Question about Xerox WorkCenter PE120i All-In-One Laser Printer
Wrong time printed on fax
For some reason the fax we sent out reflect one hour difference from the time it was really sent.
Checked menu to find out how to reset the time, but there is nothing that indicates a time reset.
  • paul_r_zurch Feb 23, 2009
    Great website and rapid solution. Thanks
    President:
  • 2,072 Answers
  1. From the machine, press the [Menu] button until 'Machine Setup' appears on the top line of the display.
  2. Press the right arrow button until 'Date & Time' is displayed on the bottom line, then press [Enter].
    1. Enter the correct time and date using the numeric keypad. By default, the machine clock mode is set to 12-hour format; however, this can be changed to a 24-hour format (see the change the clock mode section below).
    2. Month = 01 ~ 12
      Day = 01 ~ 31
      Year = requires four digits
      Hour = 01 ~ 12 (12-hour mode)
      00 ~ 23 (24-hour mode)
      Minute = 00 ~ 59
    Note: To select 'AM' or 'PM' for a 12-hour format, press the * or # button or any number button.
    1. Once the correct date and time has been entered, press [Enter].
    2. Press the [Stop / Clear] button to return the machine to Standby mode
    Posted on Feb 19, 2009
    • Rick Kasper Feb 28, 2009
      Your welcome. Anytime you have a question just ask. Most of the time someone here has a solution.
    How do we set Samsung pro express M4580FX to do auto fax sent status and confirmation after each fax is sent (rather than printing reports)
    dear
    the sent report can be disabled at FAX SETUP.press menu and scroll to enter fax setup scroll to display report enter here to enable or disable the report. the sent report only display for short time after sending the fax. also you can take a print of journalreport.
    Thanks.
    Mar 02, 2015 | Samsung Office Equipment & Supplies
    How do I print the fax confirmation page on the x4270? Are the instructions printed anywhere? How to set the time?
    here's the solution to enabling fax confirmation: press the fax button on the printer front panel,the press option 16 or until advanced fax appears.(you can also press the right arrow to get to that option). press select push options twice.fax confirmation menu will come on the front panel display.push the right arrow button. The following options are displayed: Off - Select this option to receive no confirmation. Print for all - Select this option to receive confirmation whenever a fax has been sent, whether successfully or not. Print for errors - Select this option to receive confirmation (an error page) only when a fax has not been sent/received successfully.
    ***************************** here's the solution for setting time on printer display on the printer control panel,push fax push options until EDIT DATE/TIME: appears on the printer display to change the date: - press select - use the keypad buttons to enter the date. Note: If you make an error entering the date, you can use the left arrow button to navigate to the number you entered incorrectly, and then enter your correction. - press select
    To change the time: Press the right arrow once, and then press Select. Press 1 for 12-hour time or 2 for 24-hour time. Use the keypad buttons to enter the time you want your All-In-One to display. Note: If you make an error entering the time, you can use the left arrow button to navigate to the number you entered incorrectly, and then enter your correction.
    Press Select. If you are using 12-hour time, press 1 for AM or 2 for PM. Note: If the time is entered incorrectly, the time shown will be the default.
    ************************************************** i will also put in the link for the manual for additional assistance: http://www.lexmark.com/publications/pdfs/4200/eng/frameset.html
    Jun 12, 2011 | Lexmark X4270 All-In-One InkJet Printer
    Have Brother MFC-7840W Printer/Fax How do you set the fax to print off confirmation reports
    Hi there!
    For you to setup the confirmation here's what you can do:
    -Press Menu/set 2,4,1 -Press the Up or Down arrow key and select ON you can select On+Image to get a confirmation with the image of the document that u fax. -Press Menu/set to confirm -Press Stop/exit
    To print the confirmation page for your last transaction just press Reports and press the up or down arrow key to select Transmission
    Hope this helps! Thanks!
