Question about LG Flatron F700P 17" CRT Monitor
The monitor comes on on its screen it displays "NO SIGNAL INPUT or CABLE DISCONNECTED" then when pluged to the cpu it just comes blank with a noise inside the monitor ....tick...tick......its a dell monitor
  • ttc_jal Mar 07, 2009
    no signal displayed on the screen and when i am conecting a cable with the computer it have no display
  • 77 Answers
If another monitor is available check it on your system and check yours on another. this is the simplest way to eliminate possibilities. could be your video card all together, just not kicking out a signal
Posted on Feb 19, 2009
Just purchased Asus VE248H monitor. Used a 10 pin connector and was happy, but wanted more. Hooked monitor to pc with an HDMI cable, got HDMI - NO SIGNAL. Screen went dark. Disconnected HDMI, reconnected...
Hi , just access the monitor on-screen display (OSD) menu and ensure Monitor input mode is configured for HDMI ( Asus speak the " desired input source" ) - Input select is accessed under tv with arrow icon : change from vga to hdmi
Mar 03, 2015 | ASUS Ve248h 24-inch Led Monitor
Screen says check signal cable - have check my cables....
Not really...
First check if the cable connected from the monitor is secured and properly connected to the video card of the CPU.
"Check signal cable" will only be display if there is no signal coming from the CPU.. that signal Passes through the video card..
Check the status of your video card.....and see also if the CPU is working and not dead set.
Hope this help...
Much appreciated if you rate this help.. thanks
May 21, 2010 | Samsung Syncmaster 730B 17" Flat Panel LCD...
No input signal
that is the problem of cpu not a monitor to confirm disconnect signal cable and power on. monitor will show "no signal check signal cable" it means that monitor is ok and fault lies in cpu .then open the cpu and disconnect ram and listen the beep. contineus beep should be heard then ram is faulty replace it. if no beep heard then motherboard is faulty .
Mar 08, 2010 | HP vs17
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
MONITOR NOT COMING ON . RGB NO INPUT SIGNAL .
You first take post( power on self test) connect power cord & disconnect signal cable you will see massage no signal check siganl cable then problem will be in cpu this problem may be solved by cleaning dust in cpu if montor shows no display then problem will in monitor open it check o/p of smps if not disolder path of eht if o/p comes then eht is faulty replace it
Oct 28, 2008 | Computers & Internet
Sony Screen Colors
it may not have problem of monitor first take the post (power on self test) to do so you have to disconnect 15 pin signal cable from cpu and power on it will give display without cpu the massage "no signal check signal cable" will appear then monitor is ok problem is in cpu. if no display come then problem in monitor
Oct 25, 2008 | Computers & Internet
Monitor problem
Hi, sandjkroll, this kind of problem could be because of ur monitor or even because of the on board display  card on ur motherboard. To check ur monitor, u unplg display cable which goes to ur cpu and the power cable which goes to ur cpu.
Them connect the power plug to mains, so no cable from the monitor should go to the CPU. Then u swithch on the the poower suply, and on the monitor. I
If ur monitor displays elongated screen still, and shows signal not found,and no display comes that means ur monitor needs to be send for service. and if there are no elongated screen and says no signal found, ur monitors fine, ur motherboad has a problem
From
Deepak
Sep 28, 2008 | Microsoft ChiMei CMV938D 19" Widescreen...
Montitor is blank
chk ur monitor with the input cable disconnected(the one coming frm CPU to MONITOR) if ur monitor shows any thing like no input then ur monitor is ok
and it means that ur OS has crashed.
Install new OS.
Jul 08, 2008 | Computers & Internet
Can't find video signal
If screen says "Signal cable not connected " all the time till power led switches to Amber chances are monitor is ok and problem is with graphic card or cpu.Connect to Known working CPU and confirm that monitor is the problem.
If same problem persists on another working cpu after changing signal cable,the interface board in the monitor could be defective.
Samir
PLease rate solution and provide feedback.
Jun 09, 2008 | BenQ FP731 17" LCD Monitor
No signal on first boot
I think is a power supply problem,,
Mar 10, 2008 | Nokia 445 Pro 21" CRT Monitor
LG Flatron F700P 17" CRT Monitor Logo
121 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
