Question about Lanier P165 Handheld Cassette Voice Recorder
Lanier P165 wheels not turning
If the wheels on the Lanier P165 are not turning any more....is it worth getting fixed??
2 Suggested Answers
SOURCE: I need a user manual for the Lanier P165 Voice recorder
I need a manual, too; however, I may be able to take an educated guess at some of your problems.
To get it to work (after trouble-shooting for battery issues, etc.), you simply slide the long "button" up and down. There are four settings -- all the way up is "record," then under that is "stop," then "play," and finally at the bottom is "rewind," which it does audibly. The two buttons beneath that are FF and eject (just below FF).
On the other side, there are four switches -- The top one adjusts microphone sensitivity from dictate to conference, the next one is tape speed (higher number means better quality but shorter time on tape), then the VOR on/off switch (voice-operated recording) which would start and stop the recording as you speak into it. Then below those three is simply the "on/off" switch for the whole recorder, so it doesn't accidentally get turned on in your pocket and you unintentionally record something.
On the top appear to be a few input jacks, one for a mic I guess and maybe other is for a speaker or headphones? Then there's the mystery button, that is labeled something like "# | / AFF." I have no idea what it does, but it may be to assign your counter number (counter and reset button on the front face of the machine) to a specific tape, so you can change tapes and return later to your first tape again without losing your place. Just a guess.
Here's some info I found on a seller's website - it served as the basis for some of my guesses above: http://www.martelelectronics.com/p165lp.html.
Posted on Jun 11, 2008
You can not tell me what setting to use on LANIER P-165 so that i can record someone and how far from them
If you want to record somebody 3-4 feet from you then use the dictate mode. If you want to pick up voices in a large room then use the conference mode, it increases the microphone sensitivity to the maximum level.
Jul 01, 2013 | Lanier P165 Handheld Cassette Voice...
Where can I locate a drum for an old Lanier 5235 copy machine and how much? Or is it worth it?
Your Lanier is made by Ricoh and is a model Aficio 355. The drum and drum cleaning blade is still available and not too expensive at about $200 for the pair. You can find these with all the related info at precisionroller.com Great people to deal with and I order a LOT of stuff from them.
Their part numbers are P8150 for the drum and C5950 for the cleaning blade.
Good Luck and Thank You for using Fixya.
Jan 19, 2011 | Lanier 5235 Printer
Lanier 5645 SC322 Error
It's most likely your Laser diode (LD unit). You're going to require a tech...see the posts the following link for the same problem. It's for a Ricoh model, but your machine actually is a Ricoh Machine (Ricoh owns Lanier), and is virtually identical to this one -just a generation older.
http://www.fixya.com/support/t1936988-sc_326_322_329_in_af2045
Apr 07, 2009 | Lanier Office Equipment & Supplies
Speed on Lanier P-165 keeps changing. How can I fix it?
There is a fast play switch on the side of the unit. That switch may be failing. Try moving it back and forth repeatadly to clean up the contacts.
Jan 26, 2009 | Lanier P165 Handheld Cassette Voice...
HELP!!!!
The only people I know that can still fix old Lanier machines are clearvoice@cox.net.
They are trained on Lanier and worked there for many years.
Dec 05, 2008 | Lanier P160 Handheld Cassette Voice...
Lanier P165 recorder instruction manual
The Lanier P-165 has a slide switch on the side for master power off / on. Also the battery contacts get flattened over time, a letter opener can help you get these sprung back out to make contact with the battery. Anything more than that consider it toast, serious professional tape units havnt been made in 4 years now. Its all digital now.
May 21, 2008 | Audio Players & Recorders
May 06, 2008 | Lanier P165 Handheld Cassette Voice...
Lanier P165 Handheld Cassette Voice Recorder Logo
57 people viewed this question
Top Lanier Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Lanier Audio Player and Recorder Expert? Answer questions, earn points and help others
