Question about Casio G-Shock GW300CA-1V Wrist Watch
What does JUE mean on G-Force Watch - Casio G-Shock GW300CA-1V Wrist Watch
I cant replace to lid back on my timex watch properly.its a women's watch.stainless steel back.is there anything that im supposed to do to click it into place properly?
I had the same problem and tried everything. Here was my solution. Use a double-sided 2" rubber mallet. (Below is a photo of a similiar mallet.) Be sure to use caution while pressing with force. There is always the danger of cracking the crystal, however, my solution worked perfectly for me. I hope it does for you, too. Keep in mind that some watch backs screw on with a special tool, but if you snapped yours off, it should snap back on.
sandyjd.jpgStart by lying the watch, crystal side down, on a vinyl padded notebook. Also make sure you have it aligned properly with the stem.
  1. Place one of the rubber mallet heads over the watch back.
  2. With all your force, push down on the other end of the mallet's head.
  3. Voila, you should hear a slight pop and the back will again be secure on the watch.
Hope this helps and you are as successful as I was with this tip.
--Sandy
Sep 04, 2011 | Timex 40131 Wristwatch
The minute and hour hands are "out of sync"... the
The problem that you describe--misalignment of the hour and minute hands--would be fixed in the way you'd describe--the watch movement would be removed from the case, and the hands would be removed from their pinions and placed down more accurately. This is a relatively minor repair if you have the right tools, but it's not something I recommend for the average DIY person.
The first challenge is removing the watch movement from the case. Some movements drop out easily, but others are kept in place by the crown and setting stem. These must be removed in a way that they can be re-inserted. Simply pulling them out by brute force usually damages the internal set lever; different movements have different mechanisms for releasing the stem.
The second challenge is removing the hands. Attempting to "slide" the hands on their pinions runs a high risk of damaging the pinions by making one or both of them oval instead of round. Very little force is applied to the pinions, so even a slight distortion can mean that your watch will start to hang up at odd times when friction is stronger than the force being put out by the watch movement. Even worse, it's possible to break one of these little parts--they're very strong, but they're also very brittle. A tool called, naturally enough, a "hand remover" is used to pull the hands straight up off their gears; they're then pushed back into their correct place.
For a qualified watchmaker or watch repair technician, this is a simple and inexpensive repair that should take them only a few minutes once they get around to actually paying attention to your watch. Given the high risk of damage to your watch if you haven't done this before and if you don't have a hand removal tool, I would suggest that you outsource this repair instead of attempting it yourself. I have ruined more than a few watches in the course of practicing this repair; it doesn't take much force to damage these delicate parts!
May 26, 2011 | Lucien Piccard 26024 Wrist Watch
Tag Heuer "link" woman's watch-- can't open clasp!
You just have to pull with more force. Decent watch brands always make clasps very tight.
Apr 15, 2011 | Tag Heuer Watches
I have a Philip Persio watch which has Day/Date display. In the Day display window it shows "LUN"...what is that??
LUN is short for "Lunes", spanisth for Monday. You will probably have MAR for Tuesday, MIE for Wednesday, JUE for Thursday, etc...
Oct 12, 2010 | Watches
Battery replacement
do you mean you want to replace the battery for your watch?
This isn't a difficult task to carry out. Simply get a small flat screw driver, use the screw driver to open the back cover of the watch, then you will see the battery of your watch. Remove the battery and replace with a new batter, cover back the watch and that's all.
Note that you will apply force with the screw driver when you are trying to open the back cover of the watch.
Good luck.
May 18, 2010 | Casio Atomic Timekeeping Waveceptor Watch...
How do you open the latch on a Rolex datejust watch
If I understand right, by the latch you mean bracelet clasp. You just pull it by the crown. Clasps on ROLEX watches can be very tight, so, have to pull it with appropriate force. Rate me, plz.
Feb 08, 2010 | Rolex Datejust SS
Day of week has jue yesterday min what does that mean instead of having mon, tues, wed
You have day ring in Dutch, not the English. Try to find out if there is English by slowly turning (changing) days.
Rate me, plz.
Jan 08, 2010 | Watches
The back of my merona watch popped off and I can't figure out how to reinstall it.
Usually, it takes quite a bit of force to press the case back back on. I use a special tool, like a small press that has different size cups to properly fit the size of the watch. Even then it takes sometimes a lot of force to pop them back on. This can be very frustrating for someone like you self to do this. I would recommend that you drop by a store that does this. I am sure they would not charge you for this service. It's better than damaging your watch or raising your blood presure. Best of luck
Nov 05, 2009 | Watches
Casio G-Shock GW300CA-1V Wrist Watch Logo
278 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
