Question about HP Photosmart 8050 InkJet Printer
My HP Photosmart C5180 will not print black. there are no error messages and i have tried 3 cartridges, cleaned it etc, still nothing, i have to change the text colour to dark grey or any other colour to print.
  • 3 more comments
  • Anonymous Feb 22, 2009
    same stinking problem...got the message "color cartridge failed" with ink indicator at 80% and was printing in black & white for a while in the backup mode, but lately it wont print at all. This problem began only a couple of months after initial installation, so I am abit leary about buying new ink cartridge in light of the exorbitant cost. Hewlett Pocketed my money and now I am stuck with this P.O.S -- they ought to be brought upon charges!
  • shearor Mar 21, 2009
    identical to two existing posts
  • Anonymous Apr 01, 2009
    Same here! stinking printer my old 1 worked fine now i got the c5180 and its **** wil not print i tried everything.
  • Anonymous Apr 28, 2009
    Samsies
  • Anonymous May 19, 2009
    sMine will not print black either and I've replaced black cartridge 3 times and reset the printer with HP teck help. We got it to eventually print black only to have it stop printing several data later. Took same steps and I cannot get it to print today.
5 Suggested Answers
SOURCE: hp photosmart c6180
you are good at taking things apart and not destroying them, then the problem can usually be fixed easily.
Remove the ink carts.
on either side of the carrage there is a screw, remove both of them.
CAREFULLY slide out the silver bar those screws are holding. Be sure to note its orentation for putting the thing back in later.
also carefully remove the silver "fingers".
remove the black clip/cover on the right side of the carrage that covers the ribbon cables.
lift the head (you see 4 nipples in there-- that is the top of the head assembly)
gently pull out the ribbon cables.
on the bottom of the head is 2 screws, remove them
now the head will come into 4 parts. Nipples, Gasket, nozzle block, and a metal guard.
get some windex with amonia.
soak the parts for a day or 2.
blot dry, then let it set for atleast 2 days to be sure it is COMPLETELY dry.
reassemble, charge the ink, do the printers head cleaning, and boom. back in business.
this works 90% of the time
Posted on Feb 09, 2008
SOURCE: HP Photosmart C5180 will not read new ink cartridge
Same problem with the yellow cartridge, tried pulling power cable out and removed all cartridges then power on and reinstalled carts.
No change. On the way to take it back to the retailer I dropped by Cartridge World and by off chance asked about the printer, they ended up weighing the cartridges and discovered my new cart had no ink in it. A new cart fixed the problem much to my relief.
Posted on Mar 28, 2008
  • 133 Answers
SOURCE: Black ink not working on HP C5180 Photosmart
Try a hard restart, which simply means unplugging the power cord of the printer, and replugging it after one minute has passed. If that does not work, then rerun the CD used to install the printer. Both techniques reprogram the electronics, to a certain extent.
You can also visit the HP website, to see what solutions are being offered for various printer problems. They probably have a number to call, in case you need to talk to a technician.
Hope these suggestions help you out.
Posted on Jul 04, 2008
professor_sc
  • 180 Answers
SOURCE: Ink System Failure HP C5180
this type of error message is related both with the printer and the ink cartridge. You may need to change your ink cartridge that you have purchased. Or you can reset the printer. I will give you instructions on how to make a reset on the printer if changing the ink cartridge will not resolve the problem
Posted on Dec 04, 2008
rajeshpait
  • 542 Answers
SOURCE: HP C5180 photosmart keep turning off and on. Will
This is due to ON/OFF switch is having the issue. Repair/replace the switch with the help of expert engineer/service center experts will resolve your problem.
Revert back for more assistance.
Posted on Jan 29, 2010
Testimonial: "helpful thanks"
My HP C5180 All-In-One printer says full ink cartridge is empty
Hi!
There are two ways to make your cartridge work again.
The first one will be basic....turn on the printer...remove the black cartridge from the printer.. using a moisten cloth, clean gently the contact terminal of the cartridge..after letting it air dry for a couple of seconds return the cartridge.. then try printing again..
The second one is to reset the ink cartridge.. how?
