Question about 450-R Deluxe Remote Starter with Keyless Entry
Alert 450R - Lights Won't Flash Anymore
When I turn the car on or lock the car using the remote, the lights no longer flash or stay on. Didn't do anything different, not sure why this started happening all of a sudden. Please help.
  • 95 Answers
Is your parking light wire, wired positive or negative. If positive check the fuse on the input wire for the parking lights on the remote start. If thats not the problem check the connection of the parking light wire,should be a whiite 16 gauge wire, to your car lights. If thats not the problem then they output for the lights is bad and you'll have to get a new brain.
Posted on Feb 19, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Interior light stays on when driving.goes off when I use key fob to lock
Interior lights will not turn off when door closed - VW Audi Forum
www.vwaudiforum.co.uk/.../36009-Interior-lights-will-not-turn-off-whe...
... locking when using key fob, only from the inside via the lock on the drivers door ...by key fob and manually turn off the interior lights but the door lights stay on.
close door light & interior lights - CarGurus
www.cargurus.com > Questions > Ford > Edge
CarGurusJul 24, 2010 - close door light & interior lights - close door light on my ford edge is lit up on the dash and the interior lights wont go off. all the doors, truck, and . ... are completly shut. what to do? help before my battery goes dead. ... charged Interior lights work Headlights are strong Key fob locks and ... Used Ford Escape".
Door Chimes, interior lights on when stopped, and power locks have ...
www.grandamgt.com > ... > Technical Q&A
Apr 28, 2011 - 13 posts - ‎5 authors
It really only happens when its totally stopped while in drive. ... Key Fob- It works, but no longer gives the horn sound to confirm its locked. ... The fact that the car doesn't honk when using the remote isn't a problem. ..... Currently my dome light stays lit when on the door position and my alarm goes off as soon ...
Help - Interior lights staying on / door locks going crazy ...
www.mazda3forums.com/...interior.../329450-help-interior-lights-stayin...
Feb 11, 2009 - It seems that my interior lights stay on while im driving. ... If you get into the car start up the car, and then close the door the lights shut off. ... the when youuse the key fob to lock the car at night the interior lights stay on as well.
Jan 27, 2016 | Cars & Trucks
New Beetle 2002 Hi-Beam lights only flash, don't stay on, what can I do?
I would test the relay to make sure it is still good and everything there is working like it is supposed to. I would also look at the switch and make sure noting came unplugged and it is still in good working order sometimes new parts are still bad.
Jul 26, 2015 | 2002 Volkswagen New Beetle
Avital 3100 keyless entry remote sets off alarm when trying to unlock or lock doors with remote. Doors stay unlocked but alarm keeps sounding off and car wont start.
hi'
i think the wire that connects to the door trigger for the interior light
a negative or a positive one has been mixed up
if its neg change it to the positive one
if its positive change it for the negative one
25666027-extj4arg1t42xbh3l3byl5v2-3-0.jpg the purple or green wire
cheers
Apr 26, 2015 | 3100L 1way Security System
Indicator light no longer flash when I lock car doors. .ignis suzuki
Yes, could be a fuse. I think a little more likely to be in your remote though, not sending a strong enough signal.
Dec 01, 2014 | Suzuki Cars & Trucks
Passanger side brake lights wont turn on when brake pedal is pushed
You didn't say what the car model was but some cars have the same lamp as the turn sig. So check your left turn signal and also the front left turn signal light bulb to see if they both are flashing.
Sep 23, 2012 | 2007 Subaru Impreza 2.5i
I changed the battery in my remote now my car will not respond
Reprogram the remote: press and hold the f button for approximately 8 seconds. the remote will flash three times. press the remote start button on the remote. the remote is now ready to pair. enter vehicle, turn ignition on, press and release button and antenna, immediately press and hold same button, the vehicle should respond with a horn honk and/ or light flash on antenna. While holding button on antenna, pres lock button on remote...vehicle should respond with a confirmation horn honk and/or light flash. Release button on antenna, turn vehicle off. Test system.
Jul 12, 2012 | 5101 LE 1 Way Car Remote Starter System
My fpa lock is on how do i get it off? Do not have the orginial remote
I just did this on my tv same exact model, I used a universal remote, it was an rca remote but im not sure it makes a difference. I programmed the remote to this tv with the tv off and it worked. the programming directions say to turn the tv on but i couldnt. If and when u get the tv on if u are using a universal remote get the menu up. most likely the light will be flashing. take the battery out and put it right back in. the light should no longer be flashing, and the menu should still be up. u can now navigate to the preferences and turn off the fpa lock... good luck
Apr 16, 2011 | RCA TruFlat 27F520T 27" TV
I have a 2005 Nissan Pathfinder and when I go to lock my car the lights blink, the doors lock, but it doesn't beep anymore. Any suggestions of what may have happened?
most nissans can turn this on and off. press and hold the lock and unlock buttons on the remote together for 5 - 10 seccons, until the horn beeps or the lights flash. thats the way to set them on most nissans
Mar 25, 2011 | 2005 Nissan Pathfinder
450-R Deluxe Remote Starter with Keyless Entry Logo
435 people viewed this question
Top Alert Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you an Alert Vehicle Part and Accessory Expert? Answer questions, earn points and help others