    Jun 03, 2011 | Brother MFC 7840W Printer
    My HP Laserjet 3050 used to print automatically after each fax sent a call report showing that the page(s) had sent. For some reason, after a service call, now it doesn't do that any more and I have...
    Hi Dear
    HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report Description By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
    1. Press the right arrow until Reports appears in the display, press the checkmark.
    2. Press the right arrow until Fax Call Report appears in the display, press the checkmark.
    3. Press the right arrow until Print Report appears in the display, press the checkmark.
    4. Right arrow to the option of choice, press the checkmark to save the change.
    FAX call report options
    • Send Fax Only - a confirmation sheet will only print when a fax is sent
    • Never - no fax confirmation sheets
    • Every Error - default setting
    • Send Error - a fax confirmation prints when the fax transmission encounters an error
    • Every Fax - a fax confirmation sheet will print for incoming
    Jun 01, 2011 | HP LaserJet 3050 All-In-One Printer
    Does my printer give a confirmation after faxing is completed?
    Normally if i fax is sent, it will just give a message as Fax sent or it wont give any error.
    But if you want to get a confirmation whether the fax is sent or not, you can print a fax confirmation page on ever fax sent or received or both.
    Press the SETUP button ( menu )
    Scroll till you find Print Report - Press OK
    Scroll till you find Automatic Reports Setup - Press OK
    Choose Send Only - Press ok
    Regards,
    Ron
    Mar 23, 2011 | HP OfficeJet 6110 All-In-One InkJet...
    Need printed confirmation fax receipts
    I had the same problem with my 6210. A different machine, but this may be worth a try. You need to go to the general setup, rather than the fax menu on the keypad. Two pushes of the button takes you to "print reports". Press OK and you go to "Fax Report Setup", OK again gives you "Print Report". You then can toggle with the arrows for the various options. In this case press OK when you are on "sent faxes"
    Apr 20, 2009 | HP OfficeJet 6210 All-In-One InkJet...
    Time date stamp on fax machine
    The time it was sent, if they have the time set correctly on the sending fax machine
    Mar 04, 2009 | Brother IntelliFAX 4100 Laser Fax
    Don't want a transmission report after each sent fax
    On the machine there is a menu button.
    the menu can be printed out so you can see all the areas to select.
    If you scroll to through the menu, you will find a set up or incoming fax menu.
    You need to set confirmation to off.
    This will take some time to find the right menu, so be patient with the machine.
    Good luck.
    Feb 23, 2009 | Xerox FaxCentre F116 Plain Paper Laser
    How to open a message???help!!!!!
    On the console you should find menu buttons. Find jobs or job prints. Select your number job and print it.
    The menu buttons have many features you can scroll through. The print reports can print out the menu of the different menus of the fax machne.
    good luck.
    Feb 17, 2009 | Xerox WorkCentre Pro 785 Plain Paper Laser...
    Set up Print Report for each time a fax is sent
    Use the following steps to set when the fax call report is printed:
    1. Press MENU/ENTER.
    2. Use the < or the > button to select Reports, and then press MENU/ENTER.
    3. Use the < or the > button to select Fax Call report, and then press MENU/ENTER.
    4. Press the > button once to select Print report, and then press MENU/ENTER.
    5. Use the < or the > button to select the option for when you want the fax call reports to
    be printed.
    6. Press MENU/ENTER to save your selection.
    Use the following steps to include the first page of each fax on the fax call report:
    4. Use the < or the > button to select Include 1st page, and then press MENU/ENTER.
    5. Use the < or the > button to select On or Off, and then press MENU/ENTER to confirm your
    selection.
    Jan 23, 2009 | HP LaserJet 3015 All-In-One Printer
    Xerox WorkCenter PE120i All-In-One Laser Printer Logo
    271 people viewed this question
    Top Xerox Office Equipment & Supplies Experts
    Michel
    Xeroxrep
    Level 1 Expert
    Philip Hughes
    Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
