Question about Casio G-Shock GW300CA-1V Wrist Watch
I have lost the user instructions for setting up the G-Force Atomic Watch. I have no idea what DE, JUE, WIE means and after setting date time it reverts back to another time zone. Is there a manual or instructions available?
    Genius:
  • 2,035 Answers
Please use this link to get the manual ,but make sure you enter the four digit code behind the watch to the manual ..
http://world.casio.com/wat/download/en/manual/
Good luck...
Posted on Feb 19, 2009
    Brigadier General:
  • 3,614 Answers
Go HERE
  • micromaster
    micromaster Feb 19, 2009
    & also HERE
    PLEASE RATE MY SOLUTION HERE.
    THANK YOUI FOR USING FIXYA
  • 679 Answers
Do you need a book or a pdf file.
  • rockfixya
    rockfixya Feb 19, 2009
    download user manual from>>
    http://www.generalmanual.com/Watches-Clo...
    Thanks for using FixYa.
Tip
How to set your Global Atomic G-Force digital watch
This watch says "Strong Ideas" on the back instead of a 4 digit number.
Press LIGHT briefly and your LCD will be back lit for 5 seconds.
Press MODE to cycle through normal, alarm, dual time, and stopwatch display mode.
Hold MODE for 3 seconds to enable the radio to receive time signals. Once RC is activated, the watch will search for time signal automatically every day.
Hold LIGHT for 8 seconds to disable the RC function.
Press MODE, SET, and ADJUST simultaneously to reset the watch.
Press ADJUST while in normal mode to toggle year/time display.
Press SET while in year display to alternate Month-Day or Day-Month.
Hold SET for 2 seconds while in normal mode to cycle through world atomic radios (US/GB/DE/JP) push ADJUST to change, and SET to continue. Next the language will flash (GB/FR/DE/ES/IT). Next is DST on/off. Next, in order are hour, minute, second, year, month, day, and 12/24 Hr format.
(US only) Press SET to display timezone. The default is PA, use the ADJUST button to cycle through MO, CE, or EA as desired.
Press SET while in alarm mode to toggle alarm on/off.
Hold SET for 2 seconds while in alarm mode to change the hour and minute with the ADJUST button.
Press SET for 2 seconds while in dual time mode and ADJUST +/- 23 hours from normal time.
Press MODE to exit most settings.
Press ADJUST in stopwatch mode to start/stop the timer accumulatively.
Press SET to reset stopwatch to zero, or split measurements if timer is running.
Change the battery with a new CR2025 to prevent damage that low or dead batteries can cause by leaking.
Do not use solvents to clean the watch, use only a dry or water moistened cloth.
Do not use buttons when the watch is wet. Water may penetrate the watch and cause damage to it.
on Dec 31, 2011 | Watches
Need manual for g-force watch global atomic
Hi, Since you didn't specify the model or module number of the watch, try this link:
Take the four-digit module number from the back of the watch, enter it, and download a PDF of your watch setting-instructions.
I hope this helps you. Thanks, Bill
Sep 07, 2010 | Watches
How do I manually adjust the time or force the communication with the atomic timekeeper?
You can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals", watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Click on "search" and the download your instructions.
Mar 15, 2010 | Casio GShock Atomic Solar #MTG910DA1V...
On time atomic watch wrong time zone EXSV10+Talking+Watch I DON'T HAVE+instructions+owner+manual I need to set correct time?
The EXSV10 Atomic Talking Watch by On-Time sets itself to the official time standard of the United States government, maintaining split second accuracy. It can also literally "tell" you the time. It talks! The On-Time talking atomic watch also has daily alarm capability, and can be set to announce the time every hour.
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Feb 24, 2010 | Watches
Turn off alarm and how to set alarm
After a bit of searching I found a makers name for you. I trust that this is the make you have (I doubt if there is more than one!)
If you go to "www.accessible-devices.com/reizen.html", this is an instruction sheet for Reizen talking watches.
Jan 20, 2010 | Watches
Neeed manual for Invicta 4047 Atomic Watch
The Atomic watches set date & time automatically. The general instruction book applies to the alarm & chronograph features.
http://www.invictawatch.com/support_files/instruction_manual/Manual-HiRes.pdf
Jun 25, 2009 | Invicta Atomic Autotech 4051 Watch
Lost manual to set atomic 4045 watch
Unfortunately no. You will need to try contacting Invicta direct. Sometimes you can go to Invicta retailers and they will have some left over or they will have instructions for similar models.
Mar 26, 2009 | Invicta Atomic Autotech 4051 Watch
Casio G-Shock GW300CA-1V Wrist Watch Logo
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
