Question about LG DLE2512W Electric Dryer
Cracked Drum on LG Dryer... is there a newer drum available?
I have a cracked drum on an LG DLE2514W and need to replace it. The replacement part is 3045EL1002D but I was wondering if 3045EL1002E or 3045EL1002F were newer versions of the drum that are stronger or have better welds. I would like to replace it once and not have to do it again.
Thanks,
Mark
  • Anonymous Mar 27, 2009
    LG DLE2514W. I have the same problem with a 3.5 yr old dryer. Cracked at the weld. LG will not stand by their product. The say it is out of warranty so, tough luck. If your dryer is thumping. Get it checked ASAP while on warranty.
  • Anonymous May 23, 2009
    DLE2514W and have the exact same issue. $200 for part $300 for labor and LG says I am on the hook for this. I am tossing this out and buying a samsung (lifetime warranty on the drum).
5 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: Cracked Drum on LG Dryer Model #DLE2512W
If you are still looking for information on this:
No, there has not been any recall.
It is not a real common problem. I only see 1 or 2 a year, which is not many. (LE errors on washers are much more common, for example) The part number of the drum for a DLE2512W dryer is 3045EL1002D and lists for just over $100. You can find a service center to order the part from (in the US) at http://us.lgservice.com/index_b2c.jsp
I would rate the repair at about a 5 or 6 out of 10 on a scale of 1-10 in difficulty. (Basically, remove top, remove front control panel, remove front panel, remove front drum support, remove belt, drum comes out the front, reassemble.)
Posted on Jan 21, 2009
  • 5 Answers
I had a 2514 with a similar problem. Cracked drum. This is what I did to fix it. With the new drum. No noise at all.
Ordered drum from Sears parts. 3045EL1002D
Cost of 85$ + 15 to ship. It came in 5 days.
Here is how to do it on a DLE2514W. Takes about an hour. I only used a phillips screw
driver. Take your time and look over the situation. I hope that I rememberd
everything. Good luck.
Dryer Drum Repair
Dryer Drum Repair
1. Remove L bracket with 6 screws at the top, rear.
2. Slide top back 2 inches to unlatch and remove.
3. Remove control panel with 2 screws at top, inside corners.
4. Carefully unplug 4 plugs from back of control panel.
5. Looking at inside at the top. Remove wiring bundle from 2 guides.
6. Unplug wire from dryer light.
7. Open dryer door and unscrew 2 screws behind door just below lint trap.
8. Remove 4 screws at top of front panel that holds the door.
9. Lift up front panel to remove. I couldn't get the door switch plug to disconnect
so I carefully rotated it an set it on top of the dryer.
10. Remove upper case bracket with 2 screws in front and 2 screws inside at top.
11. slide up a bit to unlock from sides. Watch routing of dryer switch wire bundle.
12. Remove lint trap duct with 2 machine screws. Carefully slide down to remove.
13. Remove front drum support with 4 screws attached to sides. Lift up to disengage
sides. Lift drum to free from rollers.
14. Observe how drive belt is routed around motor and tension roller. Push tension
roller up and release belt. Carefully take belt off and remove.
15. Almost done. Lift drum up at rear to free from rear rollers. Remove.
16. While your're there vacuume up dust and reverse procedure to install.
Posted on Apr 02, 2009
SOURCE: LG DRYER MODEL DLE3777 CRACKED DRUM,,CAN I JB
you need take out for weld it and pulish all weld.
Posted on Oct 06, 2009
MNTECH
  • 1543 Answers
SOURCE: cracked drum lg tromm dle2512w
I'd say yes, especially if you replace it yourself to avoid a service call. Top needs to come off (screws at back, then push top back 2 inches and lift off), remove front, remove 4 screws holding front bulk head / front rollers, slip belt off tension pulley, remove drum, reverse to install.
Posted on Sep 25, 2010
There is a hole in the inside drum of the dryer
LG is responding to the complaints of cracked drums in their entire LG dryer line up by offering a replacement for the cracked drum part for free.
NOTE: This will only apply if you have an authorized LG servicer replace the drum for you. The labor is not covered so you will have to pay for the labor to have the drum replaced. You can call LG customer service at 1 800 243 0000 for more info.
Read more: http://appliancejunk.com/forums/index.php?topic=8308.0#ixzz28L6qVgMh
Oct 03, 2012 | Dryers
With my dryer the drum is cracked at the back and making a lot of noise what can I do
When the drum is cracked there is no option but to replace it.
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 20, 2011 | LG DLE2532W Electric Dryer
Dryer makes a thumping sound with or without anything in it
Look for a crack in the seam, where the stainless steel drum is welded together, either at the front or back edge of the drum. If weld is cracked, replace drum.
Jan 31, 2011 | LG D5966 Gas Dryer
WE HAVE HAD THE LG DLE2532W DRYER JUST OVER THREE YEARS. RECENTLY, WE HAD TO REPLACE THE DRUM BECAUSE IT HAD A CRACK IN IT. NOW THE REPLACEMNT DRUM (FOUR MONTHS OLD) HAS A CRACK IN IT AND THE DRYER IS NOT...
Here's one place you can order a new drum. However, if the drum has cracked twice in four months you need to find out if there's something else with the dryer that's making the drum crack. You also need to think if you're doing something like putting shoes in there or something that's stressful on the dryer.
Nov 01, 2009 | LG DLE2532W Electric Dryer
LG DLE2514w electric dryer has loud thud every turn
Most model dryers are supported at thge rear of the drum with a bearing configuration, but usually the front of the drum is supported by some lining pads or guides. These help hold the rotation of the drum concentric. It sounds like your drum is not spinning concentric. My guess would be that some new guides might need to be installed.
Hope this helps...
Sep 02, 2009 | LG DLE2514 Electric Dryer
LG DRYER MAKING CLUNKING NOISE
Clunking could be from bad rollers or cracked drum. Check the drum seam for a crack. If its the rollers you can do the same thing as drum replacement only order the rollers. I got my parts from Sears parts. The below is for a 2514 but should be close for yours.
Dryer Drum Repair
Dryer Drum Repair
Feb 10, 2009 | LG DLE2515S Gas Dryer
Dryer Drum Repair
Dryer Drum Repair
Did you resolve your dryer / noise?
You have a problem with your dryer drum.  The seam weld has cracked and the drum needs to be replaced.  You will need to call a qualified LG technician to resolve this issue.
Apr 15, 2008 | LG DLE2532W Electric Dryer
LG DLE2512W Electric Dryer Logo
496 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
