Question about Linksys SPA942 IP Phone
Cannot transfer calls from one phone to another.
  • knightline Apr 23, 2009
    I can transfer calls from one SPA942 to another but not to a Siemens Gigaset phone.
Is there a way to transfer phone calls from this phone?????
yes, you should have a transfer button on the phone. click that then type the phones extension to which you which to transfer the call and hit transfer again
Apr 16, 2010 | Polycom SoundPoint 330 IP Phone
How to use the to transfer phone calls
Call transfer on Norstar phones works by:
  1. Answer call
  2. Press the [Feature] [7] [0] (or simply press the [Transfer] button below phone display)
  3. Dial the number where you want to transfer the call
  4. Stay on line if wishing to speak to the person
  5. Press the [Rls] button to complete the transfer
  • If an external call is transferred to a busy internal or network extension, or is not answered after a few rings, the call automatically rings you back.
  • Note: Use Link to transfer callers to a telephone number
Oct 01, 2009 | NorStar Meridian M5009 Phone (NT4X35)
Can I transfer voice messages to a cell phone
Yes and no (or maybe)
Your Norstar system is capable of outbound call transfers... transfers to people outside your phone system.
Most instances, the programmers shut off this feature of out bound transfers to protect your system from fraud.
A programmer will be required if you need this feature to work.
Otherwise, try this... outside caller calls in, (you want to transfer caller to a cell phone), press the TRANSFER button, pick an outside trunk (Line 2), and dial out, when you hear ringing, hang up.
The call will be transfered to the cell phone.
Aug 14, 2009 | NorStar T7316E Corded Phone
Transferring Calls
press transfer button
call the transfer extension
wait until the person picks up
tell who is calling
hang-up to finish transfer process
Feb 23, 2009 | Lucent PARTNER18 Corded Phone
CALL TRANSFER
Go to Settings from the menu options. Select it, then select Call settings. From call settings, select call transfer or divert call. There, you will be able to activate call transfer to a specified number.
Aug 12, 2008 | Meridian Two-Line Corded Business phone
Transferred calls
sounds like the phone transfer numbering is out of sync or someone thinks its funny to send there transfered calls
i would go with the lessor of 2
phone numbering extensions example=
say you want to call someone at 2430 ext. but it takes you to 2340 that would be phone interupt extention box
the phone company who installed the software should come out and make sure the extensions are to the correct offices its there service but you pay for quality service to know and see it works
to send back calls just transfer back to secretary switch board the secretary will know what to do
May 07, 2008 | NEC Dterm DTP 32D-1 Corded Phone
Transferring incoming calls
Press transfer then dial 9 plus the phone # you want to transfer to. If this does not work , you may be restricted in software from trunk to trunk transfer.
Mar 28, 2008 | Comdial 8324S-PT Corded Phone
Call retrieve and call transfer
press recall key plus the extension number then you can transfer the call
Dec 04, 2007 | Siemens Euroset 2005 Corded Phone
Transferring calls-- transfers too quickly
You are transferring calls from your cell to your landline? Need more info.
Cynthia
Nov 04, 2007 | Motorola Mobility RAZR V3
Linksys SPA942 IP Phone Logo
265 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
