Question about Compaq Presario Notebook
Screen darkens when i plug my charger i
I have compaq presario r3000....when i plug my battery charger in and my battery is low the screen goes dark....you can still see it but its darker
  • christos_kar Feb 20, 2009
    My problem appeared when i inserted an extra memory stick in the slot (not compaq memory) Then the neotebook couldn't start up, not even the xp and when i removed them the screen was dark. There is a background dark image. seems like the backlite light failure. Is ther any fuse in the screen power unit, the section drinving the EL lamps
  • Aenim4 May 11, 2010
    How dark you mean? is the backlighting still on but low or is completely dark?
    What operating system are you working with?
    Problem Solver:
  • 9 Answers
Remove your battery then place new battery
Posted on Feb 19, 2009
My compaq Presario 3000 laptop is not charging and every charger i buy for it frys over night.
Maybe the problem is not the charger.It can be the battery or the circle input from your laptop broken
Aug 28, 2013 | Compaq Presario R3000 Notebook
What is the factory setting of the bios password (after F10) on my presario R3000
if you cant remember the bios password simply make sure its plugged out remove the laptop battery locate the cmos battery and remove this for about a minute or two, then replace everything, this will make the bios reset and hopfully the password will be removed
hope this helps
Feb 20, 2011 | Compaq Presario R3000 Notebook
It keeps turning off, I have tried my friends power cord incase that was the problem but even with her cord it turns off, and just before that says that I need to plug the charger in even though it is...
ok sounds like your battery has gone bad.
try this test: remove battery plug computer into the wall.
boot computer if it boots up and stays on you will need a new battery.
Nov 13, 2009 | Compaq Presario R3000 Notebook
Compaq Presario R3000. Push power button and lights come on then goes dead before booting. Occassionally Windows will start booting the it goes dead. Any suggestions?
Either the power supply is putting out too low voltage or the power jack is bad.Try moving the ac adapter tip around while its starting up to see if it keeps it running or shuts it off.If it makes no difference try another ac adapter that does work for sure and see if thats the problem.If neither approach works,then the HDD may be seizing or one of the ram sticks may be bad.Some sort of hardware conflict can cause shut downs.You would have to take the bootstrap approach to narrow it down to one pacific component.
Aug 02, 2009 | Compaq Presario R3000 Notebook
Compaq R3000
r u mention for battery light?if is it true,then the light is blinking because of your laptop want to make sure the power supply charge that battery.if it is in charging condition,the light on.but if the light goes off,that mean, the battery is already full.
But when u use adaptor without battery, the light will goes off because no charging session is in progress which has same behaviour with battery full(during battery full,no charging session occur)
May 12, 2009 | Compaq Presario R3000 Notebook
Compaq Presario R3000 dim screen but not dark
Sounds like the auto-dim in the BIOS is set too low. Fortunately the Compaq R3000 allows you to adjust the brightness right from the keyboard. Hold down the [FN] function key while tapping the [F8] key will brighten the screen, while [FN]-[F7] will dim it. The settings are different for running on AC power and battery, so you must do each individually.
Dec 31, 2008 | Compaq Presario 700 470024-192 Notebook
Compaq Presario R3000 PC
Hi Tom,
It appears without looking at the laptop you have removed or dislogged the cable that goes between the motherboard and the screen. This is not hard to do they are very delicate. The only thing you can do is take it to a qualified service tech. i get these periodically in my shop too. Check the cable before you do so to see if you can reconnect it but be very carefull.
Be mucho blessed,
Mark
Jul 18, 2008 | Compaq Presario R3000 Notebook
Itermttit ac and battery power on laptop compaq presario r3000. ac sees to work fine and then goes to battery (battery discharges in less than 30 miutes) - mp
your are probably experiencing a short in your ac cable, the next time it happens wiggle the cable, if the ac pops up in the task bar stop using the charger and buy a replacement.
PS check the slot where the adapter plugs in the back of the laptop to see if its loose, if it is take to the repair shop.
compaq are known for tis problem.
May 26, 2008 | Compaq Computers & Internet
Compaq Presario Notebook Logo
228 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
