Question about Canon LaserClass 2060P Plain Paper Fax
Is there a way to turn off the report unless the report was not sent?
  • 59 Answers
Go to report settings and make sure TX REPORTS is ERROR ONLY not output yes.
Posted on Mar 20, 2009
Fax confirmation
most printer in the market has the same standard setting for the fax.
u can set the report many types for many user's purposes, some people want to save paper, save ink/toner, so they dont need report if the fax is sent but only print report if the fax is not good(NG or not sent)
it can be set to:
report off--means report will be print out only if the fax is NG
report off+image--means report will be print out if the fax is NG + the image of the page that is not sent(so we know which page is not sent through the image)
report on+image-- every fax activities( sent or not sent) will be reported, which is not recommended
etc....
how to set is depends on your printer, just go to the menu "FAX" and look inside the menu.
Jul 08, 2014 | Epson Workforce 520 All-in-One Color...
How to confirm message sent what is the code so i know the party is sent it to received it
There is a transmit report which can be auto printed for every fax message sent out. Go to menu, under the fax sub-menu, turn on the transmit report (under report).
Apr 10, 2014 | Brother IntelliFAX 1270E Plain Paper Fax
How do I print a single call report for a FAX previously sent
Printing a fax call report
A fax call report is a brief report that indicates the status of the last fax that was sent or received.
To print a fax call report
1. On the all-in-one control panel, press Menu.
2. Use the < or the > button to select Reports, and then press .
3. Use the < or the > button to select Fax Call report, and then press .
4. Press to select Print report now. The all-in-one exits the menu settings and prints the report.
NOTE To set the fax call report to print automatically, see Setting print times for the fax call
report.
Setting print times for the fax call report
You can set the all-in-one to print a fax call report after any of the following events:
? Every fax error (the factory-set default)
? Send fax error
? Receive fax error
? Every fax
? Send fax only
? Never
NOTE If you select Never, you will have no indication that a fax failed to be transmitted
unless you print a fax activity log.
To set the print times for the fax call report
Use the following steps to set when the fax call report is printed:
4. Press the > button once to select Print report, and then press .
5. Use the < or the > button to select the option for when you want the fax call reports to be printed.
6. Press to save your selection.
The following print-time options are available:
Including the first page of each fax on the fax call report
If this option is turned on and the page image still exists in the all-in-one memory, the fax call report
includes a thumbnail (50% reduction) of the first page of the most recent fax that was sent or
received. The factory-set default for this option is On.
To include the first page of each fax on the fax call report
Use the following steps to include the first page of each fax on the fax call report:
4. Use the < or the > button to select Include 1st page, and then press .
5. Use the < or the > button to select On or Off, and then press to confirm your selection.
Jul 06, 2011 | HP LaserJet 3050 All-In-One Printer
My HP 1040 fax prints a sending confirm notice after every fax is sent. Is there a way to turn this feature off as it is a major waste of paper.
Reports you can print
You can print these reports whenever you need to. Some of these reports can be set to print automatically also.
1. Press Report/Help.
2. Choose the report you want by using left or right arrow.
3. Press Start/Enter when the desired report is displayed.
4. The selected report will be printed.
Sending Confirm
A confirmation report shows whether the transmission was successful or not,
how many pages were sent, etc.
ON: prints a confirmation report automatically each time you send a fax.
OFF: never prints a confirmation report (You can print one manually using the
Report/Help button (see Print reports on page 51).
ERROR: prints only when an error occurs.
Nov 25, 2010 | HP 1040 Plain Paper Inkjet Fax
MFC 8300 Laser Printer: do i receive anything after i send a fax?...
Only if you have set the fax options to automatically print a sent item/transmission report. Otherwiase you will receive nothing unless the person or company you sent a fax to decides to fax you back.
May 06, 2010 | Brother MFC 8300 Laser Printer
We need to print a fax report for all faxes sent on February 17, 2010.. is that possible and how?
The m/c only keeps the last 40 transactions in memory so unless u haven't sent 40 faxes since then u wont be able to!Sorry!
Apr 07, 2010 | Canon FaxPhone L75 Plain Paper Laser
Received confirmation
Sent confirmation reports are available within the fax machine.
Theoretically if the fax has been successfully sent, it should be successfully received on the other end as well.
But unfortunately there is no confirmation for successful receipts, unless you are using IP based fax transfer.
Mar 31, 2010 | Brother IntelliFAX 560 Plain Paper Fax
Can I print the history of faxes sent?
You either press the reports button and select fax log, or press the menu button until you see reports and select fax log. It will save a few unless the machine has been unplugged for a while, in which case the report will be blank.
Nov 27, 2009 | Brother IntelliFAX 560 Plain Paper Fax
Hp officejet 6310 all-in-one send fax configure
1. Press Setup on the front panel of the All-in-One.
2. Press 2 to enter in to Print Report.
3. Press 1 to enter in to Fax Confirmation.
4. Press 1 to turn on Fax confirmation
5. Press 2 to enter in to Image on Fax Send Report
6. Press 1 to turn on Image on Fax Send Report
Jun 03, 2009 | HP Officejet 6310 All-In-One InkJet...
I cannot see my sent text messages
oyu have to turn your reports on and the phone might not save the message unless you ask it to as some phones dont save sent messages they just save the ones you ask it to save hope this is some help
Oct 28, 2007 | Samsung SGH-E900 Cellular Phone
Canon LaserClass 2060P Plain Paper Fax Logo
67 people viewed this question
old marine
old marine
