FixYa.com
Tags:
Panasonic AY-DVM60E Mini DV Tape
REUSING DV Tape (by 2 users)
By Bray - usenet poster
Dear Videophiles,
I have many DV tapes that I would like to reuse.
What's the best approach?
1. Just record over the existing signal
2. Blank the tape before reusing
If you recommend 2 then please recommend a bulk eraser for DV tapes.
Does bulk erasing remove timecode?... or does timecode remain??
Arcita
PS: Beware of Panasonic AY-DVM60E tapes. They're less expensive but their
performance is suspect. I took a ten pieces on a trip to India and had poor
results. i.e., frequent shearing in the picture on playback. This happened
on many tapes, not just one. I suspected my camera at first (Sony TRV7) but
had it checked out on return and it passed muster.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by wilga1, posted on Jun 08, 2008
Need to find out how to erase used tapes. Any suggestions?
Solution #1
posted on Aug 01, 2007
Not Rated (0)
lawyer
lawyer - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I've had good results with Panasonic MiniDV tape over the past 11 months.
The only issue I my DHR-1000 wants to record in LP mode on the Panasonic
DVM-80 tapes, the metal contacts on the 80 min cassette apparently fool the
DHR-1000 into going into an undocumeted LP record mode! Strange but true.
My policy is to resue tape (an tape) only when I can recover should a problem
occure with the recycled tape.
Posted via Deja News, The Discussion Network
# Search, Read, Discuss, or Start Your Own
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Horner
Horner - usenet poster
Rating: 0%, 0 votes
Solution #3
Not Rated (0)
Ross
Ross - usenet poster
Rating: 0%, 0 votes
I had the sane problem with Panasonic mini DV tapes. I had the camera
checked and it was fine but the tape was shot after only one use. I've
spoke to a few people here who say they will no longer use Panasonic Mini
DV tapes.
It's suprising as I've always found Panasonic products first rate.
Brett Ramsey
Solution #4
Not Rated (0)
Putty
Putty - usenet poster
Rating: 0%, 0 votes
Yes. I just got back from Egypt and I have seen the same thing. One
tape is really bad; two others only have problems here and there.
I have previously read that you should stick with one brand of tape
because the binders used by different manufacturers can be
incompatible and result in gumming up the heads. Can any recommend a
method for switching from one brand of tape to another? Is a standard
cleaing cassette enough? Does it matter which brand of cleaner?
Also, can someone recommend a better tape?
Thanks,
Kevin
Solution #5
Not Rated (0)
Bouncy
Bouncy - usenet poster
Rating: 0%, 0 votes
I use the 60 min. Panasonic mini-DV tapes every week and I have had
no problem after shooting over 20 movies with them.
Jim Gunn
Jim Gunn Productions, Inc.
writer/photographer/director/content provider
website #
e-mail
(Please delete REMOVE from the e-mail address to reply)
Solution #6
Not Rated (0)
Brad
Brad - usenet poster
Rating: 0%, 0 votes
Same here, I bought two used one and returned them both some days later...
Can you Help with these Audio and Video Media problems?
SOUND DRIVERS FOR ASUS MOTHER...
i want to install sound driver... Answer This...
Setting timer on T.V. screen
I set a couple programs to play... Answer This...
E-MU Proteus 1 volume control
I had what was seemingly low... Answer This...
Unlock dvdplayer
How can make my Philips PET... Answer This...
need a code to activate dvd...
Hi there, i have a phillips... Answer This...
Repair Service
Find Audio and Vid. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