1. While your printer is on.. disconnect the usb cable from the back of your printer.
2. Remove the cartridges.
3. Wait until the message "Insert Cartridge" display on the control panel.
4. Disconnect the power cord from the back of the printer.
5. Wait for 60 seconds.
6. Plug the power cord at the back of the printer...If printer does not automatically on..press the "Power" button.
7. Reinsert the cartridge and close any open doors of the printer.
8. If prompted to Calibrate, do so..
9. Reconnect the usb at back of the printer...and try printing again..
After that you can print easily.
If you find this information helpful....Please rate this solution and vote on this on the YES below..thanks..
Jun 02, 2010 | HP Photosmart C5180 All-In-One InkJet...
0xc18a0005showing up on my photosmart c5180 al in one printer. How do I fix this
Hi it not same code but it may clean it off for you.
I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. Error 0xc18a0201 with HP printers Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
1. Without turning off the product, disconnect the USB cable from the rear of the product.
2. Remove the cartridges from the product.
3. Wait for the 'Insert Cartridges ' message to display on the control panel.
4. Disconnect the power cord from the back of the product.
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
7. Reinsert the cartridges, and then close any open doors on the product.
8. If you receive a prompt to print a calibration page, do so.
9. Reconnect the USB cable to the rear of the product, and then try printing again.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 01, 2010 | HP Photosmart C5180 All-In-One InkJet...
My HP Photosmart C5180 printer keeps coming up with an error message 'Ink System Failure. Does anybody know what is needed to solve the problem.
The "Ink System Failure" error is causes by air in the ink feed tubes. We have a step by step guide purging the air from the feed tubes posted on our web site. Go to our site at: www.ccl-la.com, click on the printer repair link and then the HP link. Follow the steps and you should be back printing in no time at all.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Nov 01, 2009 | HP Photosmart C5180 All-In-One InkJet...
I have a 13 month old HP Photosmart C5180 which is now displaying the following error message, "Ink System has failed. Unable to print.." Error: Oxc18a0506. The help message suggests "turn power off then...
your second set of catridges mush help you,, and also,, it seems that your operating system is corrupted,, its better you reinstall the printdrivers first,, if problem persists,, then try reinstall of windows..
Sep 28, 2009 | HP Photosmart C5180 All-In-One InkJet...
My HP Photosmart 2610 All in One has an error message reading "Remove and check cartridge on the right." I did it three times and there was nothing wrong. Any ideas?
IT seems to be fairly common issue with HP printers.
Try this:
Remove the power cable from the back of the machine. Wait 30 seconds. Press and hold the POWER button on the front panel.
Reinsert the power cable in the backside of the unit.
Print a test page. If the problem persists, replace the cartridge.
These printers have a cartridge check feature. If it detects cartridge contact problems such as dirt, dust or oil on a contact, it will give warnings so the user can correct them by properly seating the cartridge and/or cleaning the contacts.
Jul 28, 2009 | HP Photosmart C5180 All-In-One InkJet...
Incompatable Ink Cartridge HP C4480
Cartridge failed try another new one.
Yea it is new and should be good but they are machines and are prone to failure too.
Jul 24, 2009 | HP Photosmart C5180 All-In-One InkJet...
I have an HP C5180 that is showing an message Error 0xc18a0301, Ink failure. Tried the HP fix of removing cartridges, turn off/on nothing work. Any ideas
Hi I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
5. Wait 60 seconds.
Jun 30, 2009 | HP Photosmart C5180 All-In-One InkJet...
Hp photosmart c5180 ink system failure
Hi ok then try I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
5. Wait 60 seconds.
Apr 20, 2009 | HP Photosmart C5180 All-In-One InkJet...
Hello can you help me in a Printer problem in HP
Hi how about trying I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
5. Wait 60 seconds.
Apr 09, 2009 | HP Photosmart C5180 All-In-One InkJet...
HP C5180 PRINTER ERROR
Hi ok try I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
5. Wait 60 seconds.
Nov 09, 2008 | HP Photosmart C5180 All-In-One InkJet...
HP Photosmart 8050 InkJet Printer Logo
824 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
