Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Sears auto garage door opener not opening and closing properly
I have a Sears Mastercraft Automatic Garage Door opener , not sure how old it is but it does give me problems closing and opening..closes for about a foot or so then it opens back up...and when it comes to opening it only opens about a foot or so and then it stops.
Hope there is some kind of adjustment that can be done...it does it more when it is really cold out but it also did it ocasionally when the weather was warm.
Thank you
RMC
    President:
  • 3,197 Answers
Remove the cover and check the drive gear. It is a white nylon gear and just may be stripped. Also on the rear of the motor unit near where all those white wires go you will find the up and down force adjustments. Increase both of these a 1/4 turn and check.
Posted on Oct 05, 2009
  • 25 Answers
There are little knobs on the back for adjusting up and down turn them up and you should take care of your problem.
Posted on Oct 03, 2009
Auto garage door opens will not close not the sensors
Look at the back of the motor unit and see if that little light is flashing a code. Post the code.
Aug 13, 2012 | Sears Craftsman LiftMaster Chamberlain...
I have a Sears craftsman model 139.53637SRT garage door opener. My remote has not worked in a long time. I use the wall control button and have to hold the button in order to open or close the garage door....
It sounds like your door sensors may be bad or misaligned. Make sure the small light on each sensor is lit and not flickering. That could be the cause of your having to hold the wall button down until the door is closed. You can buy a universal remote but if you only had one remote before it could be the receiver that has quit. A new remote would not fix that but the only way to find out is to try.
Aug 15, 2011 | Sears Craftsman LiftMaster Chamberlain...
We can't close our garage door
Make sure neither light on the sensors is flickering. Tweak them a bit to make sure they are aligned properly.
May 16, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door doesn't open and close properly
Loosen the chain enough so that you can remove it from the sprocket above the motor unit. With the door closed run the motor until the sprocket turns clockwise and stops. With everything attached replace and tighten the chain. Some adjusting of the up and down limits will probably be required.
Jan 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door chain is sagging
If the chain is adjusted properly the chain will sag slightly on one side when the door is closed and on the other side when it is open. It should not sag enough that it is dragging on the T-rail. You can adjust it at the trolley. If you over tighten it you will hear a clicking sound when the opener opens or closes.
Jul 28, 2009 | Sears Craftsman LiftMaster Chamberlain...
How to switch back to automatic after manually close the garage d
mikey-moore's advice helped me figure out what to do but it's not exactly what I had to do. Manually open the garage door all the way. Then hit the automatic button you normally would use to open and close your garage door. The bracket slides back and locks into place. Hit the automatic button again and the garage door should automatically close.
Jul 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
I have a stanley garage door opener that won't close the door
the door beams are not working properly. Let me know what you find
Apr 07, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster garage door opener will only work at wall unit
check electric saftey beams. shovel blocking them. dirty. aligned (LED on in each unit)
Jan 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Keypad outside not working Properly
Have you replaced the battery in your keypad? That should take care of the trick.
Jul 16, 2008 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster security + model 1265 NOT CLOSING PROPERLY
wbuero, I had same problem two weeks. The door springs weaken over time and may need to be tightened - check opening force manually. Manufacturer also recommended reviewing install guide to be sure opener arm is attached at proper angle. The opener on my professionally installed door was not connected properly. It that doesn't work, the opener drive train or door track/wheels may need maintenence.
Jul 05, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
230 people viewed this question
Top Sears Building Materials Experts
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
