Question about Shure (LX287CC) Professional Microphone
I have a shure microflex mic condencer 150 the led does not work and the mic is dead. Does the mic need a battery if so how do you instal it.
    Prodigy:
    An expert who has answered 500 questions.
  • Shure Expert
  • 611 Answers
The mic does not need a battery. But it does require phantom power. Contact the mixer manufacturer to find out how to turn on phantom power on your mixer.
Posted on Jul 15, 2010
  • 35 Answers
Try using a mixing console with phantom power ( + 48 ). A condenser mic needs 48 volts to operate. The led should light when the XLR microphone cable is connected to a console with phantom power.
Posted on May 01, 2009
  • Mark May 06, 2009
    Try using a console that has phantom power(48V) on the channel. that should solve the problem if not the mic is damaged internally and needs to be sent in. Check the Shure website for repair fees.
I also, have a shure microflex 150 condenser mic. We use it at the pulpit of our church for 2 years at least. The mic went dead. I replaced the 185 cartioide cartridge but the mic is still dead. D
It sounds like somebody turned off the phanton power on the mixer. Bring the main volume all the way down and turn it on, that should resolve the problem.
Nov 09, 2014 | Shure MX418/S Microflex 18" Gooseneck...
Why.....my two brand new Shure pg27's are BOTH dead...can I be THAT unlucky?? Or just dumb. I'd RATHER be dumb, hopefully I'm doing something wrong....but I'm trying to record with them in my Zoom R16. No...
The Shure PG27's are condenser mics. They need power. Since the mics don't have a battery compartment then the power has to come from the mixing console. Have you switched on 48V Phantom power?
Aug 11, 2014 | Shure PG27USB USB Condenser Microphone
Shure 55 sh dead?
You are best to send the mic to Shure for repairs. They can certainly get it working for you. www.shure.com/service
Mar 24, 2014 | Shure 55SH Series II Professional...
My Shure mics work fine but two bodypacks are not working. Are there fixable parts in there?
Try switching mic's with known good system. The small diameter cable going to headset and lav mic's are easily damaged. If the mic feeding the bodypack is good, fresh battery, mute disengaged and channels set properly then it's Shure factory service time.
Feb 06, 2013 | Shure SLX1 Body-Pack Transmitter for...
We are using a Shure PG58 wireless mic. It worked very well for about 1 year and then it would work on/off. Even when we put new batteries in the mic it still just goes dead. Any suggestions?
Unfortunately, there are many, many things that can cause a unit to be non-functional. Try calling Shure to get it repaired, or call Delta Audio at 773-764-3634. Delta Audio also repairs older Shure equipment.
Jan 17, 2011 | Shure UT2 / 58 / PG58 Professional...
I have a shure ULX-1m1 transmitter with full battery but will not work. screen comes up green nothing on the display and the battery light is red, what could this be? and how do I fix it
First, sometimes LCD screens have an intesity/angle control and at extreme range of these characters are sometimes not visible. Check you manual to see if your unit might have such a setting.
Also this unit has some control lockouts so make sure it is unlocked so the automatic frequency selection can be made.
Verify the status of the LED in your manual. MANY Shure mics display the LED red when battery is low.
DO NOT trust a battery as being full because it is new.
ALSO DO NOT USE rechargeable batteries in these as the rechargeable battery does NOT produce 9 volts... usually only 7.2 volts (in spite of the labeling) which is insufficient and will give a low battery indication.
Sep 29, 2009 | Shure ULX1 Body-Pack Transmitter...
Shure 87a no sound
Send the mic to Shure for repairs. www.shure.com/service
Sep 12, 2009 | Shure Beta 87A Professional Microphone
Shure microphone MX418 microflex condenser 150
The mic requires phantom power from the mixer. Contact the mixer manufacturer to find out how to turn on phantom power.
Feb 19, 2009 | Shure MX418 Microphone
Shure T2 SM58 intermittent transmit
Two screws on the back of the battery casing, then prise out the battery tray (it's a detachable moulded tray in the mic body) using a small screwdriver in the slot near the power button. Under the threads of the battery cover is screw which holds in the PCB, unscrew this. Take the full mic head off (not just the ball, but an inch further down with the capsule in it), and remove the circlip inside. The PCB then slides out towards the head end of the mic.
Jun 06, 2008 | Shure T2 / PG58 Professional Microphone
Shure (LX287CC) Professional Microphone Logo
475 people viewed this question
Top Shure Audio Players & Recorders Experts
Michial Gueffroy
Ben Armstrong
Vito Vacirca Jr.
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
