Question about Husqvarna Garden
Engine cuts out when I release clutch/brake
14 hp Jonsered Husk engine for ride on mower.
Engine cuts out when I release clutch/brake.
Haven't started engine since Sept 08 due to winter.
Has been stored outside under covering.
SOURCE: I have 16 hp Craftsman riding mower with a Kohler engine.
It may think you are in reverse and is killing the motor to keep you from backing up with the blade running. Look for switch that is telling it when you are in reverse, maybe it is stuck with grass or other debris. another possibility is that the blades are jammed and they are stalliing the motor. Mines stalls easily when cold.
Posted on Mar 12, 2009
  • 109 Answers
SOURCE: engine stalls when clutch/brake pedal is released
Under the seat, there is a operator presence switch, if this switch fails, the mower will shut off when the brake is released, or put in any gear.
Posted on Apr 23, 2009
  • 109 Answers
SOURCE: lawn tractor won't stay running if clutch is released.
There is an operator presence switch under the seat...it is more than likely faulty and must be replaced in order for the mower to run right.
Posted on May 03, 2009
  • 95 Answers
SOURCE: engine dies when clutch brake released on husqvarna gth2548
First check the seat switch,make sure it is plugged in tightly, these plugs have a safety tab built into them that will cut the engine off if you unhook it,sometimes the plug latch pulls out slightly and this will cut the engine, There are two other switches in the system one on the foot clutch and on on the mower clutch, if you follow the white wire from you ignition switch it will lead you to both of them,check those connections also.
Posted on Jul 31, 2009
RonInFla
  • 86 Answers
SOURCE: STARTS GOOD BUT ENGINE DIES WHEN CLUTCH RELEASED
cut the wires running to the switch...try again...if same, stripp back wires, and twist together...wrap in tape or use some sort of connector...it's electric and should be treated as such...try again...still ?? Start finding those switches and repeat the process til it works...theres usually 3 or 4...
Posted on Apr 18, 2010
Testimonial: "Haven't tried the suggested solution but makes sense."
Mower died when I engaged the cutting blades. Won't restart.
How long has it been since you used it? Could be a clogged carburator filter or bad gasoline. Gasoline left in lawn mowers and other small engines lose their kick after sitting for a fall and winter season. Try removing the carburator cover and take some fresh gas, just about a little less than 1/8 of a cup and pour it in the carburator and try to start the engine. Once it starts cover the carburator with the palm of your hand and then release it and cover again until the machine stays on after you remove your hand. This is called priming the engine.
Jun 18, 2015 | Ariens Max Zoom 60 in. 25 HP Kohler...
Where is the part located that shuts the mower off when you release the clutch
There is a safety switch for the brake clutch and if the seat safety switch is not activated by someone sitting on it, then the mower will die. So if you are sitting in the seat and the brake clutch is released and the seat safety is faulty then the engine dies, so the seat safety is where you should start looking.
Aug 31, 2011 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Release clutch/ brake pedal engine stops / as well engage clutch lever for mover / engine stops. Thank you for taking my question . engine runs well no problem starting engine stops when place mower in...
Hi Carl,
Just had this happen to me. The mower had sat all winter. During that time a couple bearings froze up.
It took a pipe wrench to free them up.
I worked in some oil and that solved it.
You need to check each pulley and bearing to see if you can spin it. If you can't, oil it first, then try to **** it free.
Once it lets go, a little more oil and you are all set.
Best regards
Mike
May 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Apr 18, 2010 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Engine dies when clutch brake released on husqvarna gth2548
Jun 22, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Mower will not drive
Usually, that's an indication the the seat switch is not working. It's like getting off the seat without locking down the parking brake or getting off the seat with the baldes engaged, same result...engine dies.
Jun 02, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Engine cuts out when engaging clutch or engaging blades..
lift the seat and make sure the connector is firmly plugged into the seat switch
Jun 01, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Engine stalls when clutch/brake pedal is released
Apr 21, 2009 | Garden
Engine dies off once brake/clutch is released
Your answer was perfect, when I located the saftey switch it was not working properly.
Thanks a million, Ron
Jan 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
101 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
