just an ounce or two off can make a very big difference. You also need to know what type of refrigerant the unit requires, this is usually found on the name plate of the unit along or near the refrigerant charge the factory put in.
Also, if the unit entirely lost its charge, it would need to be evacuated to a deep vacuum to get all of the air out of the system. Without doing this you are wasting time and money as air in a system will create very big problems.
Furthermore, you need to make sure there is enough oil in the system, and without giving a reason or amount of refrigerant lost from the unit it is hard to give you an exact plan of action.
Jul 11, 2011 | Friedrich P12A Air Conditioner
The delfield box 18672ptb has no tags andi need to know critical charge
my chart says 32 ounces of R-404 A. Remember, cap tube systems are charged by super heat and TXV systems are charged by subcooling or full sight glass if system has receiver.
Feb 01, 2011 | Delfield 18672PTB Commercial Refrigerator
My fridge is no longer getting cold, I was told to re-charge my refridgerator, but I do not know how to do this This model is 3 years old, and I`m not 100% sure it`s the right product, but it looks the...
recharging is not somethig you do but a cert tech . the refergent is special and so are the valves and guages . if too much gas you damage compressor and too little your in the same boat . now at 3 years if you do need charging then you need to know where did the gas go . does it have a leak and if so it needs repair of new gas won't stay in system .. i would get a second opp as this is a new frig and too young to need gas . if you need more help pls tell me model # and brand . and the real problem your having . this is like starting over . mm
Oct 26, 2010 | Frigidaire FRT21H8 Top Freezer...
The top rack of my frigidaire FFU1724DW5 does not get as cold as the other racks.
prob is poor door sealing of low ref charge .. this would cause the prob . ck door seal first . then the ref charge .. ,, mm
Jul 03, 2010 | Frigidaire FRT15B3A Top Freezer...
PLHS69EGSS1 Freezer not cooling properly but Frig is OK
This is one time you might need gas. Your freezer needs to be 20 degrees or less for the ice maker to work.
May 01, 2009 | Frigidaire PLHS69EGSS Stainless Steel Side...
I have a frigidaire model FRT21LRGW, the compressor was changed in 2005, evaporator& heat exchanger was changed in jan.2009. Last week apr.2009 the unit started giving problem AGAIN. Freezer and fridge not...
Possible leak in the sealed system. Make sure the technician pressurizes the system with nitrogen, changes drier, evacuates to 500 microns, then weighs in the correct charge.
Apr 23, 2009 | Frigidaire FRS23KF7AB Side by Side...
Need to know normal pressure for 134-a to recharge my refrigerator
Depending upon the way you charge it you could introduce air into the system. The lines need to be bleed before charging to make sure the refrigerant is in the charge lines and not air. Most folks that do not do this for a living make that mistake.
With air in a 134 system problems will abound. The only way to really charge a system is to use a vacuum pump to pull it down then charge to the correct lever in ounces as provided on the label of the refrigerant u purchase
Apr 17, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Heating & Cooling Logo
65 people viewed this question
Top Frigidaire Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
