Question about Plantronics - Bluetooth Headset Plus Base & Headset
My 222 plantronics bluetooth wont turn on and it's fully charged. what can i do?
  • 1 more comment
  • Anonymous Feb 22, 2009
    Hi, I got a 222 plantronics. It was working fine for about 2 days. Yesterday, in the middle of a conversation it decided to trasmit sounds to my phone. I hung up the call, and reconnected it. Last night, I plugged it in for a charge and today-- it won't connect at all.
  • ramseytine63 Mar 06, 2009
    I bought a 222 plantronics bluetooth 2/27/09 and I really liked it. Well on 3/4/09 a.m., it turned on and it connected just fine, but by the time I got to work it had just quit. It would not come on and I had charged it. I exchanged it around 2:00pm. They asked if I had charged the full 2 hours before using and I told them not initially. I took the new one never had been turned on and charged it for two hours. I turned it on and it connected. Well about 24hrs later same thing.
  • Anonymous Apr 14, 2009
    my password
SOURCE: charging plantronics 520/521
The red light will stay ON while charging and will go OFF when charged. Charging does not take long. Since you have no manual, you turn the headset on by pressing down or toward your head and holding the button down. If it's in your ear already, you'll hear a four-note upward pitch sequence to indicate it's powered on. If it's out of your ear, you'll see a red light, followed by a blue flashing light.
Set your phone into Bluetooth mode and make sure in the menus that Bluetooth is "discoverable" or some such lingo to search for the headset. The pairing code for this headset is 0000 (zeros not O's), so when you set your phone up to pair with the headset and the phone wants a pairing code, enter 0000. After the pairing is completed and Bluetooth is activated on your phone, you should hear a high pitched single tone to indicate the headset is in range and communicating with your phone. If you separate from your phone over about 30 feet or if communication is interrupted with your phone for some reason, there will be a lower pitch single tone, indicating loss of communication. After pairing, you should not have to go through the code sequences or setup again unless your phone is completely reset. You should be able to set your phone to Bluetooth, turn your headset on and hear the four-note sequence, followed by a single high note.
Push the switch up or away from your mouth to step the volume up. Likewise, push the switch down or toward your mouth to lower the volume. I've never turned it down, it's always a little low in volume to me even at max.
Push down or toward your head BRIEFLY to answer or hang up the call. Depending on your phone, you can also activate dialing or voice command by using this same brief push. There is a brief delay between pushing the button and being able to talk on most phones, so you might listen for a volume or noise change before talking.
To turn the headset off, push down or toward your head and hold the button down. You will hear a four-note downward pitch sequence to indicate power-down. If you're looking at the headset, you will see a steady red LED, then it will go off. By the way, a flashing red LED indicates need to recharge. A flashing blue LED indicates the unit is operating correctly.
Remember, battery consumption on your phone is greater with Bluetooth turned on, whether you use the headset or not. Bluetooth units constantly stay in touch with their partners, much like your phone stays in touch with the cell towers. So watch your phone's battery indicator a little more closely until you get used to your talk patterns and general use. Depending on your situation, your phone may not use much more battery than before.
Standby (inactive but ON) time on the headset is very good, and battery shelf life (power OFF) has been good also. These headsets are extremely useful in a car or if you are busy with your hands during calls. Just remember to use your head (pardon the pun) and not take or make calls while doing something dangerous. You wouldn't do that with your corded home phone, would you? The vote is still out, but they do tend to look a little nerdy when worn constantly in public. I hope you get as much benefit from your Bluetooth headset as I have from mine. I thought they were completely Nerdsville before, but I'm a convert now. Good luck.
Mark in Oklahoma
Posted on Aug 28, 2008
SOURCE: plantronics bluetooth won't turn on
me to i charge it one night and now it will not power up!
I put it back on the charger light turns red and then goes out!
Posted on Nov 06, 2008
SOURCE: passkey for my plantronics 222
try 0000
Posted on Jan 21, 2009
SOURCE: phone won't connect to the plantronics 222. When
I had that problem too. I finally realized that I had to press the enter key on my phone.
Posted on May 08, 2009
casouzaj
  • 1118 Answers
SOURCE: passcode for 222
First, try '0000' (four zeros), which is the most commonly chosen code by bluetooth manufacturers. If it doesn't work, swittch to '1234'. If this one also fails, very few models use '8888',
Hope one of them works for you.
Cheers! Carlos
Posted on May 15, 2010
Unable to turn on my plantronics 210 explorer bluetooth .therefore no light is showing in it. charger is fully charged
Sep 06, 2012 | Plantronics Explorer 210 Wireless...
Passcode for 222
Cheers! Carlos
May 15, 2010 | Plantronics - Bluetooth Headset Plus Base...
Plantronics 230 won't turn on
The batt is probably dead....if the batt fully dies,then you would have to buy a new bluetooth...charging wont help
Jan 01, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Lost my plantronics 222 bluetooth passkey
trying to install my plantronics 222 blue tooth head-set to my nokia 7610,but it keeps asking for a pass code.
Oct 03, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Plantronics 222 problem please help!
Make sure it is fully charged then hold the button down and don't let go till it flashes blue/red. You will see it turn blue first but still hold down the button till like I said it flashes blue/red.
Aug 22, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Phone won't connect to the plantronics 222. When
Apr 13, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Need guide/manual for Plantronics 222 Blue Tooth
first question,i have anplantronics explorer 242 when i plug it iun to charge it the light ired then after a few min. it turns blue,how do i know when its fully charged? will the lights go off?
Dec 16, 2008 | Plantronics - Bluetooth Headset Plus Base...
Plantronics bluetooth won't turn on
Jun 05, 2008 | Plantronics - Bluetooth Headset Plus Base...
Plantronics - Bluetooth Headset Plus Base & Headset Logo
813 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
