Question about Dell Vostro 1000 Notebook
Dell vostro 1000 will not turn on
When hitting power button on, the notebook beeps once the pause then two beeps.  the screen does not turn on at all.
When I power up my laptop, lights flash, dvd driver is running, it appears to power up, but the screen is completely black.
Help, everything I need is on this laptop.
    Genius:
  • 2,035 Answers
Try to connect the external monitor on your laptop's vga port and check if it displays on the monitor works , if it displays then is the problem with the screen.You may need to get the screen serviced or replaced ,if there is no display then try to replace the ram to different slot and check ...if it works
Posted on Feb 19, 2009
    Guru:
  • 832 Answers
Hello there!
thanks for using fixya.com
I suggest that you do:
1. Turn off your laptop
2. remove the power adapter from the ac
3. remove the battery
4 then install your battery again.
5. connect the power adapters and plug it to power ac
6. turn on your laptop
If you have the same problem, try connection your laptop to a third party monitor, connect thru VGA port. Just to try if its going to display to another monitor or LCD screen.
If the same problem, you have a problem with your video card. then if its working to another monitor, then perhaps you have a lose connection from your own LCD.
You are right that the power is turning on and your laptop does have a power.
Better, contact your technician to check accurately your laptop and to do some testings on it.
Hope it helped you somehow.
Regards!
  • Dennis Jambalos
    Dennis Jambalos Feb 19, 2009
    hi again!
    is there any news about your laptop? did you troublshoot? anyway, don't worry your important files will be there. just make sure to do some tests and after that do some back ups.
    take care!
  • 679 Answers
There is a problem with the laptop battery or charger.
    Brigadier General:
  • 3,614 Answers
remove the battery for a while. then test the unit again
  • micromaster
    micromaster Feb 19, 2009
    if u can easily access the |apt0p mem0ry strip, try t0 rem0ve the
    mem0ry 0n the s|0t and wipe and c|ean the br0nze meta| and put it back
    again 0n the sl0t pr0per|y.
    |et me kn0w
Dell vostro 1000 power button press on..but lap is not working
unplug the power chord, take the battery out for 30 seconds. plug them both back in, restart.
Let me know.
tony
Feb 09, 2013 | Dell Vostro 1000 Notebook
I updated the bios on the dell vostro 1000 and it wouldn't start. The power light stays on and you can hear the fan. This is followed by a long beep and 2 short beeps while the screen stays black.
Hi alkeith...
Turn on the computer while tapping F8, this will take you into the Safe Mode.
While your in the Safe Mode you can do a system restore.
Restore your computer back to an earlier time when it was working before you installed the bios change.
Left click on Start>All Programs>Accessories>System Tools>System Restore.
This should solve your problem.
Please take time to rate me
Aug 05, 2011 | Dell Vostro 1000 Laptop Computer (AMD...
My dell vostro 1000 laptop's display ain
if i read this right, when you power up the laptop you get fan spin but no display ?, if you just get fan spin and the green power light and nothing else the you have a motherboard failure, if you get LED activity and it seems to be working but you only have no display the its more likely LCD failure, if you DO get activity try this : power off the system, press power button while holding down the D key, this will run the LCD BIST SELF TEST which will run through full colour screens if fails this test you will et a beep code, please bear in mind you will only be able to run that test if you get LED activity, if you dont have activity then the motherboard needs replacing
Oct 27, 2009 | Dell Vostro 1000 Mobile AMD Sempron...
Failure to power up
Check the cable and do power on self test(POST)
Aug 25, 2009 | Dell Vostro 1000 Mobile AMD Sempron...
How do you turn off numlock on dell laptop
try using the on screen keyboard which is available at Start -- All Programs-- Accesories-- Accessibilty -- Onscreen Keyboard..once u r there u can click off the num key from the onscreen keyboard.
Jun 07, 2009 | Dell Vostro 1000
remove the memory cards and wipe the golden ends with an erraser and than put them back in and issue will be resolved ... if that doesnt help... if there are more than one card than remove them again and reseat one card at a time and you will find the culprit and you have to change it and in case of one card you have to change that
Feb 09, 2009 | Dell Vostro 1000 Notebook
Update Dell Vostro 1000 BIOS now wont turn on, nothing on display
You may be in for some trouble, a failed bios update isn't always an easy fix. if you can find the cmos battery try to remove that for a few seconds. you will also need a disk version of the bios, download that from dell on another computer and copy it to floppy or cd and see if you can boot to that and reinstall the bios.
when you press the power button what happens, does it light up and run the fan? Nothing appears on the screen?
Dec 29, 2008 | Dell Vostro 1000 Mobile AMD Sempron...
Dell Vostro 1000 Notebook Logo
88 people viewed this question
Alun Cox
