Question about Kenmore Elite 45986 Front Load Washer
I have a Maytag Neptune front load washer, and I get a foul odor when the washer sits for a few days. Is this normal, if so how can it be fixed?
  • 188 Answers
It's not always normal but it does happen.
Run an empty, heavy cycle with "affresh", "washer fresh" or bleach with the hottest water available.
Leave the door slightly open when not in use to allow any residual water to evaporate.
Also make sure you are using HE (high efficiency) detergent and only about 2 table spoons for a full load.
Posted on Feb 19, 2009
My maytag neptune spins water out, the tub is empty but when you turn the tub manually you can hear water sloshing and the clothes smells moldy after washing
There will always be some residual water left in the outer tub after draining. This is normal for most washers. Purchase a container of Oxy-clean and cycle the washer a few times using hot water settings with a half-cup of Oxy-clean added to each cycle. This will help remove any organic matter left behind that might be causing odors.
Oct 15, 2014 | Maytag Neptune MAH5500B Front Load Washer
Water in the washer.
First I would have posted this in the washer section not the vacuum section. That being said:
This is normal for a maytag Neptune. There is a liquid filled balance ring on the Neptune washer drum. That is the sloshing you are hearing. The smell is from the water trapped between the door seal and drum. You can wipe down this seal with an old cotton towel or sock and then throw it in with your next load. Also, just leave your door open a crack after your loads are done and the water will evaporate and not sit and get moldy.
Jan 26, 2014 | Washing Machines
My Neptune front load washer has a foul odor. I have tried the HE tablets, wiping it, etc. but it smells bad. When I spin it with my hand, there is water in the background. How do I get rid of the smell?...
Add 3 cups of Sugar Soap concentrate. Then fill the machine and leave it for 24 hrs.
Then put it through wash cycle with no clothes.
If not fixed........machine has to be stripped apart and manually cleaned.
Oct 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
My Neptune MAH5500B has a terrible odor and I can hear water swishing when I manually spin the drum.
Pick up some Affresh tablets they are in the detergent isle,and the swishing you here is normal there is a liquid in the balance ring in the front of the tub that makes that noise..
Sep 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune washer has bad odor, city water.
There is no filter in your washer that would cover the odor issue.
The website link below will give you all the information concerning odors in a Maytag Washer
http://maytag.custhelp.com/app/answers/list/kw/odors/p/293/r_id/108284/sno/1/search/1/session/L3NpZC9RRDdZdDhEag==
Jul 18, 2009 | Maytag Neptune MAH5500B Front Load Washer
Sometimes there is water that fills in my washer after I use it. It does not happen right away but by the next day. I don't know the model but I do know this is an old washer....gold....I have had it for...
Q - My washer seems to keep filling  with water, the water keeps coming in the washer and going out the drain without the washermotor running.
A - This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
  1. Boot change helps
  2. Consumer Display Code Table on the Electronic Display Maytag Neptune Front load washer
  3. Free on-line repair manual for the Neptune washer MAH3000, MAH4000, MAH5500, MAH7500  ( Acrobat reader required )
  4. How to access the console on the mechanical timer models
  5. How to access the workings of the washer
  6. My washer door is locked and it will not open up...HELP
  7. My washer will start when I push the start button, but a few seconds later, it will shut off
  8. My washer will not pump out + pump noise problems
  9. My washer will not spin
  10. Odor complaints from the front load Neptune washer - mildew complaints + a new "freshen up" procedure
  11. Parts breakdowns/exploded of the Maytag Neptune front load washer ( mechanical timer models )
  12. Problem chart for MAH3000 & 4000 Neptune washers
  13. Readers repair tips
  14. Trouble shooting tips from the Neptune manual for MAH3000 and MAH4000 models
  15. Tips from our friendly engineer on changing the boot and re-installing that clamp and spring
  16. Tips on changing the washer belt  ( acrobat reader required ) Belt parts link
  17. Tips that show what components need to be checked/replaced if a certain resistor on machine control board is bad. It is as follows: Burnt resistors in Maytag Neptune washer models MAH4000 and MLE/MLG2000
  18. Washing one item in a front load washer
Apr 01, 2009 | Maytag Washing Machines
Maytag neptune front load odor
its better do a maintenance, or put it to wash without cloths, only water and clorox, and varsol with the max level (water)
Nov 12, 2008 | Maytag Neptune MAH5500B Front Load Washer
I have a Maytag Neptune Front Load Washer. It spins the water out of my clothes good, but when the Washer stops and I take my clothes out, when I spin the inside by hand I can hear water between the drum...
water sound when spinning by hand totally normal, they use water as a counter balance, built into tub assy. as far as the mod/midew odors a few things things can help, first make sure youre using an HE detergent(HE detergent specially formulated for front loading machines) odors can be attributed to excessive amounts of detergent not completely broken down during the cycles, leaving the door ajar between cycles will also promote better air flow through the unit. and lastly using this product. new to the market made just for the front loading washers .
http://www.affresh.com/home.jsp
Mar 23, 2008 | Washing Machines
Kenmore Elite 45986 Front Load Washer Logo
Sal De
fordexpert
 Brian Main
Brian Main
