Question about Logitech Cordless TrackMan Optical Trackball
Trackball stops communicating with PC
Sometimes after I reboot my PC my Logitech optical trackball will stop working. If I unplug it from the back of the PC and then plug it back in (even in the same port) it will work just fine. Any ideas what's causing this?
  • 154 Answers
Hi, logitech mice quite often have an 'auto power off' after a period of time. Instead of unplugging and plugging it back in, try clicking one of the mouse keys, give id 1-2 seconds and try it again.
Posted on Feb 19, 2009
After months of good work my mouse stopped working, it has to be very close to the receiver for the pointer to move. New bateries installed, still the same.
Has any new piece of hardware been put in between the trackball and the receiver? Electro-magnetic fields can cause interference. I had a similar problem once - didn't even unplug the receiver, just moved it behind the monitor. It was a big clunky CRT screen and created a huge EM field - huge enough to cause interference with the trackball.
Oct 05, 2010 | Logitech Cordless TrackMan Optical...
Mouse not responding
Clean the PC Mouse
1. Unplug the mouse, turn it over, then twist the retaining ring counter clockwise to remove it. Remove the trackball inside the mouse.
2.Clean the trackball with warm water and dry carefully. Clean the rollers inside the mouse with a cotton swab dipped in alcohol. Replace the trackball then secure it with the retaining ring.
3.Clean the outside of the mouse with rubbing alcohol and a cotton ball. Use a small amount on one area at a time. For an optical mouse, clean the bottom of the mouse and the surface it sits on with a damp cloth.
Fix PC Mouse Problems
1.Plug the mouse back in. The connector will either be USB or PS/2. A PS/2 connector is color-coded green and can only be inserted in one direction. Check for any bent or broken pins, then carefully plug it in making sure the connection is secure. Reboot the computer, and then test the mouse.
2.Connect the mouse to another computer. After the mouse is connected to a different computer, reboot the system, and then test the mouse. If your mouse works on another computer, the problem is most likely with your PC or operating system
3.Check for device conflicts. When you install another device on your computer it can sometimes cause conflicts with a PC mouse. Remove any new hardware and drivers you may have installed then reboot the computer.
4.Reinstall PC mouse drivers. In Windows, open "Control Panel" then "System." Select the "Device Driver" tab then scroll to and select your mouse. Uninstall any drivers that are listed. Unplug the mouse then reboot the PC. Reboot the system again, plug the mouse back in, then allow Windows to reinstall the drivers if prompted.
Please rate me if this solution works for you
Thanks......Have a great time.
Aug 19, 2010 | Computers & Internet
Mouse ball stops responding, or responds irratically at times. shaking and rotating the mouse 180 seems to provide temporary solution...ball, and sensors are clean (mouse is only 2 mths old...)
Send it back for repair, there is no fixing the chip in a mouse. Sometimes they don't work after one day.
So it depends on how much you paid for it depends on if its work ending back.
This is a great mouse, I only use logitech.
It does have a 5yr warranty.
Feb 04, 2010 | Logitech Cordless TrackMan Optical...
Trackball Quit working changed battery still doesn't work
I had one, loved it and it just stopped working one day. Logitech has a great warantee and they gladly replaced it witha brand new one. Well now the new one just stopped working today....I guess I have to call Logitech again......
Dec 29, 2009 | Logitech Cordless TrackMan Optical...
Cursor when using Logitech Trackball sometimes drifts up or down
I finally just was able to solve this problem! I saw somewhere that someone had made sure their primary mouse was selected under hardware, which got me thinking. I thought I had seen a second mouse option somewhere. So, I went into my Control Panel > System > Device Manager and click the arrow next to Mice and other pointing devices. Sure enough, there were two listed. A seemingly generic one and my Logitech I've been using. I right clicked on the generic one and chose disable and the drifting IMMEDIATELY stopped. I went so far as to re-enable that generic to see if it was a fluke because it had stopped drifting on its own yesterday, nope as soon as I enabled the generic device, drifting started again. So Happy!!!
Jun 11, 2009 | Logitech Trackman Marble FX Trackball
Logitech Cordless TrackMan Optical Trackball connection
you are probably better off buying a new one
unless you are lucky enough to find a used one
Dec 09, 2008 | Logitech Cordless TrackMan Optical...
One more problem with "Vista'
Two options:
1. Download the latest Vista driver for your trackball or mouse from the Logitech website and do a clean install.
2. Go to Control Panel and uninstall that particular update.
Should work :)
Cheers!
ID
Nov 16, 2008 | Logitech Cordless TrackMan Optical...
Kid trackball
A lot of trackball controlls made by Microsoft and Logitech use a optical system. Once the control on the screen doesn't move anymore, you simply remove the ball and clean the optics out of it.
If there is a way that you can remove the ball out of the control, all you have to do is clean the rollers underneath the wheel. After some time they do build up just like a friction mouse does. All it takes is some Qtips and a water alchohol solution.
I would hope for a kid trackball they made that a feature.
Oct 31, 2008 | Microspeed KidTRAC Trackball
Logitech Cordless TrackMan Optical Trackball Logo
228 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
