  • tuhucon Feb 28, 2009
    I have the same problem with my acer4150. When I pressed F2 to enter bios setup, I noticed that the laptop did not reconize the hdd. The laptop can't start even when I insert a bootable disc
  • 53 Answers
It sounds like the boot menu :)
try to use the arrow keys to select Hard disk and press enter
it should boot as usual.
Probably you pressed some Fn key as soon as you turned on the PC without noticing it.
Posted on Feb 19, 2009
  • 1,223 Answers
Go to setup and try F2 and see for boot device priority set hard disk on first place and others after it if it doesnt work after that ur hard disk might be giving u hard time
  • 203 Answers
1st chose harddisk and hit enter
2nd chose the boot order put the 1st device harddisk, if that will not solve your problem start the laptop in SAFE MODE and restore at a previos stage wen was working ok .
to start in SAFE MODE press F8 at the boot time.and chose SAFE MODE with windows.
Acer aspire d257 pxe-e61: media test failure, check cable error
Your computer tries to "boot" (start-up) from several devices:
* floppy-disk (if installed)
* disk-drive (if not "dead"),
* CD/DVD optical device (if "bootable" media has been loaded)
* PXE --> Pre-Execution Environment -- checks if there is a connection between the network-adapter on your computer to a "boot-server" on your local network -- it can load Windows from that "boot-server".
The "media-test failure" indicates that there is no network-cable attached to your computer *AND* the other-end of the network-cable is *NOT* connected to the "boot-server". So, you can that "error" message.
Is your disk-drive "dead" ????
Jan 24, 2013 | Compaq Presario-Notebook 700 Series, 2500...
Acer Aspire 7741Z 4433 does not see the operating system, new hard drive.
with a new hard drive , ti will not have an operating system installed
turn thr computer on and hold down the delete button until the bios screen comes up
click on the boot tab and set boot priority to first device c
put the cd in the cd drive
switch off the computer and then restart
the boot will now read the cd and reinstall the operating system
when installed go back into the bios and change back to first device --hard drive
May 09, 2017 | Acer Aspire Computers & Internet
Pxe-e61: media test failure, check cable acer extensa 542
Your computer tries to "boot" from several devices:
* floppy disk
* disk-drive
* external CD/DVD
* USB memory stick
* PXE ("Pre eXecution Environment)
To use PXE, you need "media" -- a network cable connecting yur computer to a "boot-server". The "media test faiure, check cable" reports that no network-cable exists, or that it does exist WITHOUT being connected to a boot-server.
Probably, your computer failed to boot from a DEAD disk-drive, and then tried floppy/CD/USB before checking PXE.
Replace the disk-drive.
Jul 30, 2012 | Compaq Presario-Notebook 700 Series, 2500...
I have an Acer Aspire1 Netbook and below is the problem. Went to BIOS set defaults but still get the same thing: For Atheros PCIE Ethernet Controller... check cable connection PXE-MOF:exiting intel PXE...
A computer tries to "boot" from many devices:
* 3.5-inch floppy-disk (if available)
* USB memory-stick (if connected)
* internal CD/DVD device
* external CD/DVD device
* internal disk-drive
* over your network-cable, by talking to a "network boot server".
When it tries to boot over the network-cable, and *NO* "boot-server" responds,
you get the "check cable connection" and "exiting from P(re)(e)X(ecution)E(nvironment)" mode.
If it cannot boot from your 'C:' drive, and cannot boot from the network boot-server,
your computer responds "no bootable device" and "insert boot disk" (into CD or floppy-disk),
and "press any key" (to try again to boot).
What this USUALLY means is that your 'C:' disk-drive has stopped working,
meaning that Windows cannot be "booted" from it.
Seek help from a qualified technician to trouble-shoot your disk-drive, and/or to replace it, and/or to reinstall Windows, and/or to "repair" your existing Windows installation.
Dec 28, 2010 | Computers & Internet
My computer fell and when I turned it back on it's saying check cable connection..! PXE-E63: Error while initializing the NIC pxe-m0f:Exiting Intel pxe rom no bootable device
Usually, your computer tries to "boot" from multiple sources:
1. 3.5" diskette drive, if installed, functional, and a boot-diskette is inserted
2. CD-ROM drive, if installed, functional, and a boot-CD (such as the Windows XP CD-ROM) is inserted
3. disk-drive, if installed, functional, and the "boot" record can be read from the disk-drive
4. from the Ethernet network, via a "networked boot server"
So, "check cable" means that either no Ethernet cable is connected to the computer, or that the "networked boot server" is not installed, or the boot-server did not reply.
What this means is that your disk-drive was damaged by the fall, and the "boot" information cannot be read from the disk-drive.
So, you need to replace the disk-drive.
Nov 09, 2009 | Acer Aspire One PC Notebook
PXE ROM no bootable device
your cable tv problem is not related to your computer issue.
Start your pc and enter the bios (usually by pressing F2 or Del) and navigate to the boot options. put the bootup options in a similar order to this, Floppy, CDROM, Primary harddisk. then disable network boot or add network boot to the end of the list.
Sep 09, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
Acer Aspire 5100-5674 won't boot. Keyboard won't work, mouse initializes. PXE-E61 : Media Test Failure then PXE-M0F : Exiting PXE ROM I really need some help, I just bought it. And would really like to...
PXE errors are generated by the network boot ROM. In other words, the boot process is attempting a network boot (your BIOS' 4th boot option), which means that your system was unable to boot from a HDD, CD-ROM, or USB device (the first 3 boot options).
PXE-E61 Media Test Failure, System won't boot:
1.Go to Bios Settings
2.Remove LAN booting from booting options...For laptop ,type "X" on the LAN booting option.
3.Save The configuration
Also verify if your harddisk is detected by BIOS
Jul 30, 2009 | Acer Aspire 5100 Notebook
Hi. Well there are not any reason for this problem to appear. Done nothing regarding disk problem. Anyway when I boot the process stops with the black screen with "Verifying DMI Data...... Boot from...
Make sure you dont have a floppy in the floppy drive inserted.
Also if you have a jump drive installed, plz unplug it.
But if you little computer savy. Go to your bios and make the boot sequence to first boot the Hard Drive
May 24, 2009 | Foxconn G31MX-K socket LGA775 motherboard
Aspire 5100 how do i run recovery cd's. notebook won't boot up
hi LWeller1l what you computer is trying to do is boot from a network and it's not picking one up so it gives you an error message, to check if it's just this....... go into your bios and check the boot order it should have or dvd/rom drive as first boot option then the .........hd meaning harddisk then the pxe boot, if they in this in this order and the pxe option is not above the harddisk in the order you may have harddisk problem. when the computer boots it uses this order to start, so in this order it checks the cd/rom or dvd/rom for a bootable disk, if none is in there it then tries to boot off the harddisk, if this fails then look to the pxe boot option which is network boot option off a server,........another thing is you if you don't have server you can disable the pxe boot option completly in if they are in this order in the bios then you may have to re-install the operating system or the disk may be corrupted or failed.
Oct 08, 2008 | Acer Aspire 5100 Notebook
Acer aspire 3515 reboot
Hopefully, though, there's just some craziness going on with the Boot
....suggests that the error messages you are seeing are from a failed
attempt to boot from a network source.
Check the boot order in your BIOS to insure that the hard drive is
fairly high in the list. Generally, I have it something like this:
(1) Floppy Drive
(2) CD-ROM
(3) Hard Drive
If you do this, will it boot from the hard drive?
Will it boot from a bootable CD?
Oct 02, 2008 | Computers & Internet
Computers & Internet Logo
750 people viewed this question
David Payne
David Payne
